using a coil and magnet to power an LED
Discussion in 'Electronic Design' started by Mike Pinch, Feb 26, 2006.
  1. Mike Pinch
    Mike Pinch Guest
    I am interested in using a coil and a moving magnet to briefly light up an
    LED. I have only a basic understanding of electronics.
    Does anyone have any advice on what parts or circuit I would use to
    accomplish this?
    Mike
    Seattle
    #1
    1. Advertisements
  2. DaveM
    DaveM Guest
    "Mike Pinch" <> wrote in message
    news:...
    > Hi,
    > Does anyone have any advice on what parts or circuit I would use to accomplish
    > this?
    > Thanks,
    > Mike
    > Seattle
    Ummm Err... Ahhhh Is this a trick question???
    Really, the LED, coil and moving magnet are the only things you need, if the
    magnet is strong enough and the coil is large enough and the movement is fast
    enough. Can you elaborate a bit more on the specifics of your project, or is it
    classified?
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    Never take a laxative and a sleeping pill at the same time!!
    DaveM, Feb 26, 2006
    #2
    1. Advertisements
  3. "Mike Pinch" <> schreef in bericht
    news:...
    > Hi,
    > accomplish this?
    I would try a coil and a moving magnet.
    Thanks, Frank.
    (remove 'q' and '.invalid' when replying by email)
    Frank Bemelman, Feb 26, 2006
    #3
  4. amdx
    amdx Guest
    news:...
    > Hi,
    > accomplish this?
    > Thanks,
    > Mike
    > Seattle
    Hi Mike,
    I'm sure you have seen the flashlights that you shake back and forth,
    causing
    a magnet to slide inside of a coil. These flashlights store the charge in a
    capacitor
    while your not shaking it. Is this the idea your after?
    Would a rotating coil and a stationary magnet work for you? Go to Radio
    Shack
    and get a small DC motor, connect the LED to the motor with the correct
    polarity
    and then spin the motor, the LED should glow.
    Give us a better idea of what your after.
    Mike
    amdx, Feb 26, 2006
    #4
  5. On Mon, 27 Feb 2006 00:09:01 +0100, in sci.electronics.design "Frank
    >news:...
    >> Hi,
    >> accomplish this?
    or a moving coil amd a magnet?
    seems to work in LTspice
    martin
    martin griffith, Feb 26, 2006
    #5
  6. John Larkin
    John Larkin Guest
    On Sun, 26 Feb 2006 14:35:01 -0800, "Mike Pinch"
    <> wrote:
    >Hi,
    >accomplish this?
    >Thanks,
    >Mike
    >Seattle
    Wind a couple/few hundred turns of small-gauge wire around maybe a
    toilet-paper cardboard core. Use maybe #30 enameled magnet wire.
    Connect it to the led or preferably to a pair of leds connected
    anti-parallel.
    Drop a super-magnet, like one of the rare-earth things from an old
    hard drive, through the hole, the faster the better. The led's should
    flash.
    More fun: drop a supermagnet straight down inside a long hunk of 3/4
    inch copper water pipe. Release it and quickly look down the pipe as
    it drops.
    I recently tried dropping a quarter down the bore of a megabuck
    superconductive magnet, expecting the eddy currents to slow its fall.
    It never came out the bottom, not because of the field but because it
    jammed in a flange halfway down. Very embarassing.
    John
    John Larkin, Feb 26, 2006
    #6
  7. "martin griffith" <> schreef in bericht
    news:...
    > >news:...
    > >> Hi,
    an
    > >> accomplish this?
    Yabbut, the OP is not interested in that.
    I bet ;)
    Thanks, Frank.
    > martin
    #7
  8. On Mon, 27 Feb 2006 00:34:36 +0100, in sci.electronics.design "Frank
    >news:...
    >> >news:...
    >> >> Hi,
    >an
    >> >> accomplish this?
    >I bet ;)
    You win,I lied. I couldn't find a symbol for a hand waving a coil (or
    magnet)
    martin
    #8
  9. Fred Bartoli
    Fred Bartoli Guest
    "martin griffith" <> a écrit dans le message de
    news:...
    > >news:...
    > >> >news:...
    > >> >> Hi,
    up
    > >an
    > >> >> accomplish this?
    > >I bet ;)
    > magnet)
    Did you put that nice zero threshold bridge, so that it lights whatever the
    direction you move the magnet.
    And with a transformer, if you suffer from Parkinson's disease you could
    make yourself a powerless christmas tree.
    Fred.
    Fred Bartoli, Feb 26, 2006
    #9
  10. John_H
    John_H Guest
    Mike Pinch wrote:
    > Hi,
    > accomplish this?
    > Thanks,
    > Mike
    > Seattle
    Take the guts out of this:
    http://www.sharperimage.com/us/en/catalog/productdetails/sku__DK013ZZZ
    and you have what you need. Moving magnet, coil, LED, let there be -
    shake shake shake - light!
    John_H, Feb 27, 2006
    #10
  11. Matt
    Matt Guest
    Another cute experiment is to create a "motor-generator" from a couple
    of DC "muffin fans" like those used to cool computers. You connect the
    leads of the first fan to an LED/series resistor combination (keeping
    the polarity correct), and then you connect the leads of the second fan
    to its proper power source. The second fan will start spinning. Now,
    place the first fan close to the second one so that its airflow turns
    the blades of the second fan. As the second fan turns, it generates
    electricity to light the LED.
    Anyone remember those old 28 VDC motor generator sets used to power
    portable World War II electronic field gear?
    John_H wrote:
    > Mike Pinch wrote:
    > > Hi,
    > > accomplish this?
    > > Thanks,
    > > Mike
    > > Seattle
    Matt, Feb 27, 2006
    #11
    > >news:...
    > >> >news:...
    > >> >> Hi,
    > >an
    > >> >> accomplish this?
    > >I bet ;)
    > magnet)
    No. You just model the coil and magnet in spice and then pick up the PC
    and shake in back and forth, just like one of those flashlights.
    Paul Hovnanian mailto:p
    It is not enough to succeed. Others must fail. -- Gore Vidal
    Paul Hovnanian P.E., Feb 27, 2006
    #12
  13. John_H wrote:
    [snip]
    Don't forget the bridge rectifier and the supercap.
    Disclaimer - These opiini^H^H damn! ^H^H ^Q ^[ .... :w :q :wq :wq! ^d
    exit X Q ^C ^? :quitbye CtrlAltDel ~~q :~q logout save/quit :!QUIT
    ^[zz ^[ZZZZZZ ^H man vi ^@ ^L ^[c ^# ^E ^X ^I ^T ? help helpquit ^D
    man quit ^C ^c ?Quit ?q CtrlShftDel "Hey, what does this button d..."
    #13
  14. ehsjr
    ehsjr Guest
    > news:...
    >>Hi,
    >>accomplish this?
    Elegant! I would add a LED to that.
    Ed
    ehsjr, Feb 27, 2006
    #14
  15. Mike Pinch
    Mike Pinch Guest
    I just got back. Thanks for the feedback.
    The application isn't really classified in the sense that I'm not planning
    on putting LEDs into a stronglink or anything but there are some geometrical
    constraints which will mostly impact the coil. Any standard LED will fit
    into the space I have. The intent is to have the LED flash briefly but
    intensely. The coil needs to fit in a fairly narrow space so it needs to be
    "flat" (as in probably occupying less than 1/4 inch thickness) . The coil
    can be long. Let's say we had a long thin coil with lots of windings.
    If there is a long slender coil (say 4 inches long wrapped around an 1/8"
    diameter mandrel) with the proper number of turns, does the influence of the
    magnet (which is let's say 1/4" diameter x 1/10" thick) become
    time-dependent? Will the induced current gradually build up as this magnet
    traverses along the coil? Are additional components needed in this case?
    Remember, I am looking for a briefly flashing LED -- no constant output
    required.
    Also, I am messing around with various coils, chokes and wal-warts. Some of
    these devices seem to have a metal mandrel, some don't. How do I know what
    kind of mandrel (core) to use?
    Regards,
    Mike
    "Paul Hovnanian P.E." <> wrote in message
    news:...
    > John_H wrote:
    > [snip]
    Mike Pinch, Feb 27, 2006
    #15
  16. Christopher
    Christopher Guest
    Hello Michael,
    Just when I thought I had it you changed rules.
    Actually one method is using three small button type batteries and a
    super bright LED. Make certain the LED forward voltage is under 4
    volts. Kids tennis shoes use this method. Look around in the toy
    section Walmart, I found packs of three 1" plastic marbles for $3 with
    a built in flashing IC chip, circuit board, four colors super brite
    LED's and the three batteries. That's for each marble!
    This triggers from a small spring switch that senses a mild impact.
    Trying to achieve 4 volts off of a very small coil and magnet seems a
    bit challenging.
    I don't think you mentioned what triggers your LED, physical motion?
    On Sun, 26 Feb 2006 21:12:02 -0800, "Mike Pinch"
    >required.
    Christopher
    Temecula CA.USA
    http://www.oldtemecula.com
    Christopher, Feb 27, 2006
    #16
  17. Mike Pinch
    Mike Pinch Guest
    Christopher,
    Excellent feedback; thanks.
    I didn't want to use batteries in this application. The application is such
    that human intervention to change batteries is undesirable.
    Here's a question -- does a coil necessarily need to be wound in a circular
    fashion (cross section) or could a coil be wrapped around say a flat piece
    of something (like a popsicle stick)?
    Mike
    "Christopher" <> wrote in message
    news:...
    > Hello Michael,
    > bit challenging.
    >>the
    >>magnet
    >>required.
    > Christopher
    > Temecula CA.USA
    #17
  18. Pooh Bear
    Pooh Bear Guest
    Mike Pinch wrote:
    > Hi,
    > accomplish this?
    > Thanks,
    > Mike
    > Seattle
    Like this ? http://www.freelights.co.uk/how.html
    Graham
    Pooh Bear, Feb 27, 2006
    #18
  19. Lukas Louw
    Lukas Louw Guest
    > Hi,
    > accomplish this?
    > Thanks,
    > Mike
    > Seattle
    Our 20 month old has sneakers with a couple of LEDs on them that flash when
    she walks. I assume there is a coil with a loose fitting magnet in the
    shoes. Let me see if the wife kept the older too small ones, and I'll cut
    them open to see what's inside...
    Lukas
    Lukas Louw, Feb 27, 2006
    #19
  20. Fred Bloggs
    Fred Bloggs Guest
    Lukas Louw wrote:
    >>Hi,
    >>accomplish this?
    >>Thanks,
    >>Mike
    >>Seattle
    > Lukas
    A battery...
    Fred Bloggs, Feb 27, 2006
    #20
    1. Advertisements
Similar Threads
  1. BretCahill
    Small Coil/Magnet Supplies ~ 3 Volts ~ 0.1 Amps
    BretCahill, Sep 21, 2003, in forum: Electronic Basics
    427
    Andrew Howard
    Sep 23, 2003
  2. Kieran Simkin
    3
    842
  3. Terry Dennis
    Safest Way To Hook Up Magnet Coil?
    Terry Dennis, Nov 16, 2005, in forum: Electronic Design
    9
    763
  4. N Cook
    Moving magnet / Moving coil cartridges
    N Cook, Apr 12, 2005, in forum: Electronic Repair
    774
  5. Replies:
    434
    whit3rd
    Jan 20, 2009
Loading...
