trying to add a small shock to bird feeder, to stop the squirrels
Discussion in 'General Electronics' started by Vender, Apr 25, 2004.
  1. Vender
    Vender Guest
    Hello, I am trying to add a small shock to a bird feeder from a 9VOLT
    battery. The squirrels are taking over and need a simple way to do
    this. Thanks for the help. And for all the PETA people who are going
    to complain, please dont. I am not trying to kill any squirrel.
    #1
    1. Advertisements
  2. Vender
    jeroen Guest
    hi,
    well, you can create a small shocker driven by a 555 timer supplying a small
    300V condensator
    however you should keep it to a small condensator, that is if you want the
    squirrel to survive ;)
    jeroen
    "Vender" <> wrote in message
    news:...
    jeroen, Apr 25, 2004
    #2
    1. Advertisements
  3. Vender
    Gary Lecomte Guest
    (Vender) wrote in message news:<>...
    Any shock that scares the squirrels, will also scare the birds.
    Put the feeder on somthing the squirrels can't climb.
    Gary
    Gary Lecomte, Apr 25, 2004
    #3
  4. Vender
    Ken Taylor Guest
    How will adding water help?
    Ken
    "jeroen" <> wrote in message
    news:AGVic.151344$...
    > hi,
    small
    > 300V condensator
    > jeroen
    > news:...
    Ken Taylor, Apr 26, 2004
    #4
  5. Vender
    Rich Webb Guest
    The effectiveness depends somewhat on the layout of the feeder and
    perches but you might try sprinkling some cheap ground cayenne pepper
    either in with the seed or where the squirrels sit and reach for it.
    Birds don't "taste" the capsaicin in the pepper but the squirrels sure
    will. Might convince them to try another buffet...
    Rich Webb Norfolk, VA
    Rich Webb, Apr 26, 2004
    #5
  6. It is going to take a lot more than a 9 Volt battery to do what you
    want. Your problem would be to discrimate between what is a bird and a
    squirrel, if you are not manning the switch manualy.
    There will still be safety issues, and also the consern for animal
    rights.
    There are feeders that are squirrel proof, and also if you have a dog,
    the squirrel will most likely not come over, but birds will.
    Jerry G.
    http://www.zoom-one.com
    Jerry Greenberg, Apr 26, 2004
    #6
  7. Vender
    Garrett Mace Guest
    news:...
    http://www.ibiblio.org/Dave/Dr-Fun/df200404/df20040423.jpg
    Garrett Mace, Apr 26, 2004
    #7
  8. Vender
    JeffM Guest
    >try sprinkling some cheap ground cayenne pepper in with the seed
    >but the squirrels sure will.
    > Rich Webb
    As common as the problem is, http://www.wildbirds.com/images/squirrel.jpg
    I'm amazed that everyone doesn't know the easy solution
    and tries all this electrical / feeder-relocation / blocking-disk jazz.
    The trick is to realize the differences
    in Mammalian and Avian physiology (receptors).
    JeffM, Apr 26, 2004
    #8
  9. Vender
    Garrett Mace Guest
    "JeffM" <> wrote in message
    news:...
    > > Rich Webb
    The easy solution? I think I saw that in a Circuit Cellar or some other
    magazine ages ago...discussed a circuit to control an RC servo with a 555.
    The author used this circuit in conjunction with the internals of a
    battery-powered squirtgun, to remotely aim the nozzle at squirrels in the
    bird feeder area.
    Well...ok, so maybe that's not the easy solution, but it sure is the fun
    one.
    #9
  10. Vender
    Vender Guest
    ok I think the question was how to make a shocking device for
    squirrels. Not pepper, not squirt gun... And I think if a stun gun
    can shock someone with a 9volt battery I would think it could shock a
    squirrel. Ah f it I will hook up some 120 house current and fry the
    squirrels, that should work. Great forum thanks for no help! Also
    they sell these types of feeders, but I dont want to spend $150.
    Vender, Apr 27, 2004
    #10
  11. Vender
    Rich Webb Guest
    **plonk**
    Rich Webb, Apr 28, 2004
    #11
  12. Vender
    Ken Taylor Guest
    news:...
    You can't nail a bit of tin around a pole for less than $150?? Electronics
    is over-kill for this, so unless you want to do it for the fun of it, don't
    bother. If you're insistent, go Google 'electric fence circuit' or similar.
    Ken
    Ken Taylor, Apr 28, 2004
    #12
  13. Vender
    Vender Guest
    Rich Webb <> wrote in message news:<>...
    > **plonk**
    *plonk* back at ya. Are you kidding or are you ten years old? This is
    so old, if you dont have an answer shut the **** up!!! People post to
    get answers to questions, pretty simple. God this should be so easy,
    HOW DO I SHOCK SQUIRRELS.
    Thanks, enough bullshit.
    Vender, Apr 28, 2004
    #13
  14. Vender
    JeffM Guest
    >I think the question was how to make a shocking device for squirrels.
    > Vender
    You are not the first to seek a methodology
    to achieve a poorly-thought-out concept. It happens all the time.
    http://groups.google.com/groups?&threadm=
    http://groups.google.com/groups?&threadm=sFvic.16048$-kc.rr.com
    The pepper method has been the technique of choice for decades
    because it discriminates between birds and squirrels (yours doesn't).
    Being hard-headed and relying on an inferior concept,
    http://216.239.57.104/search?q=cache:29SiSwbFzowJ:c2.com/cgi/wiki?NotInventedHere+NIH-syndrome
    while demanding that others provide the particulars to the solution,
    is simply childish.
    JeffM, Apr 29, 2004
    #14
    1. Advertisements
Similar Threads
  1. EsMot
    Dell 17" P780 D99 chassis - H Stop or V Stop?
    EsMot, Jul 28, 2003, in forum: Electronic Repair
    774
    EsMot
    Jul 28, 2003
  2. EsMot
    H Stop or V Stop
    EsMot, Aug 2, 2003, in forum: Electronic Repair
    625
    EsMot
    Aug 2, 2003
  3. William E Miller
    † Any suppliers of LCD glass pins?
    William E Miller, Mar 25, 2007, in forum: Electronic Components
    3
    591
  4. Boozo
    How can I stop static shock ?
    Boozo, Apr 6, 2004, in forum: Misc Electronics
    4
    876
    Boozo
    Apr 8, 2004
  5. Replies:
    600
Loading...
