Xtal/chip combo for 60 Hz ?
Discussion in 'Electronic Design' started by Guest, May 14, 2004.
  1. Guest
    Guest Guest
    Is there a commonly available crystal and divider chip combination to
    generate 60 Hz?
    Guest, May 14, 2004
    #1
    1. Advertisements
  2. Guest
    Rich Grise Guest
    <> wrote in message
    news:c2Fnb2JvZw==...
    > generate 60 Hz?
    Yes, but it's so much simpler and cheaper to use the line freq., if it's
    60 Hz in your area. Long-term more stable, too. Remember electric clocks?
    They used to use the line freq - they actually had a little synchronous
    motor.
    Otherwise, find a crystal that's on a 2^n multiple of 60 Hz, and divide
    it down with a 4060.
    Cheers!
    Rich
    Rich Grise, May 14, 2004
    #2
    1. Advertisements
  3. Guest
    Steven Swift Guest
    (Steven Swift) writes:
    >from the line or using a binary crystal such as 4.194304MHz with a
    >CD4060, but very nice if you want to generate a perfect 60Hz.
    Whoops, that was to get 1Hz, need a multiple of 60.
    But the RM works.
    Steve.
    Steven D. Swift, , http://www.novatech-instr.com
    NOVATECH INSTRUMENTS, INC. P.O. Box 55997
    206.301.8986, fax 206.363.4367 Seattle, Washington 98155 USA
    Steven Swift, May 14, 2004
    #3
  4. Guest
    John Fields Guest
    On Fri, 14 May 2004 21:39:36 GMT, "Rich Grise" <>
    wrote:
    ><> wrote in message
    >> generate 60 Hz?
    Unfortunately, short-term it sometimes goes to zero Hz.
    >motor.
    4060 ÷ f XTAL COMMONLY AVAILABLE?
    OUTPUT N Hz DIGI-KEY
    Q3 8 480 NO
    Q4 16 960 NO
    Q5 32 1920 NO
    Q6 64 3840 NO
    Q7 128 7680 NO
    Q8 256 15360 NO
    Q9 512 30720 NO
    Q11 2048 122880 NO
    Q12 4096 345760 NO
    Q13 8192 691520 NO
    John Fields
    John Fields, May 14, 2004
    #4
  5. Guest
    CFoley1064 Guest
    >Subject: Xtal/chip combo for 60 Hz ?
    >From:
    >Date: 5/14/2004 3:20 PM Central Standard Time
    >Message-id:
    ><c2Fnb2JvZw==>
    >generate 60 Hz?
    Of course, the customary solution for this is to use the 60 Hz line frequency
    to do this. Otherwise, the customary answer is to generate an interrupt off of
    your microcontroller timer/counter using the crystal-based uC clock frequency.
    But somehow, I don't think that's what you're looking for.
    Given that, I don't think there's a one-chip solution that will get you where
    you want to go. An older UART crystal frequency of 1.2288 MHz will get you a
    two-chip solution (view in fixed font or M$ Notepad):
    60 Hz From Crystal or Oscillator
    ..-----o-----. | | | |
    | | | CLK /2^11| | |
    | 1.2288MHz o----o CD4040 o------oCLK |
    | | | | | CD4017 |
    '-----o-----' | | .-oEN |
    | | | | OUT/10 |
    | | | '-------o------'
    GND |
    o
    60 Hz
    Squarewave
    A cursory scan doesn't show any crystals at this frequency from the usual
    hobbyist suspects, but you can get a full-size TTL/CMOS-compatible clock
    oscillator at this frequency from Mouser for $1.50 USD from Mouser (P/N
    520-TCF122). Have fun.
    Good luck
    Chris
    CFoley1064, May 15, 2004
    #5
    > generate 60 Hz?
    You don't mention how accurate of a source that you need. A PIC, some
    simple code and virtually any crystal could do it quite well.
    Anthony Fremont, May 15, 2004
    #6
  7. <> wrote in message
    > generate 60 Hz?
    #7
  8. Guest
    budgie Guest
    >generate 60 Hz?
    There USED_TO_BE a standard Fairchild chip -a 5369 (forget the prefix, and the
    suffix brings up different output freqs) that went from a colour burst crystal
    freq to line freq. Oscillator on chip.
    Here in .au, where the line is 50Hz and the colour burst xtal is 3.579545 and a
    bit, the -EYRN suffix chip was the deal.
    budgie, May 15, 2004
    #8
  9. Guest
    Rich Grise Guest
    Rich Grise, May 15, 2004
    #9
  10. Guest
    Rich Grise Guest
    And a 74HCU04 for the oscillator.
    "Rich Grise" <> wrote in message
    news:Zdwpc.202855$...
    > "John Fields" <> wrote in message
    > news:...
    > > Q13 8192 691520 NO
    > OK, a 6.000000MHz crystal (digi-key CTS CTX605-ND
    > http://dkc3.digikey.com/PDF/T042/0685.pdf )
    > and 2.5x 74HC390
    http://www.semiconductors.philips.com/acrobat/datasheets/74HC_HCT390_CNV_2.pdf
    > Better?
    > Cheers!
    > Rich
    #10
    1. Advertisements
Similar Threads
  1. Preston Andreas
    50 hz motor on 60 hz
    Preston Andreas, May 13, 2006, in forum: Electronic Basics
    486
    Preston Andreas
    May 13, 2006
  2. Red Fox
    Battery charger - 50 Hz at 60 Hz
    Red Fox, Oct 29, 2006, in forum: Electronic Equipment
    11
    1,382
    Red Fox
    Oct 31, 2006
  3. Dave
    Thoughts on running 50/60 Hz SMPS on 400 Hz
    Dave, Jun 13, 2008, in forum: Electronic Design
    11
    1,533
    Don Klipstein
    Jun 17, 2008
  4. Red Fox
    Red Fox, Oct 29, 2006, in forum: Misc Electronics
    11
    511
    Red Fox
    Oct 31, 2006
  5. Lee
    60 hz xtal radio
    Lee, Dec 14, 2004, in forum: Beginner Electronics
    580
Loading...
