Static Sound in Radio Volume Control
Discussion in 'Electronic Repair' started by Michael, Dec 25, 2008.
  1. Michael
    Michael Guest
    Over time, the volume controls of all my clock radios always develop a loud
    static sound whenever I adjust the volume. Is there a remedy for this?
    Michael
    #1
    1. Advertisements
  2. Michael
    krw Guest
    In article <>,
    says...
    > A really good control cleaner, or all new pots.
    A new and better radio (with digital pots) is the only permanent
    solution.
    Keith
    krw, Dec 25, 2008
    #2
    1. Advertisements
  3. Michael
    N_Cook Guest
    Michael <> wrote in message
    news:MPA4l.963$...
    loud
    > Thanks,
    > Michael
    Desolder the pot or sometimes enough access to to
    do the following without desoldering
    Mark with felt tip
    the relative positions of the sub parts, bend out
    the retaining flaps of the casing metal with a small
    screwdriver.
    Dismantle the pot down to the carbon track clean/degrease.
    Where the track is not too bad , just worn in arcs.
    Bend, out or in whichever shows most fresh track, the wiper
    blade/blades to use a different
    part of track. If the wiper support can be wedged
    away from the track then bend the wiper to give more
    contact force. If the rivets have slackened on the
    paxolin then squash with an old pair of basic red/blue/yellow single
    action crimp pliers. To get to the wiper rivet
    grind down the the interfering bulges a bit between the
    red and blue sections.
    Diverse Devices, Southampton, England
    electronic hints and repair briefs , schematics/manuals list on
    http://home.graffiti.net/diverse:graffiti.net/
    N_Cook, Dec 25, 2008
    #3
  4. Michael
    Ian Jackson Guest
    In message <givibm$u2o$>, N_Cook
    <> writes
    >news:MPA4l.963$...
    >loud
    >> Thanks,
    >> Michael
    >Mark with felt tip
    >screwdriver.
    All this for a clock radio???
    Ian
    Ian Jackson, Dec 25, 2008
    #4
  5. The OP says "all my clock radios". That's odd. I've never had /all/ the pots
    in the equipment I've owned become scratchy.
    Obviously, cleaning the pot should fix the problem. But I suspect the OP
    lives in a dusty/dirty environment, or is a heavy smoker.
    William Sommerwerck, Dec 25, 2008
    #5
  6. Michael
    Michael Guest
    Thank you to all who responded.
    Michael
    "Michael" <> wrote in message
    news:MPA4l.963$...
    loud
    > Thanks,
    > Michael
    Michael, Dec 26, 2008
    #6
  7. Michael
    z Guest
    > Thanks,
    > Michael
    beside control cleaner, basically, it's a good idea to turn every
    control through the whole range of movement and switch every switch
    on and off on every piece of equipment you own that doesn't have the
    newfangled rubber key type things, every week or two. keeps them from
    getting spotty contact with dust, gunk from the air, particles from
    wear, etc. over the years, wipers on pots, switches, relays, etc. have
    evolved to do this pretty well.
    given that clock radios don't have the volume adjusted a large amount,
    they don't get this treatment the way older type equipment where the
    volume was turned down to zero to switch the thing off did.
    the other thing that happens, however, is that there gets to be extra
    wear in the small area of a control which is actually used and as a
    result contact is spotty; no cure for that.
    z, Dec 26, 2008
    #7
  8. Michael
    Jeroni Paul Guest
    > Why do poeple write ONE (1)?  Is this because some people can't read
    > numerals?
    It is to emphatize that it must be done in one second. Otherwise it
    might go unnoticed.
    Jeroni Paul, Jan 2, 2009
    #8
  9. Michael
    Jeroni Paul Guest
    > Thanks,
    > Michael
    Quick and cheap solution, keep adjusting the control up and down until
    it stops scratching.
    #9
  10. Michael
    IanM Guest
    > No, it happens to mine too. Clock radios are usually made VERY cheaply.
    Or it could be due to fine dust from your parrots' feathers and droppings.
    Ian Malcolm. London, ENGLAND. (NEWSGROUP REPLY PREFERRED)
    ianm[at]the[dash]malcolms[dot]freeserve[dot]co[dot]uk
    [at]=@, [dash]=- & [dot]=. *Warning* HTML & >32K emails --> NUL:
    IanM, Jan 2, 2009
    #10
  11. "Peter Hucker" <> wrote in message
    news:eek:...
    >> pots in the equipment I've owned become scratchy.
    >> OP lives in a dusty/dirty environment, or is a heavy smoker.
    That must be the problem. I don't own cheap clock-radios.
    William Sommerwerck, Jan 2, 2009
    #11
  12. Michael
    krw Guest
    On Fri, 2 Jan 2009 15:13:21 -0800, "William Sommerwerck"
    >news:eek:...
    It must be another of that PHucker's many problems. I have a few
    cheap ones around and there are no pot problems. Of course good ones
    don't use crappy pots, so that is a better solution.
    krw, Jan 3, 2009
    #12
  13. >> That must be the problem. I don't own cheap clock-radios.
    > A clock radio doesn't strike me as an item one would spend
    > a lot of money on.
    There have been some nice ones, especially from GE in the late 70s and early
    80s. GE produced the first clock-radio with an electronic display (1972),
    and the first with digital electronic tuning (1980). They were not cheap. I
    have both.
    William Sommerwerck, Jan 3, 2009
    #13
  14. > I just leave the volume in one place all the time.
    That's virtually guaranteed to produce a noisy control.
    #14
    1. Advertisements
Similar Threads
  1. jack
    out-of-control volume control -
    jack, May 17, 2006, in forum: Electronic Design
    4
    518
  2. Dean
    Static on amplifier, not volume related
    Dean, Dec 15, 2004, in forum: Electronic Repair
    4
    3,587
    Asimov
    Dec 16, 2004
  3. Dean
    Continued: Static on amp, not volume related
    Dean, Dec 16, 2004, in forum: Electronic Repair
    540
    El Meda
    Dec 17, 2004
  4. Replies:
    17
    2,370
    TimPerry
    Sep 20, 2005
  5. Replies:
    3
    725
Loading...
