Where to buy thermal fuse?
Discussion in 'Electronic Repair' started by james, Aug 26, 2010.
  1. james
    james Guest
    I have a steam mop that has a bad thermal fuse
    SFFUSE
    SF188E
    192 degree C
    10A
    250V
    Frys and radio shack sell thermal fuse for $1 to $2, unfortunately they are
    all lower temperature rated. I could mail order it, but it's silly to mail
    order a $1 part and pay $5 shipping.
    What other local stores are likely to carry thermal fuse?
    The fuse is crimped to the other wires. Once I have the replacement, do I
    have to crimp it, or can I solder it? I already have soldering iron but
    don't have crimping tools.
    james, Aug 26, 2010
    #1
    1. Advertisements
  2. N_Cook
    N_Cook Guest
    james <> wrote in message
    news:i55387$2ge$...
    > SFFUSE
    > SF188E
    > 192 degree C
    > 10A
    > 250V
    are
    I have soldered thermal fuses before and lower temp than that, but you need
    freezer spray on the bulge, leave the leads long with enough room for
    heatsinking clamps/forceps or the like, in between bulge and solder point.
    For 10 amps you need a reliable crimping system
    N_Cook, Aug 26, 2010
    #2
    1. Advertisements
  3. Smitty Two
    Smitty Two Guest
    In article <i55387$2ge$>,
    > SFFUSE
    > SF188E
    > 192 degree C
    > 10A
    > 250V
    Radio Shack 270-1321 is a 228C. If you can't find the right fuse, stick
    in a bigger one, I say.
    Smitty Two, Aug 26, 2010
    #3
  4. Guest
    >SFFUSE
    >SF188E
    >192 degree C
    >10A
    >250V
    Here you go. $.98 for quantity one.
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1139-ND
    They only have 1330 in stock. Specify USPS First Class Mail for
    shipping. It'll cost about $2.00 for shipping and will be in your
    hands in two days.
    PlainBill
    , Aug 26, 2010
    #4
    1. Advertisements
Similar Threads
  1. DaveC
    Help with thermal fuse specs?
    DaveC, Dec 15, 2003, in forum: Electronic Basics
    9
    788
    Ben Miller
    Dec 17, 2003
  2. John
    37
    3,387
    Joseph2k
    Mar 7, 2006
  3. Jamie Morken
    3
    1,371
    RoyLFuchs
    Oct 5, 2008
  4. Jabill
    replace thermal fuse with thermal switch?
    Jabill, Mar 4, 2012, in forum: Electronics Repair
    2,421
    UnionTech
    Mar 5, 2012
  5. eem2am
    Thermal vias in thermal pad of IC?
    eem2am, Dec 4, 2013, in forum: Electronic Projects
    5
    539
    KrisBlueNZ
    Dec 4, 2013
Loading...
Share This Page
