Strange vertical lines on Mitsubishi screen
Discussion in 'Electronic Repair' started by GPG, Apr 8, 2005.
  1. GPG
    GPG Guest
    My Mitsubishi television has developed a strange, and intermittent, feature
    : namely, vertical black lines having the following characteristcs :-
    a) they are only about 1/5 of the screen height in length
    b) they tend to be equidistant, horizontally
    c) they spread, until only small rectangular areas of the picture are
    visible.
    d) often, they vanish leaving a perfect picture.
    e) a slap on the chassis usually cures it for a few minites.
    In the past, but not recently, there was a tendency to develop a 'circular'
    (ova?l) colour distortion, which was solved by switching on and off. Not
    seen recently, though. I cannot see a similar phenomenon described ig the
    FAQ.
    All help will be gratefully received.
    GPG
    GPG, Apr 8, 2005
    #1
    1. Advertisements
  2. sofie
    sofie Guest
    GPG:
    You should do a google groups search for "Mitsubishi Vertical Problem"
    ...... lots of hits and some good troubleshooting suggestions. Also you
    should go to the website for this newsgroup at
    http://www.repairfaq.org/
    There, with some searching, you will find a wealth of television
    troubleshooting and repair information..... along with IMPORTANT SAFETY
    information. If, after reading through all of the above information, you
    are still not certain how to proceed you should TAKE your television to a
    service shop for at the very least a repair cost estimate so you can make an
    intelligent repair decision with facts instead of Internet or telephone wild
    guesses by folks who don't even have the model number of your
    television...... and in the future ALWAYS post the model number if you are
    hoping for anything close to specific repair suggestions.
    At this point you need to try the google search and the repairfaq website,
    dust off your multi-meter, ESR meter, and maybe an oscilloscope and perform
    some "in the back of the television" troubleshooting, testing and
    inspection.
    Good luck with your repair.... or getting a repair cost estimate.
    Best Regards,
    Daniel Sofie
    Electronics Supply & Repair
    "GPG" <> wrote in message
    news:42569ff6$0$42301$...
    feature
    > visible.
    'circular'
    the
    > FAQ.
    > GPG
    sofie, Apr 8, 2005
    #2
    1. Advertisements
  3. Art
    Art Guest
    May even be the infamous PIP problem creeping in. Also related to lousy smd
    caps.
    "Robert De NERO" <> wrote in message
    news:...
    > Likely bad capacitors, or get sum 1 to solder the vertical IC.
    > feature
    >> visible.
    > 'circular'
    > the
    >> FAQ.
    >> GPG
    Art, Apr 9, 2005
    #3
  4. Likely bad capacitors, or get sum 1 to solder the vertical IC.
    feature
    > visible.
    'circular'
    the
    > FAQ.
    > GPG
    Robert De NERO, Apr 9, 2005
    #4
  5. JANA
    JANA Guest
    If slapping the set, cures the fault for a while, then it is obvious that
    there is a cold solder connection, or something is loose!
    JANA
    _____
    feature
    > visible.
    'circular'
    the
    > FAQ.
    > GPG
    JANA, Apr 9, 2005
    #5
    1. Advertisements
Similar Threads
  1. Derek
    Vertical lines on laptop LCD display
    Derek, Sep 22, 2003, in forum: Electronic Repair
    3
    1,093
    Andy Cuffe
    Sep 23, 2003
  2. Ryan Alswede
    Philips 25" TV vertical lines, can't find the problem
    Ryan Alswede, Oct 11, 2003, in forum: Electronic Repair
    464
    Ryan Alswede
    Oct 12, 2003
  3. cherry6905
    5
    676
    Leonard Caillouet
    Oct 9, 2005
  4. Mac
    9
    868
    Mike Berger
    Mar 17, 2006
  5. Replies:
    4,965
Loading...
