Soldering to gold and silver metallizations
Discussion in 'Electronic Design' started by Chris Carlen, Jun 20, 2005.
  1. Chris Carlen
    Chris Carlen Guest
    Hi:
    As I understand, Ag and Au may be leached from surfaces when using
    standard Sn63Pb37 and Sn60Pb40 type electronic solders.
    Why is this to be avoided? Does it result in "intermetallic compounds"
    near the interface that compromise mechanical properties?
    Is this enough of a concern that typical gold plated component leads and
    silver plated hook-up wire in general shouldn't be soldered with
    tin-lead, but rather some non-leaching solders such as indium lead
    alloys for gold, or SnPbAg alloys for silver platings?
    Or is it only relevant to specialized applications that place
    substantial mechanical stress or thermal fatigue cycles on soldered joints?
    What is the difference between the issues involved in soldering Ag and
    Au platings, versus thick or solid Ag or Au surfaces?
    Thanks for input.
    Good day!
    _______________________________________________________________________
    Christopher R. Carlen
    Principal Laser/Optical Technologist
    Sandia National Laboratories CA USA
    NOTE, delete texts: "RemoveThis" and "BOGUS" from email address to reply.
    #1
    1. Advertisements
  2. Chris Carlen
    Chris Carlen Guest
    Chris Carlen wrote:
    > Hi:
    > Thanks for input.
    I got some info from Indium Corp about this:
    Eric: Rates of dissolution affect whether issue or not, and vary with
    temp. At 200C, electronics SnPb alloys will dissolve 35u-in/s/unit area
    of gold. For Ag, about 21u-in/s. Au reacts with Sn to form a brittle
    intermetallic. Flash Au plate isn't thick enough to make enough SnAu
    intermetallic to be a problem.
    But for Ag platings, the Ag3Sn intermetallic is actually stronger but
    also less ductile. So it depends. Since the SnPbAg solders contain
    silver, duh, they simply reduce the rate of leaching of Ag from the
    plated surface.
    It would seem that the AuSn intermetallic is generally to be avoided,
    and InPb alloys should be used on gold.
    #2
    1. Advertisements
  3. Chris Carlen
    Ted Edwards Guest
    Back when Tektronix scopes were built with components soldered into
    ceramic tie strips with silver plated U's for the leads, a small roll of
    silver bearing Sn-Pb solder was mounted inside the scope for use in
    replacing any failed components. Apparently the molten Sn-Pb solder
    would disolve the Ag but a relatively small Ag addition would prevent
    this. Sorry, I don't recall the % added.
    Ted
    Ted Edwards, Jun 20, 2005
    #3
  4. Chris Carlen
    CF Guest
    > joints?
    t>emp. At 200C, electronics SnPb alloys will dissolve 35u-in/s/unit area
    >plated surface.
    Yes, gold embrittlement IS a problem.
    We just "wick" the gold off by tinning and solder-wicking the lead
    and then solder it. This removes the gold.
    Carey
    CF, Jun 20, 2005
    #4
  5. Chris Carlen
    Chris Carlen Guest
    >>joints?
    >>plated surface.
    Very clever!
    #5
  6. Chris Carlen
    Jim Yanik Guest
    Ted Edwards <> wrote in
    news:vnDte.84421$tt5.17111@edtnps90:
    > Ted
    In addition,465 and later TEK scopes used gold-plated attenuator PCBs that
    were soldered with ordinary electronic solders.
    (not the 3% Ag stuff,either.That was only used for the ceramic strip
    scopes.)
    Jim Yanik
    jyanik
    at
    kua.net
    Jim Yanik, Jun 21, 2005
    #6
  7. Chris Carlen
    Pooh Bear Guest
    Chris Carlen wrote:
    > Hi:
    This is totally unrelated to your question ( other than being about using
    silver plating ).
    After the TWA 800 crash, the fuel tank systems of Boeing 747s were closely
    investigated. Early models used silver plated wire for the fuel quantity
    indication system with silver plated crimp lugs mounted to silver plated
    terminal blocks in the fuel tanks.
    It was discovered by examining a few old 747s that had experienced fqis
    problems that sulphur in the fuel combined with the silver plating to form
    semi-conducting silver sulphide that then washed over the terminal block
    coating it with a thin layer.
    One example when tested with a 9V battery actually 'flashed' between terminals.
    I assume the active sensing voltage and energy is lower than this though.
    Nickel plated wire is used now.
    Graham
    Pooh Bear, Jun 26, 2005
    #7
    1. Advertisements
Similar Threads
  1. Bernhard Kuemel
    gold capacitors contain no gold
    Bernhard Kuemel, Dec 7, 2005, in forum: Electronic Components
    3
    962
    Marc Popek
    Dec 8, 2005
  2. CC
    Silver vs. gold switch contacts
    CC, Apr 5, 2006, in forum: Electronic Design
    24
    2,140
    Phil Allison
    Apr 6, 2006
  3. hotjomo
    10
    1,368
    budgie
    Dec 10, 2006
  4. Periproct
    White Gold/Precision Gold multimeter
    Periproct, Jan 23, 2006, in forum: Misc Electronics
    1,930
    Periproct
    Jan 23, 2006
  5. petestrash
    What us the value of a Brown Grey Silver Gold Black resistor?
    petestrash, May 31, 2014, in forum: Datasheets, Schematics, Manuals and Parts
    3
    1,018
    TorontoBob
    Jun 23, 2014
Loading...
