Vista 20p installation problem
Discussion in 'Security Alarms' started by eric, May 22, 2005.
  1. eric
    eric Guest
    I have the panel set up on a table for testing before installing it in
    my home. I installed a window contact (Ademco PR-20451) to zone 2 with
    (2k resistor in series) and configured as follows.
    Zone type: Perimeter
    Partition: 1
    Report Code: 01-00
    Hardwire Type: Normally closed
    I get a fault on this zone all the time regardless of contact being
    open or close. I remove the resistor and everything works fine! What am
    I doing wrong here?
    I have zone 3 and 11 zone doubled.
    Zone 3 (3k resistor in series)
    zone 11 (6.2k resistor in series)
    Do these resistors act as the EOLR besides being used by the panel for
    zone identification?
    just for kicks I programed a window contact as zone type 9 for fire to
    see how the system would react. my keypads beep but the siren does NOT
    go off. Do I need to do anything to make the siren activate for fire
    alarms? would it be a steady alarm tone? I am using ademco Wave2.
    Many thanks in advance!!!
    eric, May 22, 2005
    #1
    1. Advertisements
  2. Frank Olson
    Frank Olson Guest
    "eric" <> wrote in message
    news:...
    > Partition: 1
    > Report Code: 01-00
    Don't set anything for report codes unless you want the panel to transmit a
    signal over the phone line. When you set "normally closed" you're telling
    the panel to ignore end-of-lines.
    > I doing wrong here?
    You've no doubt told the panel these zones are "normally closed" as well.
    I'd suggest you go back and read the manual. All the answers to your
    questions are in there.
    Frank Olson, May 22, 2005
    #2
    1. Advertisements
  3. eric
    eric Guest
    OK I set the panel for "EOL" and the contact with 2k resistor in series
    everything seems to work fine. When I short the loop or open the loop
    or open the contact, the keypad says fault in all cases. Do I expect
    the panel to say something like "short" or "open"?
    No for the zone double I set the panel to zone double. The was pretty
    straight forward. :)
    Unfortunately the manual is designed for a first time installer and
    assumes some prior knowledge. I can't seem to find why the fire does
    not activate siren.
    eric, May 22, 2005
    #3
  4. eric
    eric Guest
    Keypads are 6160v and 6270.
    eric, May 22, 2005
    #4
  5. > OK I set the panel for "EOL" and the contact with 2k resistor in series
    Nope. It's doing what it's supposed to do.
    > time installer and assumes some prior knowledge.
    That's pretty much the case across the board with alarm manuals. Give me a
    call Sunday afternoon if you like and I'll try to walk you through it. I'll
    be out flying in the morning; hope to be back by about 1:30pm.
    Regards,
    Robert L Bass
    Bass Home Electronics
    2291 Pine View Circle
    Sarasota · Florida · 34231
    877-722-8900 Sales & Tech Support
    http://www.bassburglaralarms.com
    Robert L. Bass, May 22, 2005
    #5
  6. Frank Olson
    Frank Olson Guest
    news:...
    Nope. It'll report "fault".
    You're learnin'... :))
    > not activate siren.
    Check your siren time outs and make sure you're getting voltage at the siren
    terminals. In all cases a "fire" will enable sounder.
    #6
  7. Robert L. Bass May 21, 10:23 pm show options
    Newsgroups: alt.security.alarms
    this author
    Date: Sat, 21 May 2005 22:23:50 -0400
    Local: Sat,May 21 2005 10:23 pm
    Subject: Re: Vista 20p installation problem
    Reply | Reply to Author | Forward | Print | Individual Message | Show
    original | Report Abuse
    series
    >Nope. It's doing what it's supposed to do.<
    And if Rojas didn't send you a programming CD you'd still think a loop
    was something from weaving class.
    me a
    I'll
    be out flying in the morning; hope to be back by about 1:30pm. <
    Yeah you'll be out flying alright. Flying down the highway to Kip's Big
    Boy for the all you can eat brunch special.
    Excuse me, who are you calling white? I'm PINK!
    Regards,
    Robert L Ass
    no wires showing, May 22, 2005
    #7
  8. eric
    eric Guest
    I programmed zone-1 as "Fire" but when I trip the zone the buzzers on
    the
    keypads go off and it says "fire trouble" but the Siren does not go
    off. The
    siren does work for other zones but not with zone-1. Fire siren Time
    outs is
    set to default. What's the problem?
    If I was to add more sirens can I put 2 or 3 sirens in parallel?
    Thanks!
    eric, May 22, 2005
    #8
  9. A.J.
    A.J. Guest
    Short zone #1 for alarm, open zone #1 for trouble.
    news:...
    > the
    > off. The
    > outs is
    > Thanks!
    A.J., May 22, 2005
    #9
  10. You either have the resistor in the wrong place or see AJ's comment on how to test fire zone.
    Yes you can wire more than 1 siren in parallel...provided they don't draw more current than the panel can provide in alarm.
    "eric" <> wrote in message news:...
    > the
    > off. The
    > outs is
    > Thanks!
    Crash Gordon®, May 22, 2005
    #10
  11. Frank Olson
    Frank Olson Guest
    news:...
    > the
    > off. The
    > outs is
    > Thanks!
    Most fire alarm devices are normally open. The panel has to see the end of
    line for a "normal" condition. Opening the circuit will cause the system to
    fault. Shorting the circuit *across* the end of line will cause it to go
    into alarm... The manual explains this.
    #11
  12. Jim
    Jim Guest
    series
    loop
    expect
    Give me a
    it. I'll
    Hmmmm .... Hey gas bag, you really should try to stay away from that
    effluvial causing food.
    Anyway, hope your mooring lines don't snag.
    > Regards,
    > Robert L Bass
    Jim, May 23, 2005
    #12
    1. Advertisements
Similar Threads
  1. john
    1,596
  2. Mike
    Programming problem on Vista 20P
    Mike, Apr 23, 2005, in forum: Security Alarms
    38
    7,393
    Robert L. Bass
    Apr 28, 2005
  3. Replies:
    14
    1,616
    GROUP MODERATOR
    Apr 17, 2007
  4. Brad Isaac
    Troubleshooting a Ademco Vista 20P Sensor problem?
    Brad Isaac, Sep 29, 2008, in forum: Security Alarms
    3,205
    Brad Isaac
    Sep 29, 2008
  5. JoeRaisin
    Re: Ademco Vista 20P or Vista 50P system?
    JoeRaisin, Nov 7, 2009, in forum: Security Alarms
    3
    2,789
    JoeRaisin
    Nov 9, 2009
Loading...
Share This Page
