Veritas 8C - needs a complete reset.
Discussion in 'Security Alarms' started by rolf@it-buy.co.uk, Nov 24, 2005.
  1. Guest
    Hi all,
    Excuse my ignorance but I dont know much about alarms having never
    installed one. Ive moved into a new house and there is a veritas 8c
    alarm on the wall. When I went to view the house the alarm wasnt set,
    when I moved in it went off! The estate agent doesnt seem capable of
    getting the code from the vendor and Ive been waiting 2 weeks now with
    a beeping alarm.
    Is it possible to drain the power on the NVM or to reset the panal back
    to the default settings and enter my own user code..? Its only a DIY
    installation.
    Cheers
    Rolf
    , Nov 24, 2005
    #1
    1. Advertisements
  2. Paul Ekins Guest
    <> wrote in message
    news:...
    > Hi all,
    > a beeping alarm.
    > installation.
    > Cheers
    > Rolf
    Yes it is possible to reset to factory default, but as there are different
    versions of this panel and it will need reprogramming after defaulting, I
    would advise you get a local installer / engineer to do this for you.
    Paul Ekins
    www.lincsecure.co.uk
    Paul Ekins, Nov 24, 2005
    #2
    1. Advertisements
  3. Guest
    Thanks for the help..I'm hoping I can reprogram it myself..its quite a
    small setup and I have managed to get the installation manual which has
    lots of help and clear guidence except for the question of resetting
    the panel! Its a veritas 8 compact.
    Im still hoping that the estate agent will come good with the code and
    resetting it is a last resort and if it goes wrong I can then get an
    alarm guru out to reprogram it.
    So if anyone can provide the reset sequence I'd appreciate it.
    Rolf
    , Nov 24, 2005
    #3
  4. Guest
    The installation manual does state this;
    "If the Engineer code has been lost, provided it has not been locked
    (section 3.2.2,
    page 21) power down the system (mains and battery). Restore power. All
    the
    indicator lights will illuminate for 10 seconds. Press RESET or SLOWLY
    press and
    release the panel lid tamper spring 3 times, before the indicator
    lights turn off. The
    factory settings have now been re-loaded into the Non Volatile Memory."
    But doesnt mention if this resets the user key code as well..I just
    want my alarm to stop beeping =)
    Rolf
    , Nov 24, 2005
    #4
  5. Guest
    Incidentally Im still hopeful the estate agent will come good with the
    code, but if not I'll reset it as a last resort and then if it all goes
    horribly wrong I can get an alarm guru in to reprogram it.
    Cheers
    Rolf
    , Nov 24, 2005
    #5
  6. R.H.Campbell Guest
    It sounds like this is the way to do a factory reset. If the installer code
    has not been locked, it will come back in it's factory fresh programming
    mode with the factory default user and installer code. If the board is
    "locked", you're board is "toast". You'll have to contact J. Rojas on this
    ng and he can assist in unlocking it for you.
    RHC
    <> wrote in message
    news:...
    > (section 3.2.2,
    > the
    > press and
    > Thanks
    > Rolf
    I choose Polesoft Lockspam to fight spam, and you?
    http://www.polesoft.com/refer.html
    R.H.Campbell, Nov 24, 2005
    #6
  7. Guest
    Thanks very much for the replies....fingers crossed the engineers code
    has not been locked...why would someone do that on a small domestic
    installation?
    There are no diamonds in this house heheh! I just want it to wake me up
    if there is a fire or if someone is crawling around downstairs.
    I will post and let you know how it went.
    Thanks again
    Rolf
    , Nov 24, 2005
    #7
    1. Advertisements
Similar Threads
  1. William E Miller
    † Any suppliers of LCD glass pins?
    William E Miller, Mar 25, 2007, in forum: Electronic Components
    3
    591
  2. Replies:
    600
  3. Veritas 8C manuals
    , Oct 20, 2006, in forum: Security Alarms
    1,209
    Father Jack
    Oct 20, 2006
  4. wizkidding
    Complete N00b needs some advice
    wizkidding, Sep 23, 2011, in forum: General Electronics Chat
    14
    1,156
    KJ6EAD
    Oct 14, 2011
  5. paulmoran
    15
    491
    Lavaguava
    Aug 10, 2014
Loading...
