*Volt-Amps Turn Relationship
Discussion in 'Electronic Basics' started by Randy Gross, Apr 23, 2004.
  1. Randy Gross
    Randy Gross Guest
    Greetings,
    I'm having a little trouble developing a power supply to deliver 14 vac
    @ 10 amps. I modified a MOT to deliver 14 volts but, the primary (5
    amps) and secondary (41 amp) amperages are so high, I had to put a large
    Iron cored inductor in series with the sec. to reduce the 41 amps down
    to 10. The power supply dwarfs the original design perimeter. I need to
    design a tranny to deliver what I need in a smaller package. What I need
    to determine is the primary to secondary turns and core size to deliver
    14 vac @ 10 amps.
    I have formulas for determining/modifying the volt amps in an existing
    design and, I understand these. What I don't know is how to target a
    specific set of values and how the core is used to achieve them. If you
    know of a source of information, please direct me.
    I realize I could find and purchase a supply to fit this need but, what
    would I learn?
    Randy
    #1
    1. Advertisements
Similar Threads
  1. Randy Gross
    Randy Gross, Apr 23, 2004, in forum: Electronic Basics
    327
    Randy Gross
    Apr 23, 2004
  2. Randy Gross
    409
    Randy Gross
    Apr 23, 2004
  3. Randy Gross
    Volt Amp Turn Relationship
    380
    Randy Gross
    Apr 23, 2004
  4. Randy Gross
    Randy Gross, Apr 23, 2004, in forum: Electronic Design
    341
    Randy Gross
    Apr 23, 2004
  5. Ian Stirling
    Ian Stirling, Apr 22, 2004, in forum: Electronic Design
    17
    1,060
    R.Legg
    Apr 26, 2004
Loading...
