vga to ethernet converter
Discussion in 'Electronic Design' started by Rune Christensen, Sep 1, 2004.
  1. Hello
    Does anyone know if it's possible to build a VGA to ethernet converter? A
    device that converts a VGA signal to a digital videostream.
    I want to be able to operate a computer from a remote position also when the
    computer boots. So I will be able to change bios settings, starting mode of
    Windows, etc.
    Rune
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.746 / Virus Database: 498 - Release Date: 31-08-2004
    #1
    1. Advertisements
  2. Rune Christensen wrote:
    > Hello
    > Windows, etc.
    That is inlikely possible. Especially when I consider the high
    analog bandwidth required for comfortable viewing.
    At 1600x1200 with 24bit colors, the bandwidth is in the order of
    350MHz per color.
    Rene
    Ing.Buero R.Tschaggelar - http://www.ibrtses.com
    & commercial newsgroups - http://www.talkto.net
    Rene Tschaggelar, Sep 1, 2004
    #2
    1. Advertisements
  3. Iwo Mergler
    Iwo Mergler Guest
    > Hello
    > Windows, etc.
    > Thanks
    > Rune
    Yes it is possible.
    As Rune pointed out, the easy approach is most likely
    unsuccessful, as the bandwidth of a video signal may
    well be several hundred MHz.
    If I had to design such a beast, I would start with
    a frame grabber, similar to the innards of a LCD monitor.
    I would then compress the video stream for transmission
    via Ethernet.
    For simple applications (BIOS, simple GUI, etc.), a differential
    encoding or simply a reduced frame rate would be sufficient.
    A 10MBit/s ethernet link could reliably transmit about one
    640x480x24 frame per second.
    For complex GUIs / moving pictures, you may have to use a
    real compression algorithm, maybe MPEG2.
    Kind regards,
    Iwo
    Iwo Mergler, Sep 1, 2004
    #3
  4. Rune Christensen wrote:
    > Hello
    > Windows, etc.
    Does it have to be Windows? There are ways to do this if you can access
    bios and/or the o/s via a serial console. Not possible with Windows
    AFAIK.
    Paul Hovnanian mailto:p
    note to spammers: a Washington State resident
    Hit any user to continue.
    Paul Hovnanian P.E., Sep 1, 2004
    #4
  5. Ian
    Ian Guest
    >Windows, etc.
    Some "server management" cards do just this. Needs to either snoop the bus for VGA
    accesses or fully emulate a VGA adapter (i.e. they /are/ the VGA adapter for the
    machine). Quite expensive to buy, quite hard to make...
    Ian
    'Milk below!'
    Ian, Sep 1, 2004
    #5
  6. Ken Taylor
    Ken Taylor Guest
    "Rune Christensen" <> wrote in message
    news:4135a614$0$271$...
    > Hello
    the
    of
    > Windows, etc.
    > Thanks
    > Rune
    Do you actually need to change BIOS settings remotely as well? Programs such
    as VNC allow you to remotely take control of the PC, which also gets over
    the keyboard/mouse interface that your VGA-Ethernet converter forgets. Only
    applies once the OS is up and running though, hence the BIOS question.
    Ken
    Ken Taylor, Sep 1, 2004
    #6
  7. Richard
    Richard Guest
    > ethernet converter?
    http://www.avocent.com/ - KVM over IP $$$
    If Ethernet / IP aren't required, there are Cat-5 KVM extenders for <$1K
    that will run 500 feet. See Raritan or Avocent for these as well.
    Richard, Sep 2, 2004
    #7
  8. Tim Shoppa
    Tim Shoppa Guest
    "Rune Christensen" <> wrote in message news:<4135a614$0$271$>...
    > Windows, etc.
    It's not really Ethernet, but there are companies that sell
    adapters that let you run VGA signals over CAT-5 cable for distances
    of hundreds/thousands of feet. There's a converter box at one end,
    and another converter box at the other end.
    For example
    http://www.compuplus.com/insidepage.php3?id=1000872
    If anyone wants to spill the beans on what's inside these, I'm curious.
    I would guess that of the 4 CAT-5 pairs, three are for R, G, and B, and
    the fourth pair is used to carry sync info. But maybe it's much more
    complicated? Or maybe it's just 3 single-ended-analog-to-differential
    converters on one end and termination and differential-to-single-ended
    conversion on the other for RGB? You could convert the H&V syncs to any
    number of intermediate signals on their way to the other end... that's
    "just" 2 digital lines.
    Tim.
    Tim Shoppa, Sep 2, 2004
    #8
  9. "Ian"
    <${send-direct-email-to-news1021-at-jusme-dot-com-if-you-must}@jusme.com>
    skrev i en meddelelse news:Q0qZc.555637$...
    the
    of
    > >Windows, etc.
    for VGA
    for the
    > Ian
    > 'Milk below!'
    I think that this must the easiest solution to the problem. Create a VGA
    card that transfer the screen to ethernet instead of a screen. Maybe a PCI
    FPGA card could be used to do this.
    To the people on comp.arch.fpga have anyone tried to create a VGA card on a
    PCI FPGA card?
    Rune Christensen
    Rune Christensen, Sep 3, 2004
    #9
  10. Ian Stirling
    Ian Stirling Guest
    > Hello
    > Windows, etc.
    Devices to do this are readily available.
    Just google for network webcams.
    Ian Stirling, Sep 3, 2004
    #10
  11. Zak
    Zak Guest
    >>Windows, etc.
    Or google for "KVM over IP". IBM and HP have servers that can do this
    via an internal management card.
    Thomas
    Zak, Sep 3, 2004
    #11
  12. INS122595
    INS122595 Guest
    We done similar projects, the critical point is if many VGA standard need be
    supported
    Walter
    "Rune Christensen" <> a écrit dans le message de
    news:41384139$0$195$...
    > "Ian"
    A
    when
    > the
    mode
    > of
    > > >Windows, etc.
    bus
    > for VGA
    > for the
    > > Ian
    > > 'Milk below!'
    a
    > PCI FPGA card?
    > Thanks
    > Rune Christensen
    INS122595, Sep 5, 2004
    #12
  13. Andrew Dyer
    Andrew Dyer Guest
    > the
    > of
    >> >Windows, etc.
    some 'server' type computers have a BIOS that will allow you to do
    the basics over a serial port. After the computer comes up you
    can run something like windows' RDP or VNC for a remote desktop.
    > for VGA
    > for the
    >> Ian
    >> 'Milk below!'
    > PCI FPGA card?
    This isn't all that simple - assume your video stream is
    800x600x8bits per pixel x 60 hz (~230 mbits/sec). To make it
    work, you'll have to run gigabit ethernet, drop bits or frames,
    compress or some mixture of these.
    Next problem is how to get at the screen data - you could implement a
    whole vga subsystem (don't forget BIOS and drivers), snoop the PCI bus
    (need to track the state of a real vga chip which can be tricky), get a
    digital copy of the VGA output data (not all vga chips have digital out)
    or recapture the data from an analog copy (probably don't have access to
    the pixel clock, so you need PLLs to recapture the data).
    Andrew Dyer, Sep 6, 2004
    #13
  14. Hi Rune,
    There are products that do what you need , I think that they just
    modulate-demodulate the analog signals and they also use analog
    signals to comunicate between transmiter-receiver.
    Please check the following links:
    http://www.svideo.com/avbalun12.html
    http://www.svideo.com/videobalun1.html
    Regards,
    Viron Papadopoulos.
    > Hello
    > Windows, etc.
    > Thanks
    > Rune
    Viron Papadopoulos, Sep 6, 2004
    #14
  15. Tim Shoppa
    Tim Shoppa Guest
    Chuck Wozniak <> wrote in message news:<>...
    > Intersil makes some ICs for doing this. Full schematic in PDF format at:
    > http://www.intersil.com/data/rd/el4543/vga_transmission.pdf
    Ah, not too far from what I thought. Although I am surprised at how
    they only use 3 of the 4 pairs, and use a funky encoding of common
    mode voltages on the red, green, and blue pairs to send the sync.
    I suppose that the sync really is sent differentially, in sort-of a
    three-phase way. They claim this reduces EMI, they're probably right but
    I've never analyzed this situation before.
    Maybe the fourth pair is reserved for a back-channel (mouse, keyboard) by
    some applications?
    Tim.
    Tim Shoppa, Sep 8, 2004
    #15
    1. Advertisements
Similar Threads
  1. Dan
    line of sight to ethernet converter
    Dan, Jan 20, 2004, in forum: Electronic Design
    5
    527
  2. Johan Karremans
    Converter RS232 to VGA
    Johan Karremans, Nov 11, 2004, in forum: Electronic Design
    4
    13,536
    USB Geek
    Jan 22, 2010
  3. VGA to NTSC/PAL converter
    , Sep 14, 2005, in forum: Electronic Design
    4
    863
    Richard Crowley
    Sep 14, 2005
  4. James O'Donnell
    s-video to vga converter
    James O'Donnell, Dec 13, 2004, in forum: Electronic Repair
    608
    FoulDragon
    Dec 15, 2004
  5. xertechx
    VGA over Ethernet problems
    xertechx, Dec 3, 2010, in forum: Circuit Help
    4
    1,094
    xertechx
    Dec 3, 2010
Loading...
Share This Page
