Solder mask solvent?
Discussion in 'Misc Electronics' started by Neil Preston, Nov 28, 2003.
  1. Neil Preston
    Neil Preston Guest
    Is there any suitable method of dissolving the green solder mask found on
    most PC boards?
    A cc: would be appreciated: npreston at swbell dot net
    Thank you....
    #1
    1. Advertisements
  2. "Neil Preston" <> schreef in bericht
    news:JyBxb.3095$...
    > most PC boards?
    > Thank you....
    Acetone will do.
    petrus
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.543 / Virus Database: 337 - Release Date: 22-11-2003
    petrus bitbyter, Nov 29, 2003
    #2
    1. Advertisements
  3. Neil Preston
    Ross Mac Guest
    "Neil Preston" <> wrote in message
    news:JyBxb.3095$...
    > most PC boards?
    > Thank you....
    Hi Neil,
    To my knowledge, there is nothing chemical that will remove soldermask and
    leave the board usable....I am assuming it is epoxy based???
    If you have a number of expensive circuit boards that need it removed, your
    only recourse would be to find a circuit board company with a laser drill.
    They would be able to remove it cleanly. Hope that helps....Ross
    Ross Mac, Nov 30, 2003
    #3
  4. "Ross Mac" <> schreef in bericht
    news:Ehbyb.129568$...
    > news:JyBxb.3095$...
    on
    > > most PC boards?
    > > Thank you....
    > Hi Neil,
    your
    Ross,
    Think we're talking about different things. Never get a board in my hands
    having a green soldermask that did not solve with acetone. Never saw the
    acetone affecting the epoxy either. Some component plastics or printing may
    be affected however.
    petrus
    petrus bitbyter, Dec 1, 2003
    #4
  5. Neil Preston
    Ross Mac Guest
    "petrus bitbyter" <> wrote in message
    news:eek:Lvyb.93001$...
    > > news:JyBxb.3095$...
    > on
    > > > most PC boards?
    > > > Thank you....
    > > Hi Neil,
    and
    > your
    drill.
    > Ross,
    may
    > petrus
    This comes from my 30 years around the PCB biz.....Ross
    Ross Mac, Dec 1, 2003
    #5
  6. "Ross Mac" <> schreef in bericht
    news:zbByb.366452$...
    > > > news:JyBxb.3095$...
    found
    > > on
    > > > > most PC boards?
    > > > > Thank you....
    > > > Hi Neil,
    > and
    > > your
    > drill.
    > > Ross,
    hands
    > may
    > > petrus
    Well Ross,
    You should have had more PCBs in your hands then I had. I remember too well
    the times I tried to clean PCBs with acetone and got the green laquer along
    with the dirt I want to remove. So I did not use acetone but ethanol (or
    WS11) ever since. Nevertheless, the next piece of PCB I got in my hands -
    some minutes ago - did *not* let its solder mask solve in acetone. So I
    think you are right and my response was based on the wrong experience. (Old
    experience although <30 years.) So sorry for the mistake and thanks for your
    reply.
    petrus
    Version: 6.0.543 / Virus Database: 337 - Release Date: 21-11-2003
    #6
  7. Neil Preston
    Ross Mac Guest
    news:WMIyb.112939$...
    > > > > news:JyBxb.3095$...
    > found
    > > > on
    > > > > > most PC boards?
    > > > > > Thank you....
    > > > > Hi Neil,
    soldermask
    > > and
    removed,
    > > > your
    > > drill.
    > > > Ross,
    > hands
    the
    printing
    > > may
    > > > petrus
    > Well Ross,
    well
    along
    (Old
    your
    > reply.
    > petrus
    Hi Petrus....
    I have never used acetone to remove what they call soldermask on PCB's and
    it might remove it somewhat. In my experience in that biz was if we
    accidentally got it on the wrong area it could not be removed adequately to
    make the customer happy. When the laser drills showed up, someone came up
    with the idea to ablate soldermask. You just set the machine up to burn down
    to the foil. The C02 laser typically won't burn through copper so it's the
    perfect tool. They use these machines for drilling blind holes .004 and
    smaller at extremely high speeds. First they use a yag laser to drill
    through the copper, then they follow up with a C02 laser to cook the glass
    down to the next layer of copper. Then they fill the impression with
    electroless copper for a connection...
    In any event, this message got way off topic!!!....take care, Ross
    Ross Mac, Dec 3, 2003
    #7
  8. Neil Preston
    Neil Preston Guest
    Thanks for the replies, guys.
    I use acetone all the time to remove flux residue after soldering. Won't
    touch the soldermask they use nowadays.
    I do repair of pro audio equipment and often have to repair burnt or broken
    foil traces. So far the only thing I've been able to do is scrape it off or
    otherwise abrade it off. But I'd prefer not to abrade the copper. And
    sometimes the foils are difficult to get access to.
    Keep looking!
    Neil
    news:tT9yb.72277$...
    > news:JyBxb.3095$...
    on
    > > most PC boards?
    > > Thank you....
    > Acetone will do.
    > petrus
    Neil Preston, Dec 8, 2003
    #8
    1. Advertisements
Similar Threads
  1. John Muchow
    Condensation a problem on PCBs w/o a solder mask?
    John Muchow, Sep 11, 2003, in forum: General Electronics
    13
    1,464
    Simon Peacock
    Sep 17, 2003
  2. Glenn Ashmore
    DIY Solder mask?
    Glenn Ashmore, Feb 16, 2005, in forum: Electronic Basics
    2,123
    Glenn Ashmore
    Feb 16, 2005
  3. John H P Southall
    Prototype TSOP MQFP Solder Mask?
    John H P Southall, Apr 12, 2004, in forum: Electronic Design
    4
    572
    John H P Southall
    Apr 15, 2004
  4. Zapper
    Solvent to clean solder site
    Zapper, Apr 7, 2016, in forum: Electronics Repair
    5
    222
    tester272001
    May 7, 2016
  5. John Vogt
    Solder mask or thru-hole mask in PADS Layout 9.5
    John Vogt, Apr 15, 2016, in forum: General Electronics Chat
    3
    117
    Arouse1973
    Apr 20, 2016
Loading...
