Tek 7904A rapid ticking - no HT...
Discussion in 'Electronic Repair' started by Mike Deblis, Jan 2, 2006.
  1. Mike Deblis
    Mike Deblis Guest
    Bad day at the office (shack) - two failure in one day ;-(
    I recently turned on my trusty 7904A after perhaps 2 years of non-use...
    It briefly displayed both traces (linup is 2 x 7A26, 7B92A, 7B53A), and
    then the traces dissapeared after about 10 seconds and the scope is
    issuing a rapid "ticking" at about 200 Hz - more of a sharp-edged buzz
    really. Now when I turn it on, I only get the buzz/tick.
    Removing all the plugins makes no difference...
    I'm not a HT person. Ideas? If it helps, I'm in the Uk.
    Many thanks
    #1
    1. Advertisements
  2. Mike Deblis
    Guest
    Sounds like bad filter caps in pwr supply
    , Jan 2, 2006
    #2
    1. Advertisements
  3. Mike Deblis
    Steven Swift Guest
    "Mike Deblis" <> writes:
    >Hi,
    >Many thanks
    The 7904 has an overcurrent protection circuit, which will cause the
    ticking. This is a good thing.
    First step, remove all the plug-ins. Still get the ticking? If yes, you
    can isolate boards by removing connectors, one board at a time.
    I had one of these fail that turned out to be a bad diode on the Z-axis
    board.
    Most likely problem: a bad cap on one of the boards. The tantalums go
    bad and Tek used them by the truck load.
    Good luck.
    Steve.
    Steven D. Swift, , http://www.novatech-instr.com
    NOVATECH INSTRUMENTS, INC. P.O. Box 55997
    206.301.8986, fax 206.363.4367 Seattle, Washington 98155 USA
    Steven Swift, Jan 3, 2006
    #3
  4. Mike Deblis
    Keyser Soze Guest
    "Mike Deblis" <> wrote in message news:dpbrju$7s$-infra.bt.com...
    > Hi,
    > then the traces disappeared after about 10 seconds and the scope is
    > Many thanks
    >><> wrote in message news:...
    It could also be that one of the high voltage power supplies arching to ground.
    Check the HV wires for breaks in the insulation.
    The post deflection accelerator is very high voltage so try not to get killed.
    Keyser Soze, Jan 4, 2006
    #4
  5. Mike Deblis
    Fred Abse Guest
    > board.
    I've had that one, too.
    A good plan can be to remove each receptacle, one at a time from the PSU
    output cable socket molding to isolate each rail. Pull the sensing
    feedback plug first, though, or you can find that a shorted rail will fry
    one of the sensing bypass resistors. The PSU will regulate, albeit a bit
    poorly, with the sensing disconnected, because of those same bypass
    resistors.
    The PSU won't run properly with no load at all, BTW.
    There are some 100uF (??) electrolytics on the 15V rails on the interface
    PCB that can go short under operating conditions, but appear OK on low
    voltage. They are a bitch to get at.
    Five'll get you ten that the PSU itself is OK.
    "Electricity is of two kinds, positive and negative. The difference
    is, I presume, that one comes a little more expensive, but is more
    durable; the other is a cheaper thing, but the moths get into it."
    (Stephen Leacock)
    Fred Abse, Jan 6, 2006
    #5
  6. Mike Deblis
    Mike Deblis Guest
    "Keyser Soze" <> wrote in message
    news:lkFuf.46962$q%...
    > > Hi,
    > > Many thanks
    > >><> wrote in message
    news:...
    ground.
    killed.
    Is Jim Yanik (sp?) still around?
    Mike Deblis, Jan 6, 2006
    #6
  7. Mike Deblis
    Jim Yanik Guest
    news:dpmrhd$6n5$-infra.bt.com:
    >> > Hi,
    >> > non-use...
    >> > and then the traces disappeared after about 10 seconds and the
    >> > scope is issuing a rapid "ticking" at about 200 Hz - more of a
    >> > sharp-edged buzz really. Now when I turn it on, I only get the
    >> > buzz/tick.
    >> > Many thanks
    >> >><> wrote in message
    > news:...
    >> to
    > ground.
    >> get
    > killed.
    > Thanks
    The fast ticking,IIRC,indicates a failure in the PS itself,like a shorted
    diode,bad electrolytic,open switcher xstr(s).Probably a primary-side
    failure.
    I strongly advise reading the serivce manual's circuit description on the
    PS.
    If you don't have a svc manual,then I would not attempt repair;it's a very
    complex series-resonant switching supply.There are under/overvoltage
    lockout circuits,several current and voltage feedback loops.
    Jim Yanik
    jyanik
    at
    kua.net
    Jim Yanik, Jan 7, 2006
    #7
    1. Advertisements
Similar Threads
  1. BFoelsch
    Tek 7904 vs 7904A
    BFoelsch, May 1, 2005, in forum: Electronic Equipment
    1,974
    tekamn
    May 4, 2005
  2. Mike Deblis
    Mike Deblis, Jan 2, 2006, in forum: Electronic Equipment
    12
    944
    Fred Abse
    Jan 22, 2006
  3. LCD monitor - PSU ticking (no startup)
    , Sep 3, 2006, in forum: Electronic Repair
    6
    751
  4. jch
    651
  5. New audio & HT forum: Oz Audo & HT
    , Mar 10, 2006, in forum: Hobby Electronics
    603
Loading...
