Why is Electrical length greater than physical length?
Discussion in 'General Electronics Chat' started by shopitham, Feb 14, 2011.
  1. shopitham
    shopitham
    Nov 30, 2010
    5
    HTML:
    Hai
    1)What does a electrical length in transmission line means?
    2)How does it differ from the physical length?
    3)Why is electrical greater than that of the physical length?
    some pls help me find the ans .
    Shofiya
    #1
    1. Advertisements
  2. shopitham
    rob_croxford VIP Member
    Aug 3, 2010
    262
    Birmingham, England
    The Physical length of a coaxial cable (such as cable used in transmission lines) is the length from one end of the connector to the other.
    The ELECTRICAL length of such a cable depends on the size and type of the dialectric material used within it (if im not mistaken). It is measured at the mating plane of the outer conductor and is the length of the adapter as it appears to the signal traveling through it.
    Try google if u need more info.
    Rob
    rob_croxford, Feb 14, 2011
    #2
    1. Advertisements
  3. shopitham
    davenn Moderator
    9,782
    983
    Sydney, Australia
    The electrical length of a transmission line is dependant on 2 things...
    1 ... the velocity factor of the line and
    2 ... the frequency
    an example ... to find the electrical length of a transmission line or dipole antenna
    say for 400MHz
    (300 million metres / sec (300,000 km / sec))
    300 / 400MHz = 0.75m or 75cm that is the wavelength
    now if we want an electrical wavelength in a transmission line that has a VF (velocity Factor) of 0.85 then....
    75 x 0.85 = 63.75 cm so you can see that the electrical wavelength is shorter
    than the free space wavelength
    davenn, Feb 14, 2011
    #3
  4. shopitham
    ans
    Nov 25, 2010
    19
    Nice information thanks for sharing.
    ans, Feb 16, 2011
    #4
    1. Advertisements
Similar Threads
  1. LIJO
    563
    Kevin G. Rhoads
    Aug 21, 2003
  2. LIJO
    1,686
    Kevin G. Rhoads
    Aug 21, 2003
  3. Paco Rosso
    Refelctions greater than 1 and L*
    Paco Rosso, Aug 1, 2005, in forum: Lighting
    423
    Paco Rosso
    Aug 2, 2005
  4. john54
    Can aperture efficiency of antenna be greater than 100%?
    john54, Jun 14, 2012, in forum: General Electronics Chat
    452
    john54
    Jun 14, 2012
  5. 24Volts
    5
    630
    24Volts
    Aug 17, 2013
Loading...
