STK 361 weaker IC as power amp than LA 4440 STK 361, Amplifier
Discussion in 'Electronic Design' started by cozz in or out, Sep 27, 2007.
  1. Hi ,
    i dreamt of a good poer amp for long and found circuit that tells
    360W amp
    had input for all like tuner ,cd etc
    I hv assembled it .however after running the power amp with some
    inputs
    i was surprized to see that the AMP is very weak ..
    it needed 15a-0-15a supply ..that cosed 20% more
    whole amp kit costed 40% more ...finally I to discover that it is v
    poor
    as compared to kits with 4440 ICs ..
    Is STK 361 weaker IC as power amp than LA 4440 ,please coment ..
    #1
    1. Advertisements
  2. Guest
    On Sep 26, 11:19 pm, cozz in or out <> wrote:
    > Hi ,
    > 360W amp
    > inputs
    > poor
    do you have a power supply that can provide at least 720 W? Class AB
    amplifiers are only 50% efficient or so, so you'll need to provide
    double the juice it needs from your power supply.
    , Sep 27, 2007
    #2
    1. Advertisements
  3. On Sep 27, 8:37 pm, wrote:
    > On Sep 26, 11:19 pm,cozz in or out<> wrote:
    > > Hi ,
    > > 360W amp
    > > inputs
    > > poor
    thanks ,
    360 w PMPO that was the title of the circuit published in
    'Electronics for you ' magazine ...STK 361 is some 25 or 50w rms
    chip i think ..
    Is the power supply that might be the cause ??
    the Amp was running fine ...amplifying but But very poor Output.....
    (i hope a power supply *stronger* than normal PSs of 12-0-12 3 Amp LA
    LA4440 based amps should be sufficient ])
    cozz in or out, Oct 10, 2007
    #3
  4. Eeyore
    Eeyore Guest
    > > > Hi ,
    > > > 360W amp
    > > > inputs
    > > > poor
    > thanks ,
    > chip i think ..
    Neither are even remotely anywhere near 360W ! You should be able to see that
    from the power supply voltage !
    http://www.electronica.ro/audio/LA4440.shtml - it's 19W
    The magazine is LYING.
    Graham
    Eeyore, Oct 10, 2007
    #4
  5. On Oct 10, 12:03 pm, Eeyore <>
    > > > > Hi ,
    > > > > 360W amp
    > > > > inputs
    > > > > poor
    > > thanks ,
    > > chip i think ..
    > Graham- Hide quoted text -
    > - Show quoted text -
    that 360 PMPO wattage is a marketig term i know .... u can see SONY
    6000w music system being sold in nearby show room ..which takes 40-80w
    power while running ... :)
    but the query still remains unanswered ... why is STK 361 is giving
    weak output ..than LA 4440 [i know LA4440 gives sufficient amount of
    output for normal home use ..i wanted a more powerful AMP ...and ended
    up with STK 361]..
    i have heard that STK 361 is used with SONODYNE soundsystems....must
    be having good power inside ....
    #5
  6. Guest
    On Sep 27, 3:19 pm, cozz in or out <> wrote:
    > Hi ,
    > 360W amp
    > inputs
    > poor
    Dears
    I think you should try on KIA6216H ICs, May be it gives you better
    result .
    I.K.KHAN
    , Oct 18, 2007
    #6
    1. Advertisements
Similar Threads
  1. Timo Rinne
    STK 2125 or STK 2129
    Timo Rinne, Oct 29, 2003, in forum: Electronic Components
    1,730
    Timo Rinne
    Oct 29, 2003
  2. feklar
    3
    924
    Christopher Bailey
    Aug 10, 2003
  3. LB
    4
    1,541
  4. Jack
    Do batteries go weaker if not used ?
    Jack, Nov 23, 2006, in forum: Hobby Electronics
    21
    826
    Bob Parker
    Dec 8, 2006
  5. majdi
    5
    899
    Harald Kapp
    Mar 12, 2014
Loading...
