Sony CDX-705 10 CD Changer
Discussion in 'Electronics Repair' started by desrv1, Jul 18, 2011.
  1. desrv1
    desrv1
    Jul 18, 2011
    I joined the site for some help. I have a Sony CDX-705 CD changer in my 1998 motorhome. I can't get the CD Magazine to eject so all 10 CD's are stuck in the unit. I can get the unit out of the dash, but don't know what to do once I get it out!
    I'd prefer to repair or replace so I don't leave a large hole in the front of my dash. Is it worth repairing and if not, I also have a good Pioneer 6 CD changer from a car I sold years ago. Problem is, it doesn't fit the space in the dash. If I should use that one, is there an adapter cable that would attach to the Sony cable that is there already?
    Thanks, desrv1
    #1
    1. Advertisements
  2. desrv1
    nepow
    Jul 18, 2011
    69
    Once out of the vehicle you can remove the covers to reveal the cause of the failure. Take your time and don't force anything...may be a jammed cd? also take a look to see if the laser transport is jammed. Not familiar with this model, but some laser chassis assemblies move up to meet the loaded cd and can get stuck upon returning caused by a slipping drive belt!! at worst the fault could be a mechanism timming error... gears or drive commponents moved out of sync. Lastly try "Google" enter the model, could be a common fault? Best of luck Nepow
    nepow, Jul 18, 2011
    #2
    1. Advertisements
  3. desrv1
    desrv1
    Jul 18, 2011
    Problem solved
    Thanks for your response. Since I posted the questions, I checked in the owners manual and it said that if I had unhooked the coach battery terminal, I should press the reset buitton on the Sony Radio. I did that, but, it didn't immediately fix the problem. Fortunately, I had the CD player out of it's spot in the dashboard and I "lightly" (as you suggested) moved it around and jiggled some parts. The magazine did finally eject. I took out the CD's in case it got stuck again. I found one CD that had been put in upside down. Took them all out and replaced several of them slowly and carefully. Tried ejecting each time I added one. Everything started working normally and I put the dash back together.
    Hopefully it will continue to work nomally!! Thanks again for your help.
    desrv1, Jul 19, 2011
    #3
    1. Advertisements
Similar Threads
  1. t@rogers.canada
    Gear for Sony CDX-T62 Changer (with picture link)
    t@rogers.canada, Apr 8, 2004, in forum: Electronic Repair
    924
    t@rogers.canada
    Apr 8, 2004
  2. wing
    repair of SONY CD Changer CDX-A100
    wing, Jun 14, 2004, in forum: Electronic Repair
    725
  3. Sidney
    Sony 10 disc cd changer model:CDX-747X
    Sidney, Nov 19, 2004, in forum: Electronic Repair
    1,255
    Sidney
    Nov 19, 2004
  4. Jumpster Jiver
    Sony CDX-705 Mobile CD Changer
    Jumpster Jiver, Jan 24, 2006, in forum: Electronic Repair
    5
    882
    Jumpster Jiver
    Jan 26, 2006
  5. Jumpster Jiver
    Sony CDX-705 CD Changer - update.
    Jumpster Jiver, Jan 31, 2006, in forum: Electronic Repair
    692
    Jumpster Jiver
    Feb 1, 2006
Loading...
