vibrating coil gradiometer
Discussion in 'Electronic Design' started by George Herold, Oct 31, 2012.
  1. Hi all, first off I may never build this.
    At the moment I'm only thinking about it, with your 'most excellent'
    help.
    So from a thread started by Tim W. about frig magnets,
    I got onto measuring B field gradients,
    In particular the gradients, in the Earth's (~50uT ) field,
    on the order of 1 uT/m.
    Phil H started me thinking about wiggling a coil back and forth to
    measure the gradient.
    The emf will go as the field gradient, times the velocity, times the
    area of the coil.
    (** = ^ , 10**2 = 10^2 = 100)
    For a 1cm**2 coil at 1m/s that's 10**-10 V. kinda depressing.
    But I can add turns, increase area, (increase velocity?)
    (Can I shake something at 1m/s? non-magnetically.)
    To get to a microvolt I need a 10**4 increase.
    1000 turns and 10cm**2 or 100 turns and 100 cm**2?
    (or something else)
    I also think the coil will have to sit in a thick walled (aluminum?)
    shield
    that will keep out the AC magnetic fields at (and above) the shake
    frequency,
    but allow the DC field gradients through. So a higher frequencies
    will mean a thinner shield. (my total cost of 'gizmo' ~$100-200)
    (How many skin depths will I need?)
    And then how do I wiggle it? I'm thinking a coil on the end of a long
    I-Beam.
    Maybe I can drive it resonantly with a 'upstream' peizo?
    I'm looking for some crazy ideas (or maybe this just doesn't work.)
    George H.
    #1
    1. Advertisements
  2. George Herold
    Robert Macy Guest
    > help.
    > area of the coil.
    > (or something else)
    > shield
    > frequency,
    > I-Beam.
    > George H.
    When working with magnetic fields, remember they are LOW impedance.
    Take advantage of that. It's not like you're making a voltmeter that
    must have high impedance.
    You could try 'chopping' Earth's DC field by using a spinning loop
    coupled to a 'slip ring' transformer for non-contact transfer of
    signal. [make the loop AND the coupling transformer, use air core]
    Spin the loop at some 'proper' harmonic that is synchronous to AC
    mains.
    Speed of the spin determines the number of turns and knowing the
    spinning speed you can synchronously detect the signal and really
    lower the noise floor. maybe a cheap optical coupler/interrupter [take
    apart an old mouse] as the loop is spun to provide the sampling pulse.
    To analyze what's going on in the fields, get a copy of femm 4.2 If
    you need help to start on the learning curve, let me know.
    PS: Circa 1989, I made a portable 4 inch diameter AC magnetometer,
    that had a 'flat' sensitivity of 1V per uT over spectrum from 5 Hz to
    1MHz.[max 2uT] Gently rocking the meter would peg the output as it
    moved through that 50uT field. The noise floor was in the range of 5nT
    [on a scope the output signal was a crisp line and not thickened by
    noise] and you could 'see' vehicles go by on the street adjacent to
    our lab as the metal deflected the Earth's field.
    Robert Macy, Oct 31, 2012
    #2
    1. Advertisements
  3. On Oct 30, 10:24 pm, "Vladimir Vassilevsky" <>
    wrote:
    > "George Herold" <> wrote in message
    > news:...
    > > help.
    > That's very simple. Strong field, no problem at all.
    > Not a good idea.
    > http://www.magneticsensors.com/
    > Use GMR sensor ICs from Honeywell. With two sensors, few analog parts and
    > proper callibration, you will be able to resolve the gradients at the order
    > of 0.001 of the Earth field. GMR is as simple as it gets; there are of
    > course better sensors and technologies.
    Oh, those might work, thanks (HMC1001, HMC1002) they're not GMR
    though, but some Anisotropic MagnetoResistive (AMR) technology. Not
    cheap (~$15 each) Or were you suggesting a different sensor?
    We've got some hall sensors from Allegro (A1324), but they are way too
    noisy.
    George H.
    > DSP and Mixed Signal Consultantwww.abvolt.com
    #3
    > > help.
    > > area of the coil.
    > > (or something else)
    > > shield
    > > frequency,
    > > I-Beam.
    > > George H.
    > mains.
    > our lab as the metal deflected the Earth's field.- Hide quoted text -
    > - Show quoted text -
    Hi Robert, thanks for that. I bet your 1989 magnetometer cost more
    than a few hundred dollars.
    A colleague has done the field gradient measurment, by weighting a
    permenant magnet. (First with the magnetic moment pointing up and
    then down.) He claims that a gradient of 1uT/m gives a weight
    difference of ~ 1 milli gram (out of a 100 gram magnet) Which can be
    done with some of these cheap balances. This doesn't give all the
    components of the gradient, but it might be enough.
    George H.
    #4
  5. George Herold
    Guest
    > help.
    > area of the coil.
    > (or something else)
    > shield
    > frequency,
    > I-Beam.
    > George H.
    http://en.wikipedia.org/wiki/Earth's_field_NMR
    -Lasse
    , Oct 31, 2012
    #5
    > > help.
    > > area of the coil.
    > > (or something else)
    > > shield
    > > frequency,
    > > I-Beam.
    > > George H.
    > -Lasse- Hide quoted text -
    Grin, Thanks Lasse, I'd like the gradiometer so our users would know
    where NOT to put this,
    http://www.teachspin.com/instruments/efnmr/index.shtml
    George H.
    #6
    > There is really no problem to measure weak magnetic fields. The problem is
    > to measure weak gradients on the background of uniform but strong magnetic
    > field of the Earth. What your colleague measured is probably caused by
    > misalignment of the magnet axis wrt Earth magnetic field. So the magnet
    > essentially acted like a compass. Compassing is common problem for all
    > mechanical magnetic gizmos,
    > so sensitivity to gradient is limited by mechanical misalignment.
    Hi Vlad, I hope it's OK if I disagree with you. There is certainly
    misalignment between the B field and magnetic moment. But a uniform B
    field can only cause a torque on the magnet. (So there is certainly
    some 'compassing' when one is weighing the magnet, but that pushes
    down more on one side and less on the other... no net force.) The
    force on the magnet is caused by the gradient in the field. You can
    see this pretty easily with a spring, magnet and rather strong field
    gradients.
    http://www.teachspin.com/instruments/magnetic_force/experiments.shtml
    Figure 2 down the bottom of the page is for a single coil, along the
    axis. It's fun to write down the field as a function of z,
    differentiate to get dB/dz and then see how that fits the data.
    (I've ordered some of the honeywell sensors, it be great to be able to
    measure both the field and the gradient... but it's a bit of a pain
    getting two sensors zero'd I've got a little mu metal tube that is
    maybe close to zero field inside.)
    George H.
    #7
  8. George Herold
    Fred Bartoli Guest
    >>> help.
    >>> area of the coil.
    >>> (or something else)
    >>> shield
    >>> frequency,
    >>> I-Beam.
    >>> George H.
    > George H.
    One way to do rotating coil would be with two coils:
    One fixed and external one to sense the varying field and the other one
    being a rotating short circuited ring.
    The rotating ring will see an induced emf=w.B.s.sin(theta) which shorted
    will induce a current in the loop, which in turn will produce a rotating
    B component, which will be sensed by the enclosing sense coil.
    I did not run the figures, you know how to do that, so I don't know if
    the figures are practical or not.
    A gradiometer could be build from this with two rotating rings and one
    big enclosing coil, with turns in one sense for half its length, then
    the same turns count in the other sense for the second half length.
    You sense the field gradient emf across the whole coil...
    Lock-ins should give you more than enough sensitivity, but again I did
    not run the figures.
    Fred.
    Fred Bartoli, Oct 31, 2012
    #8
  9. On Oct 31, 7:37 pm, Fred Bartoli <" "> wrote:
    > George Herold a crit :
    > >>> help.
    > >>> area of the coil.
    > >>> (or something else)
    > >>> shield
    > >>> frequency,
    > >>> I-Beam.
    > >>> George H.
    > > George H.
    Wow! I think I see it. Does this really work? (I get baffled by
    changing B fields sometimes.)
    I'll have to put some real numbers in for the rotating coil (wire size/
    resistance). If I'm not mistaken, it will be the current in the
    rotating coil that I need to calculate.
    Cute, but maybe instead of changing the 'sign' of the stationary sense
    coil, I could have the rotating coils wired in the opposite
    direction.
    (Still the rotating coils are going to have to be pretty well
    matched.)
    > Thanks,
    > Fred.- Hide quoted text -
    OK here's another idea.
    I was thinking about using Vlad's field sensing chips to measure the
    gradient.
    If I use two of them, the problem is always getting them 'matched'.
    So how about if I just shake one chip around and look at the AC signal
    at the shake frequency? I'll want to keep it nice and 'flat' as I
    shake it. It's not clear to me if unintended rotations (as I shake
    it) will give signals at f or 2f....
    (Hmm looks like f unless I get pointed along the field direction)
    George H.
    George Herold, Nov 1, 2012
    #9
  10. George Herold
    Fred Bartoli Guest
    That one is easy...
    The interesting one is the total flux seen by the enclosing coil which
    is, well... better measured I think :)
    > direction.
    Wired in the opposite direction? I'd sure be interested to have a
    picture of this: just look at what it is with the one turn coils :)
    I also think that rotating them in opposite direction won't make a
    difference.
    > matched.)
    One turn rings lathed from copper tubing?
    >> Thanks,
    > gradient.
    > George H.
    Fred.
    Fred Bartoli, Nov 1, 2012
    #10
  11. George Herold
    Robert Macy Guest
    On Oct 31, 9:45 am, George Herold <> wrote:
    > ...snip...
    > George H.
    Don't tell the customers, more like $24 Copper is EXPENSIVE! I even
    got away with cannibalizing a cheap meter to mount it on, so I didn't
    have to spring $$ for a display..
    Weight difference? I wonder if that could be done using MEMS?
    Combine with stress sensor and voila!
    Robert Macy, Nov 1, 2012
    #11
    > That one is easy...
    OK I'm still trying to get my head around how this works. But I think
    I'm starting to see it. Even if this isn't used to measure field
    gradients it might be fun to build one and see it work. "I'm not as
    smart as other's and it's nice to have some data to help guide my
    thinking"*
    > > direction.
    Yeah, sorry about that. Sticking my foot in my mouth again.
    (But I have no shame and will certainly do it again.)
    > difference.
    > > matched.)
    Do I gain anything by having multiple turns? If not then how about a
    copper disk?
    I was first thinking I wanted the stationary pickup coil with it's
    axis along the field direction, but now I'm thinking it needs to be at
    right angles?
    And thanks for the 'crazy' idea Fred.
    Do you know if this has ever been made?
    George H.
    > >> Thanks,
    > > gradient.
    > > George H.
    > Thanks,
    #12
  13. On Oct 31, 10:11 pm, "Vladimir Vassilevsky" <>
    > > gradient.
    > Use a PIC. Match the sensors digitally. That works very well; to the
    > accuracy limited by self noise.
    OK then I've got to calibrate each sensor separately. And then worry
    about DC offset drift with temperature. I'm not saying it's not
    possible.....but I need to measure differences of ~1-2 parts per
    thousand in the field.
    > Unintended rotations will result in compassing.
    It's worse than that, it gives me a signal. Roughly proportional to
    the rotation angle. One good thing about vibrating the sensor is that
    it moves the signal up in frequency, away from all the 1/f crud.
    George H.
    #13
  14. George Herold
    whit3rd Guest
    It doesn't take a zero-field region to make the adjustment; just
    a way to reverse the sensor orientation, and make sure if
    it reads +0.457 gauss at zero degrees, it reads -0.457 gauss
    at 180 degrees.
    Nonmagnetic materials are important, too; switches, resistor leads,
    nuts 'n bolts, all will have to be degaussed if they are near the sensor.
    whit3rd, Nov 1, 2012
    #14
    > at 180 degrees.
    Hi whit3rd, I've done that for a rough zero. Plenty good most of the
    time when I only care about the field to a few percent or so. But I'm
    contemplating a gradient measurement. I'd like to measure the
    gradient over a length about equal to the sample size ~10 cm. And I
    need to measure the gradients at the ~ 1uT/m (10mG/m... 1mG/10cm)
    level. So something better than 1 mG. Now flipping over is fine...
    (as long as you think carefully about how it's flipped) But a further
    issue is that the field in the old building that I work in jumps
    around at the few mG level... kinda randomly as elevators and fork
    lifts move around. (I guess I could take the sensors to my house in
    the country for zero adjustment.... then one worries about temperature
    changes...) Anyway the mu-metal tube reduces the effects of a
    changing local field.
    Yeah been there, all the brass bolts are screened for magnetic
    effects beofre being used in the 'non-magnetic' instuments. (Old
    carbon comp resistors are non-magnetic BTW)
    George H.
    #15
  16. George Herold
    Fred Bartoli Guest
    >> That one is easy...
    > thinking"*
    >>> direction.
    >> difference.
    >>> matched.)
    > copper disk?
    I didn't think of copper disks but it should work. Anyway field
    calculations aren't trivial anymore...
    That and multi-turns might be a win... or not:
    Emf goes with the number of turns. Then :
    1) as well as the resistance (for a constant wire gauge). Thus current
    is constant with turns and the generated field goes with the number of
    turns.
    2) Now if you only have a defined section to wind your coil, it is
    another matter as the total resistance goes with turns squared, then the
    generated field stays constant.
    > right angles?
    Say you have an X,Y,Z orthonormal axis system
    Your pick up coil will have a Z axis.
    Then draw your "chopping" coil in the X-Y plane and have it rotating on,
    say X axis. That way you'll have generate a rotating field in the Y-Z
    plane (well for the loop on axis component).
    Now you just keep the Z axis component of that for the pick up coil...
    No, I just dreamed that up. Hey, if you patent it, put my name on it :)
    Ooops, to late...
    Fred.
    #16
    > >> > gradient.
    > >  And then worry about DC offset drift with temperature.
    > You just have to match one sensor against the other in the uniform field.
    Ahh where am I getting this uniform field? I'd like to sell this to
    users so they can find a (roughly) uniform field region in their
    building.
    > >I'm not saying it's not possible.....but I need to measure differences of
    > >~1-2 parts per
    > Done that. It isn't very difficult.
    > >the rotation angle.
    > That's why I prefer digital correction. Linear and nonlinear effects could
    > be taken care off.
    > IIRC those NMR sensors generate fairly uniform noise; at least the ones I
    > tried.
    Hmm, I wonder if we are talking about the same sensors. HMC1001 or
    (HMC10xx)?
    http://www51.honeywell.com/aero/com...itions/HMC_1001-1002-1021-1022_Data_Sheet.pdf
    (Or if that's too long find them at digikey)
    The high sensitivity ones (HMC1001) have a gain that varies from 2.4
    to 4.0 mV/V/G
    and a sensitivity tempco of ~0.3%/C... (much less with a current
    drive, which I don't quite get.)
    So matching two of these across B and T to the 0.1% level looks like a
    lot of work.
    I still like the idea of wiggling one back and forth. That seems to
    get rid of all this 'common mode' crap, and just give me the
    difference that I want. But I'm not sure how to wiggle it 10 cm and
    keep it flat.
    (ohh there's a noise graph (for the less sensitive flavor) on page 4,
    1/f corner at ~100Hz.)
    George H.
    #17
    > >>> Wow!  I think I see it.  Does this really work?  (I get baffledby
    > >> That one is easy...
    > > thinking"*
    > >>> direction.
    > >> difference.
    > >>> matched.)
    > > copper disk?
    Geesh you're no help at all. :^)
    > turns.
    > > right angles?
    OK I'll have to try and mock something up. I've got a copper disk on
    a stick, but spinning it with a power drill was a no-go. (As you
    might have guessed the power drill spits out all sorts of B field
    stuff.)
    > Ooops, to late...
    We can't afford to patent anything.
    George H.
    > Thanks,
    #18
  19. George Herold
    Fred Bartoli Guest
    >>>> That one is easy...
    >>> thinking"*
    >>>>> direction.
    >>>> difference.
    >>>>> matched.)
    >>> copper disk?
    >> turns.
    >>> right angles?
    > stuff.)
    BTW it occurred to me that the picked up voltage should be at 2 times
    the rotating frequency, so you'll have to lock on 2nd harmonic.
    >> Ooops, to late...
    Was joking, of course :)
    Fred.
    #19
    > >>>>>> The rotating ring will see an induced emf=w.B.s.sin(theta) whichshorted
    > >>>> That one is easy...
    > >>> thinking"*
    > >>>>>> A gradiometer could be build from this with two rotating rings andone
    > >>>>> direction.
    > >>>> difference.
    > >>>>> matched.)
    > >>> Do I gain anything by having multiple turns?  If not then how abouta
    > >>> copper disk?
    > >> turns.
    > >>> right angles?
    > > stuff.)
    Good I somehow had the same picture.
    George H.
    > >> Ooops, to late...
    > Thanks,
    #20
    1. Advertisements
Similar Threads
  1. Quack
    Re: Vibrating alert
    Quack, Jul 2, 2003, in forum: General Electronics
    3
    1,894
    DesignElect
    Jul 8, 2003
  2. Vibrating device in cellphones
    , Aug 23, 2005, in forum: Electronic Design
    3
    513
  3. KSS240A lens vibrating
    , Oct 25, 2005, in forum: Electronic Repair
    11
    2,842
    nathanjh13
    Jul 7, 2010
  4. Microwave buzzing a vibrating
    , Feb 26, 2006, in forum: Electronic Repair
    22
    1,444
    Seafarer
    Mar 2, 2006
  5. Hong Chin Siong
    Digital monitor image vibrating sideways
    Hong Chin Siong, Feb 2, 2007, in forum: Electronic Repair
    6
    479
    Siciliano
    Feb 9, 2007
Loading...
