Variable power supply
Discussion in 'Circuit Help' started by markm6164, Feb 1, 2012.
  1. markm6164
    markm6164 VIP Member
    Jan 22, 2012
    118
    Anyone got a good circuit diagram so I can make a 0-30v variable power supply? I want to include digital volt and amp display. Not sure on amp output. What do you guys use?
    #1
    1. Advertisements
  2. markm6164
    jackorocko VIP Member
    Apr 4, 2010
    1,284
    How much current do you require? Do you need current limiting? Do you want a linear or switching PSU?
    jackorocko, Feb 1, 2012
    #2
    1. Advertisements
  3. markm6164
    Rleo6965 VIP Member
    Jan 22, 2012
    584
    9
    Quezon City, Philippines
    Are you going to use it for your electronic projects? You will need current limit.
    Rleo6965, Feb 1, 2012
    #3
  4. markm6164
    Jan 22, 2012
    118
    Yes just for general project use. Maybe power up the odd car Audio unit or cluster for bench testing too. What do you recommend. Thought better to build one for learning purposes than just buy one.
    #4
  5. markm6164
    Rleo6965 VIP Member
    Jan 22, 2012
    584
    9
    If your new in electronics. Go for analog variable power supply project. It s simpler but bulky.
    #5
  6. markm6164
    Resqueline
    Jul 31, 2009
    2,847
    Most (many) Lab Power Supplies are 0-30V and 0-3A. Here and here are shematic diagram examples that look like they'll work reliably.
    For testing anything higher powered than a simple car radio you'll need a dedicated 13.8V 10-50A power supply though.
    Resqueline, Feb 1, 2012
    #6
  7. markm6164
    Jan 22, 2012
    118
    Thankyou.
    #7
  8. markm6164
    monkeybanana
    Jan 21, 2012
    16
    I actually just made my first power supply! Here's what I found:
    I think you could make this work for up to 30V. If you have wall adapters laying around then you can use the LM317 voltage regulator (advertised to work up to 37V):
    http://www.instructables.com/id/How-to-Build-a-Bench-Top-Power-Supply/
    I can't find the link but someone out there hooked up a digital readout display to it that only costs 10 dollars !
    looks like 30V is possible with almost the same exact circuit above:
    http://www.electronickits.com/kit/complete/powe/ck402.htm
    here is a cool kit from Jameco with negative and positive supplies with the use of a transformer if you don't have wall bricks. it's only 0-15V but you can probably use their schematic (included in link) and modify it to your purposes. Also, the video explains pretty well how it works):
    http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_20626_-1
    afrotechmods who has the greatest videos on youtube explains the voltage regulator here:
    http://www.youtube.com/watch?v=IjJWWGPjc-w
    sorry to dump all these links on you but i just went through this myself!
    monkeybanana, Feb 2, 2012
    #8
  9. markm6164
    monkeybanana
    Jan 21, 2012
    16
    #9
  10. markm6164
    19,904
    1,276
    My, what a tiny heatsink he has.
    I wouldn't try to get 1.5A out of that at a low voltage...
    Check out this for an open source PSU design. This will be available in kit form almost certainly. Check out videos 1 to 6 if you're more interested in what it's designed to do, why you'd want it to do that sort of stuff, and how you make it do it.
    (*steve*), Feb 3, 2012
    #10
  11. markm6164
    monkeybanana
    Jan 21, 2012
    16
    good to know. I like the videos too! i love the internet...and foreign accents...
    edit: the video is a little advanced! more studying for us beginners
    monkeybanana, Feb 3, 2012
    #11
  12. markm6164
    19,904
    1,276
    What accent?
    #12
  13. markm6164
    monkeybanana
    Jan 21, 2012
    16
    haha human accent
    #13
    1. Advertisements
Similar Threads
  1. Mike R
    variable power supply problem
    Mike R, Nov 3, 2003, in forum: Electronic Basics
    541
    Baphomet
    Nov 3, 2003
  2. Chris
    1,094
    Thomas C. Sefranek
    Jan 1, 2004
  3. Animesh Maurya
    Problem with variable regulated power supply
    Animesh Maurya, Jul 22, 2004, in forum: Electronic Basics
    4
    716
    John Popelish
    Jul 23, 2004
  4. John Doe
    Variable speed cordless drills not variable?
    John Doe, Jul 4, 2007, in forum: Electronic Design
    1,167
    John Popelish
    Jul 4, 2007
  5. Jake Omega
    high current variable power supply from ATX PC supply?
    Jake Omega, Oct 10, 2009, in forum: Electronic Design
    1,528
    Jake Omega
    Oct 10, 2009
Loading...
