Television remote eye
Discussion in 'Beginner Electronics' started by Charles Pisano, Apr 30, 2004.
  1. The eye on my 19 inch Phillips Mag TV does not receive the signal from
    the remote unless I am right up next to the tv with the remote. Do I
    need an new eye? Or can I clean it out somehow?
    The remote works fine with my other phillips mag tv and it doesn't even
    belong to the other one.
    I have to repair it as it is the only tv that doesn't hurt my eyes.
    Also on some days it will work for like 5 minutes and then quit
    again????
    TIA
    CP
    #1
    1. Advertisements
  2. Art
    Art Guest
    Suggest having a technician check the IR Pickup or just have them change it.
    "Charles Pisano" <> wrote in message
    news:...
    > again????
    > TIA
    > CP
    Art, Apr 30, 2004
    #2
    1. Advertisements
  3. JeffM
    JeffM Guest
    > Charles Pisano
    Did it ever work properly on the 19"?
    Have you twiddled the batteries around to make better contact?
    Have you cleaned the battery contacts with an eraser?
    Have you put brand new batteries in the remote?
    >can I clean [the eye] somehow?
    Have you cleaned the bezel (lens) on the remote?
    Definately clean the bezel over the eye on the TV.
    If possible, clean the back side of each.
    Was the equipment in an environment with (tobacco) smoke?
    JeffM, Apr 30, 2004
    #3
    1. Advertisements
Similar Threads
  1. raghu
    to sense eye is open or closed
    raghu, Dec 6, 2003, in forum: General Electronics
    446
    N. Thornton
    Dec 8, 2003
  2. Dan
    electric eye solution
    Dan, Jan 15, 2004, in forum: Electronic Design
    8
    637
  3. Winfield Hill
    Laser injures Delta pilot's eye
    Winfield Hill, Oct 7, 2004, in forum: Electronic Design
    469
    Paul Burridge
    Oct 9, 2004
  4. R.Lewis
    led & eye safety
    R.Lewis, Mar 3, 2005, in forum: Electronic Design
    48
    1,205
    John Woodgate
    Mar 8, 2005
  5. 1984 GE television 19", w/remote
    , Mar 3, 2007, in forum: Electronic Repair
    3
    403
Loading...
