Transistor Saturation
Discussion in 'Electronic Basics' started by Bart, Aug 3, 2006.
  1. Bart
    Bart Guest
    I've got a bunch of general purpose NPN transistors and I want to turn on
    and off 15Vdc with 5Vdc from logic chips like binary counters or different
    logic gates (XOR, NAND,etc). From what I read about these transistors I
    guess I want them to go into saturation which is maximum CE conduction. Is
    there a rule of thumb to turn a transistor all the way on or do I go to the
    datasheet for each particular transistor (which still sometimes confuses me
    and not sure which callout is the designation for base volt/amp for
    saturation). I've read that .7V base voltage above emitter voltage will do
    it, I've also read that I need 5 volts above collector voltage will do it.
    Any guidance is appreciated,
    Bart
    Bart, Aug 3, 2006
    #1
    1. Advertisements
  2. Bart
    Winfield Guest
    "Bart" <bborb@fusedotnet> wrote in message
    news:551d9$44d17d2e$d8442e8b$...
    the
    me
    > Bart
    You need to check the rating of each transistor. In general, for
    small-signal transistors such as BC548 etc, limiting the base current to
    about 500uA to 1mA is sufficient. To turn on a BC548 from a 5V supply, (or
    chip), a 4.7K or 10K resistor in series with the base will do the job.
    The absolute minimum current required to turn on the transistor is the
    collector current divided by the current gain.
    .... Winfield
    Winfield, Aug 3, 2006
    #2
    1. Advertisements
  3. Bart
    Winfield Guest
    > ... Winfield
    Sorry, I should have added, the typical base-emitter voltage of a
    small-signal transistor is about 0.6V. For a higher power transistor or a
    Darlington pair, this can be as high as 1-2V. This voltage is like the
    forward voltage drop of a diode. If the voltage applied to the base exceeds
    this voltage, it is a good idea to limit the input current to a known value.
    (5V-0.6V)/4.7K = 936uA.
    .... Winfield
    #3
  4. Bart
    Eeyore Guest
    You're missing the point.
    The best transistors for this job are *designed* as switching transistors. They
    have low intrinsic resistance to reduce the Vce(sat).
    Also, it's not about base *voltage* but base *current* !
    Check out the 2N440x series.
    Graham
    Eeyore, Aug 3, 2006
    #4
  5. Bart
    Noway2 Guest
    > Bart
    Using the minimum Beta of the transistor (from the datasheet),
    calculate the required base current needed to pull the collector
    voltage down to the voltage at the base. Assuming a common emitter
    configuration, the voltage at the collector is equal to the (applied)
    collector voltage minus the IR drop in the collector resistor. Then
    multiply this current by 10, for a 10x overdrive factor as it is called
    in the Art of Electronics. Knowing the base voltage (5v in this case)
    and the required base current, you can calculate the needed base
    resistor to provide this current.
    Noway2, Aug 3, 2006
    #5
  6. "Bart" <bborb@fusedotnet> wrote in message
    > the datasheet for each particular transistor (which still sometimes
    > confuses me and not sure which callout is the designation for base
    > volt/amp for saturation). I've read that .7V base voltage above emitter
    > voltage will do it, I've also read that I need 5 volts above collector
    > voltage will do it.
    > Bart
    One way to find the base drive required for saturation is to create a
    load-line for the circuit with Ic on the vertical axis and Vce on the
    horizontal axis. Where this load line intersects the vertical axis is the
    saturation current of the BJT, for that circuit, and where it intersect the
    horizontal axis is cutoff. If you take value of Ic found on the vertical
    axis and divide by the beta of the transistor this will give you the value
    of base current needed to saturate the transistor. You will then need to
    find a value of base resistance needed to obtain this current at 5 volts.
    The easiest way, to do essentially the same thing, is to find the collector
    saturation current by dividing the power supply voltage (Vcc) by the
    collector load resistance. Divide this current by the typical Beta or Hfe of
    the transistor. This give the base current necessary for saturation.
    Your goal should to find the lowest base current required for saturation.
    The brute-force method is to use an overwhelming large base current but this
    is wasteful.
    The best way to know if the transistor is in saturation is to measure a Vce
    of 0.3 volts or less.
    Dorian
    Dorian McIntire, Aug 3, 2006
    #6
  7. Bart
    John Fields Guest
    The rule of thumb is to divide the collector current by 10 and to
    force that current into the base.
    Doing it this way will cause the transistor to have what is called a
    "forced beta" of 10 and will very nearly always assure that the
    transistor will go into saturation.
    For example, assume a transistor with a collector-to-emitter
    saturation voltage (Vce(sat)) of 0.3V with 100mA of collector
    current, and also assume that the base-to-emitter diode (Vbe) will
    drop about 0.7V, worst case, when the transistor is in saturation.
    With a 15V collector supply and the signal into the base being
    either 0V or 5V, your circuit will look like this: (View in Courier)
    Vcc
    +15V
    [Rl]
    +----Vce(sat)
    | 0.3V
    C
    0/5V>--[Rb]-----B
    / E
    Vbe(sat) |
    0.7V |
    GND
    Since, when saturated, the collector voltage will be about 0.3V, in
    order to get 100mA through the load we can calculate the value of
    the load resistor like this:
    Vcc - Vce(sat) 14.7V
    Rl = ---------------- = ------- = 147 ohms
    Il 0.1A
    Then, since the collector current will be 100mA, we'll want to turn
    on the transistor with 10mA through the base. Since we want the
    transistor to be turned on when the input signal is at 5V and we
    have a Vbe of about 0.7V, the base resistor will need to be:
    Vin - Vbe(sat) 5V - 0.7V 4.3V
    Rb = ---------------- = ----------- = ------- = 430 ohms
    Ib 0.01A 0.01A
    It's also possible to use the same procedure forcing a beta higher
    than 10 and, in the process, saveing some base current. Notice,
    however, that on most data sheets Vbe(sat) and Vce(sat) are given
    for a forced beta of 10.
    John Fields
    Professional Circuit Designer
    John Fields, Aug 3, 2006
    #7
    No particular designations, then? Well, it's not terribly important
    so long as they aren't very ancient.
    >and I want to turn on and off 15Vdc with 5Vdc
    Since they are NPN, I assume that you mean to use them with emitter
    connected to ground and the 15V load (whatever it is) between the
    collector and the +15V supply side.
    >counters or different logic gates (XOR, NAND,etc).
    Hobby play?
    >From what I read about these transistors I guess I want them to go into
    Well, saturation in the case I mentioned above is just a matter of
    forcing the collector voltage close enough to ground voltage (0V) so
    that the base-to-collector junction begins to be forward-biased. And
    the current through the collector needed to do that will depend on the
    load you have connected, not upon the transistor. So which exact type
    of transistor you use won't really matter on this narrow point. Do
    you see why?
    >Is there a rule of thumb to turn a transistor all the way on
    Yes. When the current passing by way of the transistor's collector
    and through the load causes the load itself to drop almost all of your
    supply voltage, then the transistor will be "all the way on." When
    that happens, the load is taking up almost all of the voltage
    available, leaving only a smidgen left to support the collector to
    emitter voltage of the transistor. For design purposes, that
    remaining smidgen is usually estimated to be just a few tenths of a
    volt, perhaps somewhere between .1 and .4 or so.
    So just estimate the collector current needed by taking your 15V,
    subtracting a small "smidgen" from it for the transistor, then
    dividing that by the load resistance of what you are connecting to the
    collector and supply. Let's say it is 1k ohm load and you want to
    estimate a saturation Vce of .2V, you'd calculate (15-.2)/1k as your
    collector current needed for saturation. As you can see, with a 15V
    supply in hand, changing your saturation estimate by a tenth or two,
    one way or another, won't seriously impact your calculated saturation
    current. The actual voltage for Vce that you will get will depend on
    other particulars (such as the exact device used and the base
    current), but it's not important at this stage to worry about the
    transistor data sheet.
    It's not uncommon to then blindly estimate the needed beta as 10, for
    saturation. That's because most modern transistors are pretty much
    going to be doing as much as you can expect from them as a switch when
    you supply 1/10th of the collector current as base drive. There are a
    few exceptions. Actually, it turns out that in many cases you can
    drive them with much less base current than this rule of thumb
    suggests. Maybe 1/30th or even 1/50th. But almost any transistor
    will get there with 1/10th. So you might not even need to look at the
    data sheet for even this value, if you are willing to accept 1/10th of
    Also, it's not uncommon to estimate the base voltage as .7V for this
    purpose. The exact base voltage will depend largely on the base
    current used (not entirely, as the collector current does play a role,
    but almost.) But since it varies up and down by roughly 60mV for a
    10-fold change in base drive current, the exact value won't be all
    that far away. If your collector current is large, then the base
    drive current will be large too and the base voltage may be nearer
    ..8V, .85V, or even .9V. But for design purposes, being off by one
    tenth of a volt won't kill your design. And .7 is a good place to be
    for many cases.
    So far, no need yet for a data sheet to make a reasonable design.
    (1) Compute collector current from the supply voltage, the load
    resistance, and a blind estimate of Vce, as (Supply - Vcesat) / load.
    (2) Compute needed base drive current as 1/10th the value computed in
    step (1).
    (3) Use .7V as a blind estimate for the base voltage. You can modify
    this per Vbe=25.865mV*(1+ln(Ib/Is+1)) @ 27C, where Is is a value found
    for the simulation model of the transistor or just taken to be 10^-14
    or so, blindly. For example, if Ib (base drive current from step (2))
    is about 100uA, then you could compute 25.865mV*(1+ln(1+100uA/10fA)),
    which works out to about 0.62V. This will be closer, probably, than
    the .7V. But the .7V won't steer you much wrong, anyway.
    (4) Estimate the actual control voltage. You said 5V, but unless
    this is a power supply (and you've said it isn't), there is some
    internal impedance and supplying the base current calculated in step
    (2) will drop the voltage a little. Or, if this is a standard TTL
    output, you cannot always rely upon the voltage being much better
    than, say, 4V. What it is exactly will depend on your output type and
    what is connected to it other than the transistor. But let's use an
    estimate of 4.5V, as an example.
    (5) Compute your base resistor used to limit the base current to the
    value you computed in (2) on the assumption that your 5V control
    voltage is low impedance enough that it can yield at least the voltage
    estimated in step (4) or 4.5V. This is done by dividing the voltage
    that the base resistor needs to drop by the estimated base drive
    current. Something like this: (4.5V - .7V)/100uA = 38k. Use 39k, as
    a standard value.
    Now, suppose you are wrong about the base drive current using the
    estimator of 1/10th to compute it. Suppose the actual base drive
    current for the actual transistor works out to, say, 1/30th instead.
    Well, the voltage drop across the base resistor will be a lot less if
    that happened and that would mean that more of the 4.5V control
    voltage would appear at the base of the transistor. Just for a
    moment, let's assume that 1/3rd of our computed current was actually
    needed -- in that case, the base resistor would drop 1/3rd of the 3.8V
    we earlier used in our computation for the resistor value, or about
    1.3V, instead. That would, we might guess, cause 3.2V to be at the
    base of the transistor. But that won't happen. That's because, as I
    mentioned before, the base voltage goes up by 60mV for each 10-fold
    increase in base current. So if it really were 3.2V, that could only
    happen if there were (3.2V - .7V)/60mV or about 4.2 orders of
    magnitude change in the base drive current. That would be more than
    10,000 times. And if you tried to send that much current through the
    base resistor we computed, then the voltage drop would be impossibly
    high. So what really happens is that even if the saturation beta of
    the transistor _might_ be better estimated as 1/30th, than 1/10th,
    having designed things with the idea of 1/10th means that it will be
    very close to 1/10th, anyway. The actual transistor you use may
    impact just a tiny bit the actual current flowing through the base
    resistor, but it will be _very_ close to the designed value because of
    this exponential behavior of base current versus base voltage. So if
    you use 1/10th as your rule of thumb in your design, it will come out
    pretty darned close no matter what transistor you actually use.
    So no data sheet, still.
    >or do I go to the
    You _may_ still want to take a look at the data sheet. One thing you
    need to be sure (and this is more important if you had a supply
    voltage larger than 15V) of is that the transistor can "stand off"
    your supply voltage when it is off. If there is no current flowing
    through the load, then the load doesn't drop any voltage and the
    collector will be exposed to the supply voltage. You want to be sure
    that the transistor can support the Vce difference without breaking
    down. For most transistors, given my hobby experience, you can
    usually start worrying when the supply voltage exceeds about 25V or
    so. But there are enough transistors with lower voltages that it's
    worth a look just to be sure.
    Jon
    Jonathan Kirwan, Aug 3, 2006
    #8
  9. Bart
    Bart Guest
    > voltage will do it.
    > Bart
    Thank you all for the replies. I had a chance to play with a resistor
    decade box to the transistor base and applied the information I got here in
    this thread. Everything worked just like you said. I found these transistors
    (assorted and all T0-92 pkg) very forgiving and work great when using what I
    learned here. And they only cost 4 cents each!
    Thanks again everybody,
    Bart
    Bart, Aug 5, 2006
    #9
  10. Bart
    Noway2 Guest
    > Bart
    On a final note, you may or may not have noticed that one of the things
    you are doing, is in effect desiging the circuit so that its
    performance is dependant on the commponents connected to the
    transistor, rather than the transistor itself.
    For example, if you were using the transistor in the active mode
    instead of cutoff and saturation, it would (most likely) be desirable
    that the gain depend on the resistors used in the circuit. The reason
    for this is that the defining parameters of the resistor are much
    easier to control than the intrinsic paramaters of the transistor, such
    as the Beta.
    Noway2, Aug 7, 2006
    #10
    1. Advertisements
Similar Threads
  1. Mr. J D
    3
    2,925
    William Hightower
    Aug 18, 2006
  2. spice mos transistor saturation
    , Jul 18, 2006, in forum: Electronic Design
    3
    697
    Chris Jones
    Jul 19, 2006
  3. Mr. J D
    6
    780
    jasen
    Aug 19, 2006
  4. Mr. J D
    Delaying the saturation of a transistor
    Mr. J D, Aug 19, 2006, in forum: Electronic Design
    13
    883
    Fred Bloggs
    Aug 20, 2006
  5. Replies:
    27
    3,106
    Joerg
    Aug 16, 2007
Loading...
