vlf transmitter, part II
Discussion in 'Electronic Repair' started by Albert, Mar 30, 2005.
  1. Albert
    Albert Guest
    This morning, I put my 17 Khz vlf transmitter (petsafe wireless fence)
    on spectrum lab running on my laptop. What I saw has put me in a
    tailspin.
    I have the schematic and the screen captures showing the output
    spectrum for anyone who wants to email me, aballen at colby dot edu.
    Using spectrum labs built in vlf receiver and a short antenna wire, I
    was able to display the output spectrum of the transmitter without any
    problems. BUT, I'm at a loss to explain the output spectrum.
    Around 18 Khz, there is a peak. Exactly 15 Hz below and above the peak
    is a smaller set of peaks, presumably these are the sidebands that the
    receiver recovers. BUT, there is a peak every 60 Hz that slowly gets
    weaker as the spectrum moves away from the (center) largest peak. Each
    one of these smaller peaks has upper and lower sidebands as well.
    There are many of these peaks, not just a few.
    I wish I could attach the gif's and the schematic diagram of the
    transmitter, but I think binary attachments are forbidden here.
    For those who didn't read the original post, here's a summary. I
    purchased a petsafe PIF-300 wireless fence to make an invisible fence
    to contain our dog. The unit has a 17 Khz transmitter that runs in the
    house from ac power. The small battery powered receiver is mounted on
    the dogs collar and gives an audible warning and a correction IF the
    dog tries to go past the transmitters range.
    The url for the product is at:
    http://www.petsafe.net/pet_containment/instant_fence.htm
    Here's my question...
    Why would they use a transmitter with such a wideband output and
    containing so many spurs? Is there any kind of simple receiver that
    can properly recover the transmitter data?
    As I said before, send me an email and I'll be happy to forward the
    schematic and the screen captures showing the output spectra.
    A
    #1
    1. Advertisements
  2. Albert
    Albert Guest
    The product is an Instafence (also called Instant Fence or wireless
    fence). The manual for the thing is available on petsafe.net, look for
    the PIF-300 product (which also includes the collar). It transmits a
    short range signal at 18.7 kilohertz using large air coils as
    antennas. It is designed to contain a dog within a 90 foot radius and
    to issue mild shocks if/when the pet attempts to leave the area. It
    does not work with a buried wire loop, it uses the transmitter to
    define the dogs play area.
    For anyone interested in purchasing one, they are horribly expensive
    (list price $280) and they have a special battery for the collar,
    which is only used by petsafe, available at 6 dollars each. The
    batteries don't last long. The range is only 90 feet, so it doesn't
    allow the pet to move very much.
    It appears to be grossly over-engineered as well, an ASIC feeds one
    each amplifier separately and the amps appear to run at very low
    power. No doubt a much cheaper transmitter could be made, this one is
    also physically large as well!
    For anyone interested in the petsafe IF100 vlf transmitter, you can
    look on www.petsafe.net for the manufacturers info-
    Or, check out pictures, schematic and field strength documentation at:
    https://gullfoss2.fcc.gov/cgi-bin/w...Exhibits&application_id=91640&fcc_id=KE3IF100
    Here are some notes based on my personal observations (before I
    returned the device).
    SW2 is hardwired, and is not adjustable as shown in the schematic. For
    some reason, this switch was called 'mode' back in 1998 when petsafe
    submitted the documentation to the FCC. The schematic shows it as a
    switch though. When looking at the schematic, the position of the
    switch in the schematic is shown correctly.
    Switching S3 to ground selects low power transmit.
    The pot, R33 is the power control.
    The ASIC is marked as follows:
    Supertex
    500-029
    204T770
    0225
    It is impossible to tell how many turns are on each loop (transmit
    antenna). But, each of the 4 loops has the same size wire and has a dc
    resistance of 4.5 ohms.
    Vdd for the ASIC is 4.85 volts.
    I have spectral output for each of the output lines (X, Y, Z). The
    spectral display shows the same signal on each output although the
    same output signal on all 3 output lines, although there are different
    peak amplitudes (some of the amp stages are driven harder than others,
    but all have the same basic input signals).
    There are 3 audio amp chips, they are each the LM 1875T. They can run
    20 watts output, but the output power is much lower than 20 watts for
    each stage. This is based on the V+ being very low (16.8v) and the
    observation that the 1.8A wall wart (at 14v ac) runs very cool. Also,
    although the heat sinks for each stage are very small, they are barely
    warm to the touch.
    If anyone wants to see the spectral output of the ASIC that feeds the
    amps, send me an emmail to:
    K Y 1 K at pivot dott nett.
    Enjoy,
    A
    Albert, Apr 5, 2005
    #2
    1. Advertisements
  3. NSM
    NSM Guest
    <Albert> wrote in message news:...
    Far more things than you can imagine are designed like this. On short runs
    it isn't cost effective to come up with an efficient design. Same applies to
    a lot of software!
    N
    NSM, Apr 6, 2005
    #3
  4. Albert
    Albert Guest
    Thanks N.
    Well, the audio amp chips might be cheaper than some chips that are
    less powerful. I know this happens sometimes.
    Also, the manufacturer attempts to get a somewhat circular (3D) power
    distribution so the orientation of the transmitter is non critical
    (and is a circle). So, three transmit stages might be necessary-I
    notice each stage has slightly different voltage gain, no doubt to try
    and achieve a circular coverage pattern. So, three stages might
    actually be necessary.
    But, ASIC's are very expensive to develop and this one doesn't seem to
    be doing much. Maybe it's cheaper to have an ASIC than to build a
    larger circuit board with discrete components?
    GL.
    A
    >a lot of software!
    Albert, Apr 6, 2005
    #4
  5. NSM
    NSM Guest
    "When you only have a hammer, everything looks like a nail".
    N
    NSM, Apr 6, 2005
    #5
    1. Advertisements
Similar Threads
  1. Michael
    anybody know of any VLF (3-30Khz) transcievers?
    Michael, Jul 7, 2004, in forum: Electronic Design
    13
    856
    John Woodgate
    Jul 7, 2004
  2. Steve Sands
    Need help with controlling VLF beam width
    Steve Sands, Oct 8, 2004, in forum: Electronic Design
    15
    491
    Country Loon
    Oct 12, 2004
  3. Albert
    vlf transmitter hop up?
    Albert, Mar 20, 2005, in forum: Electronic Design
    458
    Albert
    Mar 20, 2005
  4. Albert
    Albert, Mar 30, 2005, in forum: Electronic Design
    13
    834
  5. Roger Sterling
    VLF transmitter & antenna
    Roger Sterling, May 5, 2011, in forum: Electronic Projects
    6
    1,199
    MattyMatt
    May 9, 2011
Loading...
Share This Page
