Soft start for 110V AC water pump?
Discussion in 'Electronic Design' started by Pszemol, Jan 10, 2004.
  1. Pszemol
    Pszemol Guest
    Anybody knows some tested solution for a DIY wavemaker device
    which would switch two or more AC-powered water pumps
    (about 40W-90W each) in a 10 seconds cycle with a soft start
    feature? I would be able to variable pump speed using variable
    frequency of supply AC power. I would like the switch to start
    with low frequency, lets say 10Hz and gradualy go up to 50-60Hz
    during 1-2 seconds and then keep the pump running for 10seconds.
    I was thinking about modifying an old UPS I have which is APC 280
    for this purpose. Anybody here has any schematic for such devices?
    #1
    1. Advertisements
  2. Pszemol
    mike Guest
    What kind of motors are these?
    You have verified that running them from 10 Hz. will give you what
    you want?
    Depending on what you're trying to do, you might find a hydraulic
    solution more feasible.
    mike
    Return address is VALID.
    Toshiba & Compaq LiIon Batteries, Test Equipment
    Honda CB-125S $800 in PDX
    TEK Sampling Sweep Plugin and RM564
    Tek 2465 $800, ham radio, 30pS pulser
    mike, Jan 10, 2004
    #2
    1. Advertisements
  3. Pszemol
    James Meyer Guest
    On Sat, 10 Jan 2004 14:38:04 -0800, mike <> wroth:
    >> feature?
    >you want?
    >mike
    I agree Mike. Trying to do it Pszemol's way is going to turn into a big
    can of worms really quickly.
    I assume it's some sort of wave synthesis for a saltwater aquarium. If
    so, then running a small pump continuously to fill up an auxiliary tank placed
    above the level of water in the big tank that can be dumped into the big tank at
    10 second intervals would be a lot easier.
    You don't even have to use a valve to do the dumping. There is a type
    of syphon that can be used that allows a tank to fill and then the syphon starts
    and empties the tank. The tank has to fill again before the syphon does its
    thing again.
    Jim
    James Meyer, Jan 11, 2004
    #3
  4. Pszemol
    Pszemol Guest
    I agree that hydraulic solution is more feasible in most cases
    but I have very small fish tank in my livingroom (30 g) and
    there is no much room for a dump bucket nor I do not want
    to have big splash of water on my carpet :)
    The idea behind electric wavemaker is to switch water pumps
    alternately and this works fine with the exception of loud
    pumps turning on/off and shortened life of their impellers.
    The workaround is to have the pumps start slowly, and many
    expensive wavemakers are equiped in "soft start" feature
    which is giving a variable frequency voltage to the pump
    synchro motor causing it to turn more slowly at the beginning
    and reach full flow rate in about a second or two. This way
    you reduce the noice of impeller starting instantly full speed
    and you extend the life of the pumps without sharp starting.
    Since I would like to play with making some DIY wavemaker
    out of what is in my basement (a couple of old computer UPSes)
    I was seeking for some inspiration in this newsgroup...
    If I could reuse boards from my APC 280 UPS to make such
    wavemaker it could be great. Any idea on how can I aproach
    this task?
    Also, I have read somewhere that when I start this kind of
    synchro motor slowly with lowered frequency I need to lower
    voltage also to not burn the motor. Anybody knows what
    would be the formula for the voltage for 20 Hz 40Hz when pump
    is accepting full 110V for 60Hz frequency?
    Pszemol, Jan 11, 2004
    #4
  5. On Sun, 11 Jan 2004 14:27:43 -0600, "Pszemol" <>
    How about a mechanical solution: place a "false wall" at one end of
    the tank, pivoted at the bottom of the tank (or just held against the
    real end wall by gravel), and arrange a motor, crank, and pushrod
    assembly to move the top of the false wall back and forth.
    Peter Bennett, VE7CEI
    new newsgroup users info : http://vancouver-webpages.com/nnq
    GPS and NMEA info: http://vancouver-webpages.com/peter
    Vancouver Power Squadron: http://vancouver.powersquadron.ca
    Peter Bennett, Jan 12, 2004
    #5
  6. Pszemol
    Pszemol Guest
    "Peter Bennett" <> wrote in message news:...
    Interesting idea... I will think about it.
    The problem is that it takes valuable space inside the tank.
    Pszemol, Jan 12, 2004
    #6
  7. Pszemol
    Rich Grise Guest
    (why is this font so fat?)
    Are you just trying to make water slosh back and forth? What about some kind
    of
    auxiliary tank, behind the main one, with the slosh baffle in it.
    It seems like modifying two motor speed controllers, and coming up with
    some kind of control circuit, would be way more work than you'd need,
    just to make water slosh back and forth.
    What if you mount the tank on a fulcrum, so the whole tank can seesaw
    back and forth? It wouldn't take much movement to make some pretty
    good waves!
    Good Luck!
    Rich
    "Pszemol" <> wrote in message
    news:btpuao$6jl$...
    Rich Grise, Jan 16, 2004
    #7
    1. Advertisements
Similar Threads
  1. Replies:
    14
    4,798
    kevreh
    Dec 14, 2004
  2. John
    441
  3. Franks
    825
    Franks
    Oct 16, 2004
  4. moyaanomalous
    8
    1,082
    moyaanomalous
    May 20, 2013
  5. Tristar
    Wireless Start for Water Pump on my Farm
    Tristar, Aug 21, 2013, in forum: General Electronics Chat
    219
    (*steve*)
    Aug 22, 2013
Loading...
