Transistors Replacements
Discussion in 'Electronic Basics' started by BobG, Mar 29, 2005.
  1. BobG
    BobG Guest
    Looks like any ol transisitor that will handle 12V and 2 A will work.
    BobG, Mar 29, 2005
    #1
    1. Advertisements
  2. BobG
    Chretien Guest
    I'm trying to build a circuit that calls for these three Transistors.
    My local guy does not have them. I would rather buy from him than some place
    I have to have them shipped into, added cost etc.
    Who knows they may be obsolete?
    Does anyone have a book or something where they can look up replacements for
    these that might be more available.
    BC212
    BD132
    BC182
    The circuit would like to build is at :
    http://www.atv-projects.com/html/nicd_zapper.html
    Thanks.
    Chretien, Mar 29, 2005
    #2
    1. Advertisements
  3. BobG
    Chris Guest
    some place
    replacements for
    > BC212
    > BD132
    > BC182
    > Thanks.
    Hi, Chretien. If you can't find the specified parts for a hobbyist
    project, you might want to try NTE replacement semiconductors. They're
    made for repair and engineering prototype stuff. Their cross-reference
    page is
    http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search?OpenForm
    You can frequently find what you need there.
    I did a quick search on their cross-reference page, and came up with
    the following:
    BC212=NTE159
    BD132=NTE242
    BC182=NTE123AP
    If you can't find NTE parts locally, you can always get them out of the
    Mouser catalog
    http://www.mouser.com/
    (By the way, please wear eye protection when you use your NiCd zapper
    circuit. Also, try using a 12V automotive bulb as a load when checking
    out your circuit, before you try a battery.)
    Good luck
    Chris
    Chris, Mar 29, 2005
    #3
  4. BobG
    Chretien Guest
    "BobG" <> wrote in message
    news:...
    Thanks.
    I am a novice and tend to slavishly follow schematics. However I know that
    many circuits can use as you say any old transistor. I don't always
    understand why, accept to say that I suppose the circuits are so heavy
    handed and non specific that almost anything will do so long as the are NPN
    or PNP.
    Thanks again.
    #4
  5. BobG
    BobG Guest
    that
    >understand why,
    The rule of thumb is that the transistor needs to withstand the voltage
    and current from the circuit, so over spec-ing the transistor just
    hurts your wallet. Same with caps... you can use a 50v cap in a 5v
    circuit, but not vice-versa
    BobG, Mar 30, 2005
    #5
  6. "Chretien" <> wrote:
    > BC212
    > BD132
    > BC182
    In the well known electronics magazine Elektor they use the acronyms tun
    and tup to mean transistor universal npn(pnp).
    The requirements for these transistor are something like this:
    Max collector voltage min 30V, hFE min 200, max current min 100mA.
    Thousands, if not millions, of small signal transistors meet these
    requirements, and you can use any of them in most circuits.
    Elektor use those basic types in many of their circuits.
    In your circuit 3 are such small signal transistors and there is no
    special requirements as far as I can see. The power source is
    12 Volt, and practically all transistors ever made can be used when we
    consider the maximum voltage alone.
    The BD type is a power transistor which need to be able to handle 2Amp
    momentarily.
    There are circuits where other parameters mean a lot, like in an audio
    preamp if it says BC109c it means a low noise transistor with a hFE above
    500 or so. But your circuit does not seem to need any special types. Take
    what you have and it will probably work just as well as with the named
    types.
    A well known tun is BC107 (108,109), a well known tup is BC177 (178,179).
    The numbers ending in 9 in these series denote low noise types, but they
    can take less maximum voltage. (30V instead of 60V for the 107 and 108
    types) If there is a letter at the end it shows the hFE value.
    BC107b = General purpose npn small signal transistor with medium amplification
    factor, hFE = 300-500 or so.
    All numbers above are approximative, different manufacturers have
    slightly different values.
    Check out these links:
    http://www.uoguelph.ca/~antoon/circ/tuptun.htm
    http://www.uoguelph.ca/~antoon/gadgets/gadgets.htm
    Roger J.
    Roger Johansson, Mar 30, 2005
    #6
  7. BobG
    Chretien Guest
    "Chris" <> wrote in message
    news:...
    > some place
    > replacements for
    > > BC212
    > > BD132
    > > BC182
    > > Thanks.
    > page is
    > the following:
    > BC212=NTE159
    > BD132=NTE242
    > BC182=NTE123AP
    > Mouser catalog
    > Good luck
    > Chris
    Hey thanks thats that will be a great help in the future.
    Chretien, Mar 30, 2005
    #7
  8. BobG
    Chretien Guest
    "Roger Johansson" <> wrote in message
    news:Xns96292485F4B1086336@81.174.12.30...
    > > BC212
    > > BD132
    > > BC182
    > momentarily.
    > types.
    amplification
    > Roger J.
    Roger,
    Thanks for the tutorial it was extremely helpful. Here and I thought all
    those letters where just manf codes.
    I'm printing off your message and will keep it in my transistor file for
    future reference. The web links were very useful also. I have actually made
    a few of Mr Toons projects but somehow didn't see those links.
    I have to say this newsgroup is one of the most helpful I have ever used. I
    always seem to get some help when I need it.
    Thanks again.
    #8
  9. BobG
    Jamie Guest
    > BC212
    > BD132
    > BC182
    > Thanks.
    http://www.datasheetcatalog.com/catalog/p47320.shtml
    those are generic type PNP and NPN signal transistors.
    from what i can see.
    Jamie, Mar 30, 2005
    #9
    1. Advertisements
Similar Threads
  1. AliTonto
    11
    650
    Watson A.Name - \Watt Sun, the Dark Remover\
    Jun 18, 2004
  2. Norm Dresner
    LM13600 -- National's obsoleted it. Any replacements?
    Norm Dresner, Oct 17, 2004, in forum: Electronic Components
    6
    1,250
    Winfield Hill
    Oct 23, 2004
  3. Jimbo
    Pyle output transistors replacements
    Jimbo, Feb 9, 2005, in forum: Electronic Repair
    4
    442
    James Sweet
    Feb 11, 2005
  4. Albert
    6
    2,153
    Albert
    Oct 25, 2007
  5. Simmon
    Metal Can VS ceramic transistors or plastic transistors
    Simmon, Feb 15, 2014, in forum: General Electronics Chat
    9
    1,427
    (*steve*)
    Feb 16, 2014
Loading...
