SONY DVD Player - Intermittant won't load disc
Discussion in 'Hobby Electronics' started by Chromatik, Feb 17, 2004.
  1. Chromatik
    Chromatik Guest
    Hi all,
    I have a SONY DVP-NS305 DVD player that is around 12-18 months old.
    Recently it has stopped recognising discs. When DVDs or CDs (originals not
    burnt) are inserted the player makes a noise like it is seeking for a short
    while on and off (~60secs) then reports "Cannot Play This Disc".
    A month or so ago I put a CD in and it didn't see it, took it out to check
    for scratches (there weren't any) then put it back and it worked. On
    another occasion a CD that was playing stopped mid track without error.
    All DVDs are Region 4 that have been used sucessfully previously.
    Both the CDs and the DVDs I have tried are pristine, scratch/dust free.
    Inside the drive bay looks clean/free of dust.
    Any suggestions on remedies before I take it to the doctor?
    Many thanks
    #1
    1. Advertisements
  2. Chromatik
    amstereo Guest
    sounds like te rom drive is either failing, or needs a service (read:clean)
    pop the lid off and see if it runs a stock PC dvd-rom (look for the grey 40
    wire flat ribbon cable and a 4 pin PC power plug)
    If it is, then, opening these drives are a little dificult, but not
    impossible.
    If it is a laser mech on a plate type job, then metho and cotton tip
    gentally clean the lense.
    amstereo, Feb 17, 2004
    #2
    1. Advertisements
  3. Chromatik
    Rod Speed Guest
    "Chromatik" <chromatik(at)optusnet.com.au> wrote in message news:4031fae0$0$28870$...
    > Hi all,
    If you smoke, try cleaning the lens with metho carefully.
    Rod Speed, Feb 18, 2004
    #3
  4. Chromatik
    Chromatik Guest
    "Rod Speed" <> wrote:
    > > months old.
    Thanks Rod and amstereo.
    I don't smoke and despite appearing very clean inside I gave the lens a
    gentle once over with a cotton bud and metho, alas the same problem.
    In lieu of alternatives looks like a trip to a doctor in in order. Any
    recommendations for repairers in Sydney (between, say Parramatta/Ryde)?
    Preferrably with free-quotes as I imagine repair bills would come close to
    new players in many cases.
    Thanks.
    Chromatik, Feb 20, 2004
    #4
  5. Chromatik
    Rod Speed Guest
    "Chromatik" <chromatik(at)optusnet.com.au> wrote in message news:40368e03$0$28870$...
    > > > months old.
    Yeah, not usually economic to repair.
    Well worth cleaning the lens if you smoke, but thats about it now.
    Rod Speed, Feb 21, 2004
    #5
    1. Advertisements
Similar Threads
  1. DaveC
    DVD disc compatibility btw computer and DVD player
    DaveC, Mar 26, 2005, in forum: Electronic Equipment
    5
    574
    CWatters
    Mar 27, 2005
  2. Scott N. Weber
    Sony 200 disc dvd player won't read discs
    Scott N. Weber, Oct 12, 2003, in forum: Electronic Repair
    3
    1,621
    Mark D. Zacharias
    Oct 13, 2003
  3. jd
    sony 200 disc changer doesn't see disc
    jd, Sep 6, 2004, in forum: Electronic Repair
    7
    805
  4. DVD Player Won't Release DVD
    , Mar 23, 2007, in forum: Electronic Repair
    5
    663
  5. Gary
    3
    705
Loading...
