What to do when plastic becomes sticky?
Discussion in 'Electronic Equipment' started by Fred McKenzie, Dec 4, 2009.
  1. Over the years, I've had several pieces of equipment with plastic parts
    that have become sticky. The latest is the rubberized part of a Sears
    Craftsman High Temperature Infrared Thermometer. There is also the
    rubberized case of a Radio Shack HTX-200 Two Meter Handheld radio.
    Does anyone know of a treatment for these sticky surfaces?
    Fred
    #1
    1. Advertisements
  2. Rich Webb
    Rich Webb Guest
    Know? No, but a couple of ideas. A clear acrylic coating might work.
    Mask off the unaffected areas and airbrush on a light coat or two of
    Future acrylic. http://www.swannysmodels.com/TheCompleteFuture.html
    Or, just try rubbing the sticky sections with talc?
    Rich Webb Norfolk, VA
    Rich Webb, Dec 4, 2009
    #2
    1. Advertisements
  3. Boris Mohar
    Boris Mohar Guest
    >Fred
    Try vinegar. Let us know if it worked.
    Boris
    Boris Mohar, Dec 5, 2009
    #3
  4. In article <>,
    Robert Baer <> wrote:
    > Methinks the plastic is slowly decomposing - so no treatment will
    > stop the problem.
    Robert-
    That is what I was thinking. I was hoping there was some chemical that
    would "passivate" the decomposing plastic.
    I have some 100% Isopropyl Alcohol (fuel line water remover) that I'll
    try, just in case that works. If it does, I expect it will just be a
    matter of time before the remaining plastic starts to decompose.
    Fred
    Fred McKenzie, Dec 6, 2009
    #4
  5. In article <>,
    "robb" <> wrote:
    > i treated it to a bath in %91 Isopropyl alcohol and it disolved
    > and washed the sticky coating completely away exposing the hard
    > rubber or plastic under part.
    Robb-
    I liked the idea of using alcohol because it would probably not hurt the
    underlying plastic. I tried some Isopropyl Alcohol (fuel line water
    remover) on the Infrared Thermometer. Just as you said, it wiped away
    the sticky coating.
    I was surprised that the "rubberized" surface was actually a coating
    that had been painted onto the plastic. The alcohol acted as a paint
    remover. If I can disassemble the Two Meter Handheld radio's case, I'll
    give it a try as well. It is just too intricate to clean without
    getting sticky stuff inside the radio.
    Fred
    #5
  6. timetraveler
    timetraveler
    Jun 30, 2010
    Thanks for posting. I have a hairdryer whose plastic-covered handle was sticky. I tried soap, oil, and Goo-Gone. Nothing worked until I found this thread. I cleaned it with 70% isopropyl rubbing alcohol (because that's what I had) and no more sticky handle. I then applied the same treatment to the electric cord of my Kitchen Aide mixer that I thought for years was persistently gathering kitchen grease. No more sticky cord!
    timetraveler, Jun 30, 2010
    #6
    1. Advertisements
Similar Threads
  1. C.R.U.S.A.D.E.R Australia (TM)
    Mobile Phone EMF safety concerns becomes an Insurance risk for telcos
    C.R.U.S.A.D.E.R Australia (TM), May 3, 2005, in forum: Electronic Basics
    9
    1,004
    Richard the Dreaded Libertarian
    May 13, 2005
  2. Winfield Hill
    A five-part requirement becomes a 25-part purchase.
    Winfield Hill, Sep 30, 2005, in forum: Electronic Design
    5
    576
    Greg Neff
    Oct 4, 2005
  3. Anonymous
    4
    1,057
    Sofa Slug
    Jan 31, 2004
  4. jacker
    Orion 21S - screener becomes black
    jacker, Nov 2, 2004, in forum: Electronic Repair
    695
    Jerry Greenberg
    Nov 3, 2004
  5. Jason D.
    369
    Jason D.
    Aug 29, 2005
Loading...
Share This Page
