What's the best way to measure large capacitors?
Discussion in 'Electronic Design' started by Norm Dresner, Aug 15, 2004.
  1. Norm Dresner
    Norm Dresner Guest
    I'd like to check out some large capacitors (not supercaps), say, 20,000 -
    100,000 uF. What's the best method? Timing the rise (or discharge)
    between two voltage levels? Impedence at three frequencies (to try to
    separate out ESR & inductance)?
    TIA
    Norm
    #1
    1. Advertisements
  2. Norm Dresner
    Ken Smith Guest
    In article <3jMTc.211332$>,
    I'd say measure both the rise and discharge. Use largish resistor values.
    Make the measurement after the charge and discharge has been happening for
    several mS. This way you can pull out the leakage and series resistance
    and are at low enough frequencies the ESL doesn't matter.
    forging knowledge
    Ken Smith, Aug 15, 2004
    #2
    1. Advertisements
  3. Norm Dresner
    mike Guest
    > TIA
    > Norm
    What do you want to know about them? That's what you measure.
    Different applications emphasize different characteristics.
    Measuring one parameter may not imply the others are "good".
    mike
    Return address is VALID.
    Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
    Compaq Aero floppy,ram,battery.
    FT-212RH 2-meter 45W transceiver. 2-meter linear
    Toshiba & Compaq LiIon Batteries, Test Equipment
    30pS pulser, Tektronix Concept Books, spot welding head...
    mike, Aug 15, 2004
    #3
  4. Norm Dresner
    Norm Dresner Guest
    "mike" <> wrote in message news:...
    20,000 -
    > > TIA
    > > Norm
    > mike
    Okay, since I'm going to use them as filter caps in power supplies, I guess
    I need to know
    1. Capacitance
    2. ESR
    3. Inductance
    in that order of importance.
    Norm
    #4
  5. > Okay, since I'm going to use them as filter caps in power supplies, I
    guess
    > I need to know
    > 1. Capacitance
    > 2. ESR
    > 3. Inductance
    > Norm
    Hi Norm: How old are they and were they made by a known and reliable
    manufacturer? What happens to some of them is that they get a tad dry
    inside and lose much of their capacity. Others, although old, can be
    "reformed" by step charging them (start out at 1/4 of their voltage rating
    for 6 hours and then 1/2 for 6 hours and so on). After reforming and
    checking for leakage, a load test is in order. For example, how long can
    they supply the expected current (T = RC and 5RC is close to total discharge
    .... easy enough to measure). Last, but not least, can they deliver a peak
    current that satisfies a low internal resistance? Some folks use the
    screwdriver test for this but that can be daunting and even dangerous. ESR
    meters are available. Hope this helps.
    I ducked the inductance question since I don't think it is an issue in most
    power supplies.
    Charles Schuler, Aug 15, 2004
    #5
  6. Norm Dresner
    terry Guest
    "Charles Schuler" <> wrote in message
    news:D...
    > guess
    > > I need to know
    > > 1. Capacitance
    > > 2. ESR
    > > 3. Inductance
    > > Norm
    discharge
    ESR
    most
    > power supplies.
    A good way to measure ESR and ESL is to apply a voltage step with a waveform
    generator, and look closely at the rising edge. Assuming that the dominant
    time constant (Rpulse*C) is much larger than the timescale at which we
    examine the capacitor voltage, we will see the sum of: A voltage step =
    Vpulse*ESR/(ESR + Rpulse) and a voltage spike = ESL*dI/dt.
    If you terminate a 50R pulse generator into 5R = 10R//10R you get Rpulse =
    4.55R, Vpulse = Vunterminated/11 = 0.909V for my waveform generator. A cap
    with 36mOhm ESR would have an amplitude step of 0.909V*0.036/(0.036+4.55) =
    7.14mV.
    The inductance can be calculated from the spike that sits atop the ESR step,
    by measuring the area of the spike - but I lent someone my copy of "High
    Speed Digital Design" which details this method, and I cant recall how the
    trick works, but its pretty easy - you want a pulse generator with a pretty
    fast risetime though - faster than Rpulse*ESL - which for 10nH is about
    45ns. If you have a couple of smt inductors with a known low inductance
    (10nH, 47nH, 100nH) you can manually "calibrate" your test fixture.
    Cheers
    Terry
    terry, Aug 16, 2004
    #6
  7. Norm Dresner
    Norm Dresner Guest
    "terry" <> wrote in message
    news:SeTTc.13614$...
    waveform
    > 7.14mV.
    step,
    pretty
    > Cheers
    > Terry
    Thanks for the info. I'll check our library tomorrow for a copy of that
    book.
    Norm
    Norm Dresner, Aug 16, 2004
    #7
  8. "terry" <> wrote in message
    waveform
    > 7.14mV.
    step,
    pretty
    > Cheers
    > Terry
    Hey Terry,
    Sounds like we need a simple Cap_Driver box. BNC input, driven by pulse
    generator (5V, 1.0uS PW, 100uS RR), our favorite Zeltex PNP/NPN transistors,
    10uF MLC, 9V battery and on/off switch. BNC output for scope and pads for
    CUT (cap under test). Output R of driver trimmed to 0R50. Those transistors
    should pump +/- 10Amps, <10nS rise and fall. We could also check cables with
    this puppy. Call it a Z/100 box!
    Cheers
    Harry
    Harry Dellamano, Aug 16, 2004
    #8
  9. Harry Dellamano wrote...
    > terry wrote ...
    >> waveform generator, and look closely at the rising edge. Assuming that
    >> the dominant time constant (Rpulse*C) is much larger than the timescale
    >> at which we examine the capacitor voltage, we will see the sum of: A
    >> voltage step = Vpulse*ESR/(ESR + Rpulse) and a voltage spike = ESL*dI/dt.
    >> = 4.55R, Vpulse = Vunterminated/11 = 0.909V for my waveform generator.
    >> A cap with 36mOhm ESR would have an amplitude step of
    >> 0.909V*0.036/(0.036+4.55) = 7.14mV.
    >> step, by measuring the area of the spike - but I lent someone my copy of
    >> "High Speed Digital Design" which details this method, and I cant recall
    >> how the trick works, but its pretty easy - you want a pulse generator with
    >> a pretty fast risetime though - faster than Rpulse*ESL - which for 10nH is
    >> about 45ns. If you have a couple of smt inductors with a known low
    >> inductance (10nH, 47nH, 100nH) you can manually "calibrate" your test
    >> fixture.
    > Hey Terry,
    A post I made seven years ago yesterday, reposting an earlier post...
    Subject: Re: ESR of large caps?
    Date: 1997/08/15
    Message-ID: <5t2ba7$>#1/1
    References: <>
    Organization: Rowland Institute for Science
    Newsgroups: sci.electronics.design
    Kendall Castor-Perry says...
    > Will Rose writes
    >> Kendall Castor-Perry wrote:
    >>> Drive the cap through a 50R resistor from a nice chunky old oscillator
    > [snip]
    > input and across-cap signals on X and Y, scale them so they fit across
    > the screen properly, then do a Lissajous. Wind up the sensitivity to
    > 'open out' the small error gap; for any particular scale you're using...
    What's with all these 50 ohm or even 1k-ohm resistors, fellas? When
    I want to measure 0.01 ohms, etc. I want AMPS! not mA or uA of test
    current! For modestly interesting results I used a HIFI amplifier with
    a 2.5-ohm resistor. Several amp drive is a piece of cake! But for
    more useful capacitor data, I created the apparatus described below,
    which can achieve 0.0001-ohm resolution:
    Subject: Re: 0.01ohm impedance measurments ?
    Date: 1997/06/22
    Message-Id: <5okc44$>
    Newsgroups: sci.electronics.equipment
    Adam Craig Seychell said...
    > How can I measure impedances below 10 milli ohms at frequencies
    > of about 500kHz or less?
    I measure impedances to 0.01 milliohm by using a fast high-current
    pulse. Although it takes a little construction and setting up - as do
    all high-current measurements - it's actually quite easy to do. Note,
    this technique may damage devices which can't carry a high current for
    a short time, but such a device likely won't have milliohm impedances
    anyway!
    The concept is simply to force a 10 to 100 amp current step through
    the device and measure the voltage drop as a function of time. For a
    10A pulse with a known dI/dt (say 10A/us) the voltage step (lasting
    1us) is mostly due to the device inductance, L = v/(di/dt), then a
    lower voltage plateau reveals the series resistance, r = v/i, and
    finally an increasing voltage measures series capacitance,
    C = i/(dV/dt).
    The high current is supplied from a few large computer electrolytics
    (e.g. I used two 33,000uF 15V units in series - note that the C * esr
    figure-of-merit simply scales with physical size - select _large_
    capacitors!). First, a modest power supply charges the capacitors,
    then the cap's are used to charge an inductor with the help of a few
    high-current MOSFETs, turned on with a single-shot pulse generator.
    The pulse generator must supply a negative-going OFF-state discharge
    current so as to set a sub 1us current rise time (adjusted with Roff)
    in an avalanche diode, which steers the current to the device under
    test (D.U.T.).
    3 to 50 10 to 35V
    --- 100 --+--- uH ----+---- avalanche ----+
    + | | diode |
    computer D +------ scope probe
    capacitor --G D.U.T.
    | | S +------ gnd clip
    ----------+---------+-+-------------------+---- SCOPE chassis gnd
    200us etc -- Roff -- |
    pulse gen -------------+
    All the measurements are made with a scope probe with the groung clip,
    acting as a 4-terminal sensor. For example, 0.1m-ohm resolution
    implies a 10mV measurement capability (1/5 div with a 5mV/div range
    and a 10:1 scope probe) and a 10A current.
    This method easily measures the inductance and resistance of say,
    shunt resistors and high-current inductors, as well as the ESR,
    inductance and capacitance of big computer capacitors. Although these
    are time-domain measurements, for most purposes, the results are
    easily translated to the frequency domain.
    For my purposes, larger 100 to 500A current pulses from the same setup
    provided very useful data for avalanche breakdown investigations, but
    that's another story.
    ---------------------------- end quote -----------------------------
    inductance spike
    _ /
    flyback | |
    voltage | | due to dV/dt = i/C
    | | \ ______
    | |___,,,....-----'''''
    _____________ / v = iR due to ESR
    Here's the relevant waveform for the first 10us, before the current
    in the coil has fallen too much.
    Winfield Hill
    Cambridge, MA 02142
    - Win
    (email: use hill_at_rowland-dotties-org for now)
    Winfield Hill, Aug 16, 2004
    #9
  10. Winfield Hill wrote...
    > inductance spike
    > _ _/
    > flyback | |
    > | | \ ______
    > _____________ / _ _ \ v = iR due to ESR
    The height of the inductance spike about the esr voltage step is
    V = L di/dt, which means to measure L you need to know the di/dt
    of the high-current MOSFET switch. It's convenient to make the
    FET switch fast (but not too fast), and to give it a well-defined
    dI/dt by controlling the gate-voltage waveform. The di/di can be
    measured with a current probe.
    - Win
    #10
    1. Advertisements
Similar Threads
  1. Fritz Schlunder
    Re: Best way to blow up capacitors - constant current source?
    Fritz Schlunder, Jul 23, 2003, in forum: Electronic Design
    4,975
    Fritz Schlunder
    Jul 23, 2003
  2. Mark
    What is best way to check capacitors?
    Mark, Jul 20, 2004, in forum: Electronic Repair
    7
    2,196
    Bob Parker
    Jul 22, 2004
  3. eromlignod
    Best way to measure precise harmonics?
    eromlignod, Oct 18, 2007, in forum: Electronic Design
    61
    1,594
    JosephKK
    Oct 25, 2007
  4. Jamie Morken
    best capacitors for high ripple and large capacitance
    Jamie Morken, Apr 10, 2008, in forum: Electronic Design
    13
    850
    Jamie Morken
    Apr 11, 2008
  5. Ken Williams
    best way to measure current?
    Ken Williams, Jun 29, 2009, in forum: Misc Electronics
    3
    3,170
    Resqueline
    Jul 31, 2009
Loading...
