Toshiba vcr model:M-68C plays for 5 seconds then stops
Discussion in 'Electronic Repair' started by sidneybek@yahoo.com, Jun 18, 2006.
  1. Guest
    Toshiba 4 head hi-fi stereo vcr model:M-68C,year:Aug 1999,CSA File
    No:LL38329 (Samsung),pcb board model:M-685 (also VR8800),the vcr
    plays,fast forwards or rewinds for about 5 seconds.During play the
    idler wheel does not move only the capstan motor and pulley therefore
    the vcr eats tape.
    I cleaned the mode switch and inspected and cleaned the idler wheel
    assembly but no go,according to a repair tip from:
    http://intrepid-video.com/database/toshiba.htm
    for a model:M-65C it states that the take up reel sensor (photo
    interrupter) pcb location:pT601=Toshiba # 70796241 or generic # SG-105L
    is defective,is this true? if so can someone verify the part # for my
    model as the above part is for model:M-65C as I looked at the part #
    look up sites below but could not find it:
    Part # lookup sites does not list it:
    http://www.tritronicsinc.com/lookup_cs.htm
    http://www.wehaveparts.com
    http://www.partsolver.com/Default.asp
    http://atv.partsearch.com/search.asp
    http://www.vancebaldwin.com
    http://brandsmartusa.partsearch.com/default.aspx
    http://www.ceitron.com/semi/ceisemi.html
    http://www.pacparts.com/scripts/whlsl.cfm
    http://www.doubleo.com/ecom/main.php
    http://www.mcmelectronics.com
    http://www3.sears.com
    http://www4.sears.com
    http://www.radioshack.com/ProdSupport/ProductSupport.asp
    http://www.radioshack.ca/en/templates/partlist.asp
    http://www.timelapsesupply.com
    http://www.pasc.panasonic.com/epartr
    http://www.jvcservice.com
    http://parts.pioneerelectronics.com/
    http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search?OpenForm
    I also look for my model at these free Toshiba service manual download
    sites but could not find mine:
    http://www7.toshiba.com/secured/tass/technical/vcr/vcrconts.asp
    http://www7.toshiba.com/index2.htm
    http://www7.toshiba.com/secured/tass/technical/dvd/dvdconts.asp
    http://tacpservice.toshiba.com/TACP/training/VCR/vcr06f.pdf
    http://tacpservice.toshiba.com/tacp/training/TV/MM20E45f.pdf
    http://www.tacpservice.toshiba.com/TACP/training/module1/Mod1sg1.html
    http://www.tacpservice.toshiba.com/tacp/training/Module3/Web/Mod3Titl.html
    http://www.tacpservice.toshiba.com/tacp/training/Module3/NTDMod3.html
    http://tacpservice.toshiba.com/tacp...omprehensive background progressive video.pdf
    http://www7.toshiba.com/secured/tass/technical/dvd/SD5109.pdf
    http://www7.toshiba.com/secured/tass/technical/dvd/SD9100.pdf
    Nor could I find it here:
    http://www.schematicsforfree.com
    http://www.schematicsforfree.mattsoft.net
    http://schematicsforfree.mattsoft.net
    http://schforfree.seedhost.com
    http://www.epanorama.net/schematicsforfree
    then click on "click here to see the files" followed by "video"
    followed by "products".Thanks in advance for help.
    Sidney
    E-mail:sidneybek(at)yahoo.com
    Dartmouth,Nova scotia
    Canada
    , Jun 18, 2006
    #1
    1. Advertisements
  2. Franc Zabkar
    Franc Zabkar Guest
    On 18 Jun 2006 06:04:28 -0700, put finger to
    keyboard and composed:
    >the vcr eats tape.
    If the idler wheel does not move, then the takeup reel remains
    stationary. The uP detects this via the reel sensor and then shuts
    down the mechanism. In short, there appears to be nothing wrong with
    your reel sensor. Instead I'd be looking for a slipping belt or
    slipping clutch or sticky brake pads. Also check that all rotating
    parts move freely.
    To assist in troubleshooting, and to avoid damaging your tapes, you
    could make a dummy "cheater" cassette and turn the reel(s) by hand.
    See http://www.repairfaq.org/sam/vcrfaq.htm#vcrcascheat
    You should be able to find a point where the driving part is turning
    but the driven part is not. Test the torque with your fingers. If you
    suspect a motor, measure the voltage at its terminals.
    - Franc Zabkar
    Please remove one 'i' from my address when replying by email.
    Franc Zabkar, Jun 19, 2006
    #2
    1. Advertisements
Similar Threads
  1. Sarah
    VCR picture clear & then noisy every 5 seconds
    Sarah, Mar 25, 2005, in forum: Electronic Repair
    11
    594
    Guest
    Apr 5, 2005
  2. Juneappal
    7
    739
    Juneappal
    Mar 24, 2006
  3. Replies:
    749
    Mark D. Zacharias
    Jul 29, 2007
  4. Hy
    3
    719
  5. riget
    HP vs17e turns on for 3 seconds then goes off
    riget, Mar 20, 2010, in forum: Electronics Repair
    19
    5,693
    55pilot
    Mar 25, 2010
Loading...
