Transformer lead color
Discussion in 'Electronic Basics' started by Stumpy, Sep 3, 2006.
  1. Stumpy
    Stumpy Guest
    I found a power transformer in my garage which I need to use. Primary wires
    are black. On the other side it has 2 red wires and 2 green wires.
    Is there some standard color code for transformer wire?
    Only ID on case is 710-4235-03 and then 549-7710.
    Have not found a part # reference so I guess trial and error measurements
    are next.
    Stumpy, Sep 3, 2006
    #1
    1. Advertisements
  2. Stumpy
    Stumpy Guest
    If it matters I have 8 ohms accross the black wires, 4 ohms accross the red
    ones, and 0.5 accross the green ones. Infinity accross any non-matching
    colors.
    Stumpy, Sep 3, 2006
    #2
    1. Advertisements
  3. Ralph Mowery
    Ralph Mowery Guest
    "Stumpy" <> wrote in message
    news:19pKg.13849$...
    >wires are black. On the other side it has 2 red wires and 2 green wires.
    > are next.
    Usually the 2 black wires are the primary as you mentioned. The red wires
    are high voltage wires. Could be almost any voltage , most likely from about
    120 to 500 volts. While not on your transformer, if there was a third red
    wire with a stripe on it, it would be the center tap . The green wires are
    often called the filiment winding. Usually 6.3 or 12.6 volts AC if the
    primary is connected to 120 volts.
    Ralph Mowery, Sep 3, 2006
    #3
    > colors.
    I would bet a dollar that the black wires are the primary, the red
    wires are a medium voltage output (less than the primary), while the
    green pair are a lower output voltage.
    John Popelish, Sep 3, 2006
    #4
  5. "Stumpy" <> wrote in message
    Connect the black wires to 12 VAC and measure the other voltages.
    Homer J Simpson, Sep 3, 2006
    #5
  6. Stumpy
    Stumpy Guest
    > I would bet a dollar that the black wires are the primary, the red wires
    > are a medium voltage output (less than the primary), while the green pair
    Yeah, You'd get the dollar. I hooked it up to house AC and got 23Vac on
    red, and 14Vac on green.
    Soon as I dust off a Variac I've got an adjustable DC power supply.
    Stumpy, Sep 3, 2006
    #6
  7. ehsjr
    ehsjr Guest
    You might want to consider adding a couple more
    components to it.
    Ed
    ehsjr, Sep 3, 2006
    #7
  8. Stumpy
    Stumpy Guest
    > components to it.
    Of course, I made the bridge rectifier circuit with a 2 capacitor and
    inductor filter, but blew up capacitors when I tried to feed it with a
    dimmer switch. This second go-round is just to incorporate a step-down
    transformer and an autotransformer in place of the dimmer switch. Trying to
    learn from my mistakes.
    Stumpy, Sep 3, 2006
    #8
    1. Advertisements
Similar Threads
  1. dolbowent
    Lead to lead free ROHS help?
    dolbowent, Nov 1, 2005, in forum: Electronic Components
    571
    dolbowent
    Nov 1, 2005
  2. Lead-Free vs. 63/37 tin/lead solder
    , Jun 7, 2006, in forum: Electronic Repair
    29
    3,672
    Arfa Daily
    Jun 17, 2006
  3. dolbowent
    Lead to Lead Free ROHS Help?
    dolbowent, Nov 1, 2005, in forum: Hobby Electronics
    438
    dolbowent
    Nov 1, 2005
  4. N_Cook
    3
    1,389
  5. roltex_rohit123
    sealed lead acid to flooded lead acid battery
    roltex_rohit123, Apr 29, 2010, in forum: Electronic Projects
    16
    2,407
    roltex_rohit123
    May 10, 2010
Loading...
