Tektronix 465B Focus Problem
Discussion in 'Electronic Repair' started by mike@westendstudio.com, Feb 3, 2006.
  1. Guest
    The traces on my 465B scope are bright but a bit out of focus...I have
    heard of resistor problems in the focus control voltage divider in
    other models that have caused this same problem. I checked the CRT
    schematic and noticed the resistors in question are in a resistor
    network of 4 resistors.
    Any thoughts on this would be helpful.
    Mike Miller
    Kansas City
    , Feb 3, 2006
    #1
    1. Advertisements
  2. James Sweet
    James Sweet Guest
    > Thanks
    > Mike Miller
    > Kansas City
    What's the focus control do when you adjust it?
    James Sweet, Feb 3, 2006
    #2
    1. Advertisements
  3. Guest
    The focus control seems to function correctly, but you can't quite get
    the trace clear and sharp.
    , Feb 3, 2006
    #3
  4. Jim Yanik
    Jim Yanik Guest
    wrote in
    news::
    > Thanks
    > Mike Miller
    > Kansas City
    The thick-film resistor could be out of spec,or you could also have
    astigmatism problem,or noise in the power supplies.
    First,check the cathode V (-2960,IIRC)to see that it's in spec.Part of the
    thickfilm network is the HV divider that sets the right voltage,part is the
    focus network.(doublesided thickfilm)
    465B was not known for a really sharp trace-it has a mesh lens at the end
    of the electron gun structure.
    Jim Yanik
    jyanik
    at
    kua.net
    Jim Yanik, Feb 3, 2006
    #4
    1. Advertisements
Similar Threads
  1. Douglas Scott
    Tektronix 465b Help
    Douglas Scott, Jan 5, 2005, in forum: Electronic Equipment
    967
    Douglas Scott
    Jan 8, 2005
  2. Looking for Tektronix 465b Parts
    , Apr 29, 2005, in forum: Electronic Equipment
    4
    1,279
    tekamn
    May 4, 2005
  3. ktl
    Tektronix Oscilloscope 465B Problems
    ktl, Sep 1, 2005, in forum: Electronic Repair
    10
    1,646
  4. edson
    Tektronix 465B scope repair in Ireland or UK.
    edson, Jan 27, 2007, in forum: Electronic Equipment
    3
    543
    Chris Jones
    Jan 28, 2007
  5. edson
    edson, Jan 27, 2007, in forum: Electronic Repair
    504
    Chris Jones
    Jan 28, 2007
Loading...
