Transistor part # cross reference needed
Discussion in 'Electronic Repair' started by Chuck Chopp, Feb 7, 2004.
  1. Chuck Chopp
    Chuck Chopp Guest
    I have a transistor which exploded [epoxy resin case ruptured] due to a
    power surge. It from the power supply circuit in a Toshiba TV, model 20A42,
    chassis M3L714, mfg date August 2002. The component designation on the
    circuit board is Q504.
    The following text is present on the back side of the transistor:
    K-232
    C3198
    Y
    I don't have a current Philips/ECG semi-conductor cross reference guide on
    hand, and I have not yet identified a local electronics component retailer
    to go to [other than Radio Shack]. AFAIK, the appearance of the component
    leads me to believe that it is one of the common transistor types and I
    might even be able to get a replacement at Radio Shack if I knew what the
    actual transistor type/designation was.
    Is there an online reference for these types of semi-conductors?
    TIA,
    Chuck
    Chuck Chopp
    ChuckChopp (at) rtfmcsi (dot) com http://www.rtfmcsi.com
    ICQ # 22321532
    RTFM Consulting Services Inc. 864 801 2795 voice & voicemail
    103 Autumn Hill Road 864 801 2774 fax
    Greer, SC 29651 800 774 0718 pager
    8007740718 (at) skytel (dot) com
    Do not send me unsolicited commercial email.
    #1
    1. Advertisements
  2. Chuck Chopp
    Chuck Chopp Guest
    > 20A42, chassis M3L714, mfg date August 2002. The component designation
    > on the circuit board is Q504.
    > K-232
    > C3198
    > Y
    > on hand, and I have not yet identified a local electronics component
    > retailer to go to [other than Radio Shack]. AFAIK, the appearance of
    > the component leads me to believe that it is one of the common
    > transistor types and I might even be able to get a replacement at Radio
    > Shack if I knew what the actual transistor type/designation was.
    OK, making progress... I found the http://www.nteinc.com web site and a
    lookup of C3198 returns NTE85, which is a general purpose NPN transistor.
    Now I just need to turn this back into some sort of general purpose
    transistor #, such as a 2N2222, etc.... Damn, but this gets confusing when
    you haven't done any sort of hands-on hobbyist electronics in 17 years.
    Chuck Chopp
    ICQ # 22321532
    #2
    1. Advertisements
  3. Bill Renfro
    Bill Renfro Guest
    2SC3198
    I doubt it would be a Radio Shack item.
    You could order from MCM Electronics.
    Bill
    Christian Technology
    "Chuck Chopp" <> wrote in message
    news:abeVb.23276$...
    > > K-232
    > > C3198
    > > Y
    when
    > Chuck Chopp
    > ICQ # 22321532
    Bill Renfro, Feb 8, 2004
    #3
  4. Sofie
    Sofie Guest
    Chuck Chopp:
    An NTE 85 is a general purpose NPN silicon transistor in a T0-92 epoxy
    case.... similar in fact to the slightly lower voltage/current 2n2222a,
    2n3904 or 2n4401, which I have found to work OK in most circuits.. A more
    exact replacement would be a very common 2sC945 or 2sC1815. Just be
    certain to watch the lead arrangement for the proper BCE connections as they
    do vary with some otherwise satisfactory substitutions..
    And the good news is that the mps2222a (equivalent to a 2n2222a) is
    available at Radio Shack, catalog # 276-2009...... so are the mps3904 and
    2n4401
    Best Regards,
    Daniel Sofie
    Electronics Supply & Repair
    snipped:
    when
    > Chuck Chopp
    Sofie, Feb 8, 2004
    #4
  5. Tim Marcus
    Tim Marcus Guest
    Dude -just order the NTE 85 tranny instead! NTE replacements are not
    the greatest in the world, but for this particular one, it should be
    fine (close enough). You can order these anywhere - www.mcminone.com,
    digikey, mouser, it will be less than a dollar. Or go to any
    electronics shop in your area - this should be a stock part - Tim
    Chuck Chopp <> wrote in message news:<abeVb.23276$>...
    > > K-232
    > > C3198
    > > Y
    > Chuck Chopp
    > ICQ # 22321532
    Tim Marcus, Feb 8, 2004
    #5
  6. Chuck Chopp
    Chuck Chopp Guest
    Sofie wrote:
    > Chuck Chopp:
    > 2n4401
    OK, I dug through my ancient box of spare parts and it turns out that I have
    some 2n2222a transistors in a metal can [TO-18 ?] package. A quick look up
    of the pin arrangement gave me what I needed to know about getting things
    properly arranged to solder it back onto the circuit board. I used my
    clip-on heat sink while soldering and reassembled everything. It looks like
    I'm going to need to get a schematic and repair guide as there appears to be
    additional problems. The power supply circuit is sufficiently repaired to
    the point where the flyback transformer is whining very quietly [and it
    didn't even do that before], but when I press the power button the TV does
    not actually turn on.
    Maybe it is just a lost cause and I shouldn't spend any more time on it. If
    one of the SMD ICs on the circuit board got fried then it is pretty much
    hopeless.
    Chuck Chopp
    ICQ # 22321532
    Chuck Chopp, Feb 9, 2004
    #6
  7. cessna
    cessna Guest
    Try
    http://www.nteinc.com/
    NTE Electronics, Inc. Web Site, Welcome
    it gives C3198 = NTE85
    > K-232
    > C3198
    > Y
    > TIA,
    > Chuck
    cessna, Feb 12, 2004
    #7
    1. Advertisements
Similar Threads
  1. Mike
    Need cross reference to RCA 70s transistor
    Mike, Aug 1, 2003, in forum: Electronic Components
    5
    4,272
  2. Ray
    3
    1,167
    Jim Adney
    Feb 1, 2004
  3. Replies:
    3,450
    Watson A.Name - \Watt Sun, the Dark Remover\
    Nov 20, 2004
  4. user
    hp part cross reference
    user, Jan 25, 2005, in forum: Electronic Equipment
    3
    1,155
  5. Golf
    Help needed for transistor cross reference
    Golf, Sep 15, 2007, in forum: Electronic Repair
    8
    1,274
    Michael A. Terrell
    Sep 28, 2007
Loading...
Share This Page
