Washing Machine Power Cord Replacement - How do I remove cord grommet?
Discussion in 'Electronic Repair' started by Carol, Oct 19, 2003.
  1. Carol
    Carol Guest
    I am trying to replace the power cord on a Maytag Automatic Washer
    Model A8650. The original power cord got chewed and frayed. The
    original cord enters/exits the machine through a small hole in the
    bottom of the console. The hole has the power cord wire going through
    the center of it, surrounded by a black plastic "cord grommet". The
    cord fits extremely snug in the grommet - to the point where you
    cannot slide it in either direction through the grommet. I have
    already opened the control panel and disconnected the wires so the
    ends are free, but I can't get the old wire out of the machine because
    it is so tight through that grommet. So, either 1) How do I get the
    old cord out of the grommet? or 2) How do I get both the grommet and
    the cord out of the machine? The grommet looks like it should be able
    to be popped out somehow, but I can't figure it out.
    Carol
    Carol, Oct 19, 2003
    #1
    1. Advertisements
  2. Quadrajet1
    Quadrajet1 Guest
    << I am trying to replace the power cord on a Maytag Automatic Washer
    Carol >>
    Most grommets can be removed or installed by grabbing it with a pair of
    pliers and squeezing it and thereby making it smaller, and then it pops out of
    the hole. The grommet is two piece (well, sort of). There is a part that is U
    shaped, and a smaller part that fits in the top of the U that completes the
    grommet. The two pieces are usually held together with a thin piece. Squeeze
    the smaller part towards the center, and the grommet comes out.
    Raymond
    Quadrajet1, Oct 19, 2003
    #2
    1. Advertisements
    > Thanks,
    > Carol
    I've had good results with squeezing these with a pair of slip-joint pliers
    (that have the roughly oval-shaped opening between the jaws). You'll need
    to do this on the side that's smaller, typically the inside, and then
    while squeezing, start to move it through the hole. They're a bit of a
    PIA, but real common in all sorts of stuff...
    Roy J. Tellason, Oct 19, 2003
    #3
  4. Quadrajet1
    Quadrajet1 Guest
    << I've had good results with squeezing these with a pair of slip-joint pliers
    PIA, but real common in all sorts of stuff... >>
    I just remembered, I have a tool that's made specifically made for strain
    reliefs. It's a Heyco model 29. I bet it's at least 40 years old by now.
    #4
  5. JM
    JM Guest
    quoting:
    Squeeze the "cord grommet" with pliers.
    JM, Oct 20, 2003
    #5
    > pliers
    > strain reliefs. It's a Heyco model 29. I bet it's at least 40 years
    > old by now.
    A special tool made for those things? Wow. I've never actually seen such a
    thing...
    Now I've gotta go and add _that_ to my list! :)
    Roy J. Tellason, Oct 20, 2003
    #6
  7. Quadrajet1
    Quadrajet1 Guest
    >> old by now.
    >thing...
    Try:
    http://www.morimiya.co.jp/eng/products/haisen/bushass.html
    It's the model R-29 tool. It's just one of them tools I found at a swap meet
    for a buck or two.
    Raymond
    Quadrajet1, Oct 21, 2003
    #7
  8. uk-hamman
    uk-hamman Guest
    HI
    REFERENCE YOUR WASHING MACHINE PROBLEM
    the simplest thing to do is , is to cut the wire / lead
    very close to either side of the grommet
    then simply use a sharp screw-driver and push the last bit
    that remains through andnthen simply withdraw the grommet
    failing that if you cannot push it out with a screw-driver
    drill the cable out , again once you have cut the cable
    either side of the grommet , as close as you can .
    cheers for now .
    hope you have luck
    de Paul
    uk-hamman, Oct 27, 2003
    #8
  9. Asimov
    Asimov Guest
    Re: Washing Machine Power Cord Replacement - How do I remove cord gromm
    "uk-hamman" bravely wrote to "All" (27 Oct 03 11:13:11)
    --- on the heady topic of "Re: Washing Machine Power Cord Replacement - How do I remove cord gromm"
    There is a special tool for intalling and removing them but a miniature
    "vice-grips" needlenose pliars can be used in a pinch.
    uk> From: "uk-hamman" <>
    uk> HI
    uk> REFERENCE YOUR WASHING MACHINE PROBLEM
    uk> the simplest thing to do is , is to cut the wire / lead
    uk> very close to either side of the grommet
    uk> then simply use a sharp screw-driver and push the last bit
    uk> that remains through andnthen simply withdraw the grommet
    uk> failing that if you cannot push it out with a screw-driver
    uk> drill the cable out , again once you have cut the cable
    uk> either side of the grommet , as close as you can .
    uk> cheers for now .
    uk> hope you have luck
    uk> de Paul
    .... No electrons were harmed in the posting of this message.
    Asimov, Oct 29, 2003
    #9
    1. Advertisements
Similar Threads
  1. Malcolm Fowler
    Repair Power Module for washing machine
    Malcolm Fowler, Jul 5, 2004, in forum: Electronic Repair
    1,865
    budgie
    Jul 5, 2004
  2. Darren
    2000w inverter ok to power washing machine?
    Darren, Aug 4, 2004, in forum: Hobby Electronics
    4
    2,090
    Landline
    Aug 4, 2004
  3. CampinGazz
    washing machine, low power consumption
    CampinGazz, Feb 7, 2006, in forum: Photovoltaics
    2,021
    Anthony Matonak
    Feb 7, 2006
  4. deathbymissadventure
    Hammond organ power cord replacement help
    deathbymissadventure, Apr 20, 2010, in forum: Electronics Repair
    5
    1,955
    jerryg50
    Apr 21, 2010
  5. Jamie
    Looking for a 2 hole snap on wire grommet
    Jamie, Oct 2, 2012, in forum: Electronic Design
    5
    440
Loading...
Share This Page
