UPS function
Discussion in 'Beginner Electronics' started by Procrastinator71, Jun 5, 2008.
  1. Hi,
    I'm using a 700W UPS (localy made) with a 120 Ampere battery to run
    three ceiling fans (150W each), a tube (40W), and my laptop (70W?) and two
    energy savers (18W each) to cover load shedding time which is mostly for one
    hour several times a day. The problem is if all tree fans are running for
    some time, they begin to slow down considerably. Is the battery responsible
    for this or the UPS.
    If I add another battery in parallel will this solve the problem. I intend
    to add another fan to this. Also is there a way to test what is the actual
    strength of the UPS? It is common here to sell UPS that are lower in power
    than what is printed on them.
    #1
    1. Advertisements
  2. Procrastinator71
    James Sweet Guest
    Michael Kennedy wrote:
    > "William Sommerwerck" <> wrote in message
    > news:...
    >> Running batteries in parallel is a bad idea. Think of what will happen if
    >> their voltages don't match. If you do such a thing, you need to put diodes
    >> in series with each.
    > Some car batteries are connected in parallel. Especially larger trucks with
    > diesel engines.
    > Mike
    Those normally use a battery isolator which is really just a couple of
    large diodes. Most RVs and larger boats have a setup like that too.
    James Sweet, Jun 5, 2008
    #2
    1. Advertisements
  3. Procrastinator71
    ian field Guest
    "JANA" <> wrote in message
    news:...
    > The 700 W rating is the maximum load that can be used from the UPS
    > without any damage to it, or it with it being over-loaded. Normaly, the
    > maximum load should not exceed about 60% of the maximum capacity of a
    > UPS.
    > In the instruction manual for the UPS, they usually give a chart of how
    > long it will supply power with different loads. The effect of the load
    > may not be exactly linear because the load is being run from an
    > inverter. This inverter itself uses a certain amount of base current to
    > operate. It's efficiency may not be very linear.
    > In theory, a 120 Amp Hour battery should be able to put out 120 Amps for
    > one hour. Normaly, when a battery is under load, when the voltage of
    > the battery has decreased to about 10% below the nominal rating of the
    > battery voltage, the battery is considered weak.
    Most battery manufacturers specify Ah capacity for the 10 hour discharge
    rate - a 120Ah battery loaded at 120A will be discharged in somewhat less
    than 1 hour.
    ian field, Jun 5, 2008
    #3
  4. Procrastinator71
    JosephKK Guest
    On Thu, 5 Jun 2008 20:51:33 +0100, "ian field" <>
    >news:...
    >> UPS.
    >than 1 hour.
    If they are working to US SAE specifications it is 20 hour discharge.
    JosephKK, Jun 8, 2008
    #4
  5. Procrastinator71
    JosephKK Guest
    On Thu, 5 Jun 2008 14:59:07 -0400, "Michael Kennedy"
    >news:...
    >diesel engines.
    >Mike
    Actually the batteries are in series to run the starter motor, and
    isolated otherwise.
    #5
  6. Procrastinator71
    Eeyore Guest
    Procrastinator71 wrote:
    > Hi,
    Just out of interest, of what value is the information "(localy made)" <sic>
    when you don't mention what part of the world you live in ?
    Or is it the 'world' called the USA ?
    Graham
    Eeyore, Nov 13, 2008
    #6
  7. Procrastinator71
    PeterD Guest
    On Thu, 13 Nov 2008 20:08:43 +0000, Eeyore
    >> Hi,
    >Graham
    I'd say he made it himself...
    PeterD, Nov 13, 2008
    #7
    1. Advertisements
Similar Threads
  1. AC/DCdude17
    13
    1,100
    Mike Tomlinson
    Jul 11, 2004
  2. TransFigure II
    Can I mod a 230V UPS into 110V UPS ?
    TransFigure II, Jul 29, 2004, in forum: Electronic Repair
    11
    1,627
    Michael A. Covington
    Aug 1, 2004
  3. Procrastinator71
    UPS function
    Procrastinator71, Jun 5, 2008, in forum: Electronic Equipment
    7
    1,161
  4. Procrastinator71
    UPS function
    Procrastinator71, Jun 5, 2008, in forum: Electronic Repair
    7
    587
    PeterD
    Nov 13, 2008
  5. AC/DCdude17
    12
    797
    Mike Tomlinson
    Jul 11, 2004
Loading...
