using a 7809 voltage regulator
Discussion in 'Electronic Basics' started by catfarm, Oct 23, 2004.
  1. catfarm
    catfarm Guest
    I have a KA7809 voltage regulator. I have a couple of buffering caps from
    the Vin to ground (1uF and .22 uF) and from Vout (.01uF).
    Seems pretty straightforward, yes?
    The problem:
    if I use an 18V DC 400 mA wall wart as my Vin I read 7.5V at the Vout.
    if I use a 23V 1.8A AC transformer through a bridge I read 8.2V at the Vout.
    Ive tried 2 different makes of regulator with the same results. What would
    account for this strange drop in Vout?
    FWIW I put my meter on a 9V battery and got... indeed... 9V.
    #1
    1. Advertisements
  2. catfarm
    CFoley1064 Guest
    >Subject: using a 7809 voltage regulator
    >From: "catfarm"
    >Date: 10/23/2004 12:57 PM Central Daylight Time
    >Message-id: <9Ywed.303627$D%.121731@attbi_s51>
    >The problem:
    First, check your pinout. That seems to be the most common problem. Assuming
    you've got a TO-220 package (metal back, hole in copper for heat sink screw)
    this should be the view from the front, plastic side facing you (view in fixed
    font or M$ Notepad):
    | o |
    '-o--o--o-'
    I G O
    N N U
    D T
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
    Once you've checked that, you want to put your meter on AC 20V range and read
    the input for AC. If you've got a high AC component with no load on the 7809,
    you've probably got a messed up filter cap in the wall wart. You didn't
    mention the filter cap with the transformer, so I'm assuming you don't have
    one. You need a good sized filter cap before the regulator to keep the minimum
    input voltage to the 7809 below 12.5V, otherwise it won't work right. The wall
    wart (it IS DC, right?) is supposed to have a big cap built in to keep the
    ripple on the DC output low.
    Try checking the wall wart and replacing it if there's a lot of AC on the
    output.
    If you're using the transformer with rectifier, put a 1000 uF 35V cap from the
    input terminal of the 7809 to GND.
    See if these work first. They're the most common problems.
    Good luck
    Chris
    CFoley1064, Oct 23, 2004
    #2
    1. Advertisements
  3. catfarm
    John Fields Guest
    On Sat, 23 Oct 2004 17:57:29 GMT, "catfarm" <>
    >The problem:
    1. Inadequate smoothing (too much ripple) on the wall wart output
    for the load, causing the 7809 to go out of regulation when it
    runs out of headroom.
    Fix: if your load current is less than 400mA, place an electrolytic
    cap large enough to keep the wall-wart's output ripple valleys to
    > 11V from the input terminal of the regulator to ground. If the
    load current is higher than 400mA, get a new wall wart.
    2. Too large a load for the wall wart to support, causing it to fall
    below 11V, the 7809's typical dropout voltage.
    Fix: Get a new wall wart.
    3. If not filtered, (or not filtered enough) dropout when the voltage
    out of the XFMR/bridge combo falls below 11V.
    Fix: Figure out how large a filter cap you need from:
    IdT
    C = -----
    dV
    Where C = the required capacitance in farads
    I = the average output current in amperes
    dt= the period of the ripple frequency in seconds
    dV = the permissible ripple voltage in volts
    For a full wave rectifier, dT will be 1/120 = 0.0083s and dV will be
    the output voltage from the bridge minus 11 volts. The output voltage
    from the bridge will probably be something like the 23 volt RMS out of
    the transfromer multiplied by 1.414 to get the peak voltage, then from
    that, 1.4 volts subtracted for the diode drops in the bridge. That
    comes to
    Vout = (VRMS * sqrt2) - 2Vf = (23 * 1.414) - 1.4 ~ 31V
    Subtracting 11V from that to get the permissible ripple voltage gets
    us 20V for dV so, with the exception of the load current, here ya go:
    IdT I * 0.0083s
    C = ----- = ------------- = ???
    dV 20V
    Once you get the capacitance, don't forget to take into consideration
    the tolerance of the capacitor, its voltage rating, and its allowable
    ripple current rating at the ambient temperature in which it'll be
    running.
    Just to be on the safe side of everything, increase the capacitance
    you get by about 50%, get a cap rated at 50VDC, and make sure the
    ripple current rating is about twice your load current rating.
    BTW, it wouldn't hurt to change the output cap to 0.1µF, and connect
    it and the input caps as close to the regulator package as you can.
    John Fields
    John Fields, Oct 23, 2004
    #3
  4. catfarm
    John Fields Guest
    >>From: "catfarm"
    >>The problem:
    > | o |
    > '-o--o--o-'
    > I G O
    > N N U
    > D T
    above 11V typ.
    >output.
    >Good luck
    >Chris
    John Fields
    #4
  5. "catfarm" <> schreef in bericht
    news:9Ywed.303627$D%.121731@attbi_s51...
    > The problem:
    > Vout.
    First get the datasheet of the 7809. That things sometimes contain usefull
    information :).
    As for the wallwart: A DC wallwart uses to have a smoothing capacitor
    inside. But you may have a less common type. A 1uF smoothing capacitor is
    much to small for a normal load. 500uF - 1000uF is a common value. Another
    thing is the load. Some regulators sometimes need some load for good
    regulation. Look what happens if you connect a resistor of let's say 1k to
    the output.
    As for the transformer/bridge combination: You sure need to add a smoothing
    capacitor.
    petrus bitbyter.
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.778 / Virus Database: 525 - Release Date: 15-10-2004
    petrus bitbyter, Oct 23, 2004
    #5
  6. catfarm
    CFoley1064 Guest
    >Subject: Re: using a 7809 voltage regulator
    >From: John Fields
    >Date: 10/23/2004 3:10 PM Central Daylight Time
    >Message-id: <>
    >wall
    > above 11V typ.
    How did I write that??? Jeez -- I must have gremlins in the keyboard.
    Let's see -- I added 9 + 2.5 and got 12.5, and then used below instead of
    above?? Senior moment. You're right, of course.
    Thanks.
    Chris
    CFoley1064, Oct 24, 2004
    #6
  7. catfarm
    Bill Bowden Guest
    "catfarm" <> wrote in message news:<9Ywed.303627$D%.121731@attbi_s51>...
    > The problem:
    Well, the first thing you can do is hook the 7809 input to
    a 12 battery and see if it works. If it does, you have filtering
    problem with the wall wart. Try a larger capacitor across the
    input. The size of the capacitor depends on the load current.
    It's about 8000uF per amp, per volt. So, if the wall wart
    produces 18 volts rms, the peak will be 1.414 times more, or 25
    volts. The 7809 needs a minimum of about 12 volts to deliver 9,
    so the wall wart voltage can fall from 25 to 12 (13 volts total).
    if the load current is 500mA, the capacitor will be
    (8000/13)/2 = 307uF minimum. You can use a larger value for
    more current.
    -Bill
    Bill Bowden, Oct 24, 2004
    #7
  8. catfarm
    catfarm Guest
    Thank you to everyone who responded. I put a 1000uF el cap in the line and
    everything straightened itself out.
    > The problem:
    > Vout.
    catfarm, Oct 25, 2004
    #8
  9. Re: Re: using a 7809 voltage regulator
    On Sat, 23 Oct 2004 21:09:54 GMT, "petrus bitbyter"
    >> The problem:
    >> Vout.
    >information :).
    >the output.
    >capacitor.
    >petrus bitbyter.
    Just a thought, are the usual small capacitors fitted either side of
    the regulator? If not it 'could' be oscillating, particularly with
    the long leads from the wall wart.
    Australia isn't "down under", it's "off to one side"!
    www.cobracat.com (home of the Australian Cobra Catamaran)
    http://groups.yahoo.com/group/cobra-cat/
    Stan Blazejewski, Oct 25, 2004
    #9
    1. Advertisements
Similar Threads
  1. Marcellus Pereira
    7809 replacement
    Marcellus Pereira, Nov 17, 2003, in forum: Electronic Components
    8
    773
    Jim Adney
    Nov 20, 2003
  2. William E Miller
    † Any suppliers of LCD glass pins?
    William E Miller, Mar 25, 2007, in forum: Electronic Components
    3
    515
  3. Silvia Janssen
    1,589
    Silvia
    Dec 12, 2003
  4. Replies:
    555
  5. mooginnyc
    Voltage Regulator powering voltage regulator
    mooginnyc, Mar 21, 2010, in forum: Circuit Help
    12
    1,845
    55pilot
    Apr 1, 2010
Loading...
