Weller WES51 soldering station problem?
Discussion in 'Electronic Basics' started by Bill Christens-Barry, Apr 7, 2004.
  1. Hi. I have a Weller WES51 soldering station, an adjustable
    temperature unit with a pencil iron (p/n PES51).
    Last time I used it several months ago, it worked fine.
    Usually, the light on front would stay green until the tip
    reached the dialed in temperature, at which point the light
    would start blinking green.
    Now, when I turn it on I don't get any heat at the tip, and
    the indicator light in front stays red. I'm trying to figure
    out why.
    The unit comes with a magnetic pencil-like thing that can be
    placeed near a spot on front of the main unit. This spot is
    labelled "ESD", so I guess this has something to do with
    electrostatic discharge. When I put the probe there, the
    indicator light first begins to blink in red, and then
    starts blinking green. I still don't get any heat.
    What's this all about? Is it a sign that the iron itself has
    failed? Is there an easy fix short of getting a new iron?
    And can anyone point me to an online (or hardcopy) version
    of the manual?
    Thanks.
    Wm A Christens-Barry, PhD
    Equipoise Imaging, LLC
    http://www.eqpi.net/eqpi/
    #1
    1. Advertisements
    > out why.
    > of the manual?
    > Thanks.
    It sounds like an open circuit hearing element of wiring to the
    heater.
    Do you have an ohm meter to check the heater resistance?
    John Popelish
    John Popelish, Apr 8, 2004
    #2
    1. Advertisements
  3. In article <>,
    > > out why.
    snip
    > heater.
    John,
    Thanks for the good idea. I'll try to check this, although I
    don't know which pair of the 5 probe leads are the actual
    heater. Also, I don't know what the resistance should be.
    Any data would be helpful, especially a contact for Weller.
    Bill Christens-Barry, Apr 8, 2004
    #3
  4. Bill Christens-Barry wrote:
    > In article <>,
    > > > out why.
    > snip
    > > heater.
    > John,
    If the heater is powered by something near 24 volts, the resistance is
    in the single digits. If powered by 120 Vac, then the resistance is
    in the hundreds of ohms. The thermistor pair should be in the kohms.
    One wire should be a short to the tip (safety ground). If you can get
    the case open, it should be pretty obvious which pins on the socket
    connect to what.
    John Popelish
    #4
  5. Bill Christens-Barry <> wrote in message news:<>...
    > out why.
    > of the manual?
    > Thanks.
    On the wes50 at least the pencil like magnet is used to set and lock
    the maximum temperature setting of the iron. It has nothing to do with
    esd, must be a magnetically sensitive device back behind that area.
    I cant find the manual or the magnet stick for my weller.
    Weller will probably send a manual if you write or email them and
    request one.
    cornytheclown, Apr 8, 2004
    #5
  6. In article <>,
    > connect to what.
    Thanks, John. This is just the kind of help I was hoping for
    Bill Christens-Barry, Apr 9, 2004
    #6
  7. In article
    > request one.
    Great - thanks for your help. Maybe I'm just locked @ 0
    degrees.
    #7
    1. Advertisements
Similar Threads
  1. Replies:
    5
    2,988
    Tim Wescott
    Sep 7, 2005
  2. Jim Stoll
    Weller WES51 vs Hakko 936-12
    Jim Stoll, Nov 17, 2003, in forum: Electronic Equipment
    2,077
    Walter Harley
    Nov 20, 2003
  3. Robert Meushaw
    Most useful tip to use with Weller soldering station WES50/51
    Robert Meushaw, Jan 27, 2004, in forum: Electronic Equipment
    889
    Michael A. Terrell
    Jan 27, 2004
  4. Jim Babcock
    repair Weller EC2001 soldering station?
    Jim Babcock, Mar 6, 2004, in forum: Electronic Equipment
    1,062
    BladeRunner
    Mar 6, 2004
  5. Z
    1,383
Loading...
