Transistor base as a diode
Discussion in 'Electronic Components' started by Gazza, Nov 29, 2006.
  1. Gazza
    Gazza Guest
    Hello,
    I have seen several schematics where a transistor base has been used as
    a diode where the base is also short circuited to the collector (NPN).
    Please can anybody tell me why this is done and what the benefits are?
    Many thanks in advance.
    Gary
    Gazza, Nov 29, 2006
    #1
    1. Advertisements
  2. Gazza
    Bill S. Guest
    In article <>,
    says...
    The most common case that comes to mind is a current mirror circuit,
    where you need an input diode with essentially the same I/V curve as
    your output transistor.
    Bill S., Nov 29, 2006
    #2
    1. Advertisements
  3. Gazza
    ian field Guest
    "Bill S." <> wrote in message
    news:...
    > In article <>,
    > says...
    The way I read that, is as the OP mentioning a transistor with its CB
    shorted and the BE used as a diode - as opposed to in a configuration such
    as a CM. One application that springs to mind is that it yields a slightly
    lower Vf than a regular diode, the collector will begin to draw current at a
    VBE of around 0.5V. This is also very dependent on temperature, I recall
    that the old Germanium AC128 was often used in this way as a temperature
    compensator in the convergence panels of old delta-gun CTVs. Also most Si
    transistors exhibit a zener voltage in reverse - usually around 5V or so.
    ian field, Nov 30, 2006
    #3
  4. Gazza
    Joerg Guest
    > news:...
    >>In article <>,
    >> says...
    Sometimes the reason is much more mundane: Logistics. If the board
    doesn't need many diodes but already has transistors then using a
    transistor instead can reduce the number of BOM line items by one. Saves
    inventory costs, rigging costs etc.
    Regards, Joerg
    http://www.analogconsultants.com
    Joerg, Dec 1, 2006
    #4
  5. Gazza
    Chris Jones Guest
    > news:...
    >> In article <>,
    >> says...
    > as a CM.
    That is the same configuration, for the input side of the current mirror.
    > a VBE of around 0.5V. This is also very dependent on temperature, I recall
    But if you ever make them conduct in reverse like this (as a Zener) then
    those devices should be treated as suspect parts from then on. It has been
    alleged to do funny things to the noise performance etc. Certainly on some
    IC processes it is frowned upon to let that junction break down, even at
    low current levels.
    Chris
    Chris Jones, Dec 2, 2006
    #5
  6. Gazza
    Guest
    Gazza wrote:
    > Hello,
    The logarithm characteristics of a perfect diode are shared by this
    kind
    of connected transistor; so-called 'ideal' diode behavior is used in
    logarithm
    converters, and few 'switch' diodes (which are optimized for low
    capacitance) or
    rectifier diodes (which are optimized for high currents) can compete
    with
    a good low-noise transistor.
    , Dec 4, 2006
    #6
    This is sometimes called a "super diode"; it has a maximum current
    rating equal to the maximum collector current of the transistor, and
    tends to have a nice low forward voltage drop at moderate currents
    compared with average small signal diodes, but the main advantage is
    that the diode characteristics match the characteristics of other
    transistors in the circuit so you get (for example) good current mirrors
    , especially if both are part of the same IC, so good thermal tracking
    and in some situations low distortion or little error over a wide
    operating current range.
    Mark A
    Mark Aitchison, Feb 10, 2007
    #7
  8. Gazza
    Eeyore Guest
    It avoids much of the IR voltage drop of using the b-e diode alone since most of
    the current flows c-e.
    Graham
    Eeyore, Feb 10, 2007
    #8
  9. Gazza
    Jamie Guest
    > Mark A
    They make pretty good Zeners also if you need one around that voltage
    region that is heat sinkable! :)
    "I'm never wrong, once i thought i was, but was mistaken"
    Real Programmers Do things like this.
    http://webpages.charter.net/jamie_5
    Jamie, Feb 10, 2007
    #9
    1. Advertisements
Similar Threads
  1. Ken
    Transistor amplifier -- base voltage?
    Ken, Jan 24, 2004, in forum: Electronic Basics
    7
    505
    Gareth
    Jan 25, 2004
  2. Ebrahim
    2,106
    Ebrahim
    Jun 13, 2009
  3. Victor Roberts
    Pin-base vs. screw-base or whatever?
    Victor Roberts, Apr 14, 2007, in forum: Lighting
    9
    1,917
  4. Andrew Holme
    Common base with base series resistor
    Andrew Holme, Feb 8, 2010, in forum: Electronic Design
    1,805
    Andrew Holme
    Feb 8, 2010
  5. dexterdev
    6
    1,162
    jackorocko
    Feb 12, 2012
Loading...
