Transistor pins EBC
Discussion in 'Electronic Basics' started by Macdonald, May 9, 2005.
  1. Macdonald
    Macdonald Guest
    #1
    1. Advertisements
  2. Macdonald wrote:
    > Can anyone confirm that when Im looking at the diagram of a
    > transistor eg http://www.nteinc.com/specs/100to199/pdf/nte159.pdf
    > Page 3, Diagram one, That Im looking straight at the flat spot of the
    > Transistor. Not the Rounded part.
    > Thanks.
    Yes. You see two lines, vertically, inside the body part of the
    transistor, along the vertical sides of the body.
    These lines are there to show you that it is the front side of the
    transistor you are looking at.
    These lines show the edges between the rounded and the flat surfaces.
    Roger J.
    Roger Johansson, May 9, 2005
    #2
    1. Advertisements
  3. Macdonald
    Macdonald Guest
    "Roger Johansson" <> wrote in message
    news:...
    > > Thanks.
    > Roger J.
    Thanks.
    #3
  4. Macdonald
    Rich Grise Guest
    On Mon, 09 May 2005 11:48:03 -0500, Macdonald wrote:
    > Can anyone confirm that when Im looking at the diagram of a transistor eg
    > Thanks.
    Yes.
    A: you can see its edges in the front view, and
    B: the one below is the bottom view, as if you're holding it with both
    index fingers and both thumbs, and just swing the legs up toward you.
    Cheers!
    Rich
    Rich Grise, May 13, 2005
    #4
    1. Advertisements
Similar Threads
  1. Mark
    Identifying TO-3 transistor pins?
    Mark, Dec 6, 2004, in forum: Electronic Design
    5
    2,994
    Terry Given
    Dec 7, 2004
  2. Mark
    397
  3. Mark
    440
  4. Mark
    433
  5. devatu
    RS485 15 pins to rs 485 9 pins cable?
    devatu, Sep 11, 2014, in forum: Electronics Repair
    673
    Harald Kapp
    Sep 11, 2014
Loading...
