What is PPM with regards to crystal tolerances
Discussion in 'General Electronics' started by kean, Jun 22, 2004.
  1. kean
    kean Guest
    Looking at datasheets for crystals, they specify its tolerance as +/-
    100 PPM. What does PPM stand for and how do you calculate the
    tolerance of the crystal in terms of frequency?
    Kean
    kean, Jun 22, 2004
    #1
    1. Advertisements
  2. kean
    Art Guest
    Parts Per Million: General reference to tolerance of the crystal frequency.
    1.00 MHZ Xtal with +-1PPM would therefore be plus or minus 1 hertz to be
    within that specific tolerance.
    "kean" <> wrote in message
    news:...
    > Hi,
    > Thanks,
    > Kean
    Art, Jun 22, 2004
    #2
    1. Advertisements
  3. kean
    Externet Guest
    Hi Kean.
    PPM is parts per million.
    Is like percentage, but per million instead.
    On a ±100 ppM tolerance, means a 1 MHz crystal can be anywhere in the
    range of 999 900 Hertz to 1 000 100 Hertz.
    Miguel
    Externet, Jun 22, 2004
    #3
  4. kean
    Zorknob Guest
    (kean) wrote in message news:<>...
    > Hi,
    > Thanks,
    > Kean
    PPM = parts per million
    With a +/- 100ppm tolerance, a 1MHz crystal can range in frequency
    from 999,900Hz to 1,000,100Hz. Where the crystal oscillates within
    the range is primarly a function of temperature.
    Zorknob, Jun 22, 2004
    #4
  5. kean
    Rich Grise Guest
    news:...
    > Hi,
    100 PPM == 0.01%
    Cheers!
    Rich
    Rich Grise, Jun 23, 2004
    #5
  6. kean
    kean Guest
    "Rich Grise" <> wrote in message news:<UT5Cc.23892$>...
    > news:...
    > > Hi,
    > 100 PPM == 0.01%
    > Cheers!
    > Rich
    Okay!. Thanks a lot for the help guys.
    kean, Jun 23, 2004
    #6
  7. kean
    Robert Baer Guest
    kean wrote:
    > Hi,
    > Thanks,
    > Kean
    Be advised that 100ppm is crappy; a good RailRoad watch does better...
    Robert Baer, Jun 23, 2004
    #7
  8. "Rich Grise" <> wrote in message news:<UT5Cc.23892$>...
    > news:...
    > > Hi,
    > 100 PPM == 0.01%
    > Cheers!
    > Rich
    PPM can refer to the temperature coefficient as well, so in this case
    it's not just an absolute frequency error, but a variation with
    temperature.
    100ppm/degC will give you 0.01% change per degree C. A big change if
    you are working over a wide temperature range.
    Dave :)
    David L. Jones, Jun 27, 2004
    #8
    1. Advertisements
Similar Threads
  1. Rich Grise
    R-2R ladder tolerances?
    Rich Grise, Sep 3, 2004, in forum: Electronic Basics
    560
    Rich Grise
    Sep 3, 2004
  2. Jan Panteltje
    UARTS and oscilator tolerances made easy for PICs
    Jan Panteltje, Feb 12, 2004, in forum: Electronic Design
    7
    526
    Jan Panteltje
    Feb 13, 2004
  3. kean
    6
    633
    Bill Sloman
    Jun 13, 2004
  4. Michael
    13
    684
    Jim Yanik
    Apr 20, 2007
  5. paco-pop
    Hi guys, regards from Spain
    paco-pop, Nov 24, 2014, in forum: Introductions
    382
    paco-pop
    Nov 25, 2014
Loading...
