SMD component codes
Discussion in 'Electronic Design' started by John Popelish, May 3, 2005.
  1. Does anyone have a link to a list of SMD component codes? I am trying
    to identify what I think is a dual RF transistor in what looks like a
    SOT-23-6 package with an S169 code etched into it.
    I can find lots of codes, not in catalogs, but only by calling up
    individual data sheets.
    #1
    1. Advertisements
  2. Homer.Simpson, May 3, 2005
    #2
    1. Advertisements
  3. Homer.Simpson wrote:
    >>trying to identify what I think is a dual RF transistor in what
    >>looks like a SOT-23-6 package with an S169 code etched into it.
    > http://www.tkb-4u.com/code/smdcode/indexsmdcode.php
    > http://www.marsport.demon.co.uk/smd/mainframe.htm
    > http://info.electronicwerkstatt.de/bereiche/bauteile/smd/smd_aktiv/1.
    > html
    I didn't find my part, but I have bookmarked these sites for future
    use. Thanks.
    #3
  4. John Popelish
    Boris Mohar Guest
    Boris Mohar, May 3, 2005
    #4
  5. John Popelish
    Pooh Bear Guest
    There's precious little space to put a component code on SOT23.
    I always refer to the data sheet. It's often just one letter and one
    numeral. Not much help if you don't have the schematic.
    Graham
    Pooh Bear, May 3, 2005
    #5
  6. Boris Mohar wrote:
    > Maybe here
    > http://matthieu.benoit.free.fr/cms.htm
    Another good one for the files.
    But on further examination, I am beginning to think the device is
    something more complicated and proprietary than a couple of
    transistors. I think it is a dual antenna switch (transmit and
    receive). It is connected between the antennas on a 2.4 G Hz WAN
    board. I probably can't get them even if I can identify them. Sigh.
    #6
  7. John Popelish
    Joerg Guest
    Hello John,
    Could it be an arrangement of PIN diodes?
    Regards, Joerg
    http://www.analogconsultants.com
    Joerg, May 3, 2005
    #7
  8. John Popelish
    Greg Neff Guest
    On Mon, 02 May 2005 19:16:08 -0400, John Popelish <>
    Nope, no link. Two things to consider:
    1) Are you sure it's S169 and not 691S?
    2) The last character (or two) may be a date code.
    Our inventory control system includes the part marking of each
    approved component (where applicable), so that the parts that we use
    can be identified and the markings can be searched. Unfortunately,
    this doesn't help you.
    <rant>
    SMD part markings is a major pet peeve of mine. There are many cases
    where the markings are not specified, even in the data sheet. This is
    especially true for logic families. When I put a new part in our
    database I often have to wait to get a sample to see how the part is
    marked so that I can enter that data. To make matters worse I have
    seen cases where the markings don't match the format specified in the
    data sheet, which means that we have to chase after the manufacturer
    for clarification.
    While I'm ranting, it drives me nuts that some manufacturers are using
    the same part numbers for both lead and lead-free finishes. They
    publish dates at which the finish will change, but now we have to use
    date codes to identify which parts are which. We are still trying to
    figure out how to modify our inventory control system to deal with
    this, to ensure that parts don't get mixed up. Like, what happens if
    we need lead-free, and a disti sends us parts with an older date code?
    Will the disti let us return them? And what then? What happens to
    our production schedule when these old parts arrive and we suddenly
    realize that we have to buy newer parts elsewhere? Didn't anyone
    *think*?
    And then there are things like Vishay formerly BC Components formerly
    Philips resistors. At least two different part numbers for the same
    thing, plus a NAFTA part number that does not appear in any data
    sheet, together multiplied by the number of packaging and lead length
    options. What a nightmare.
    </rant>
    Greg Neff
    VP Engineering
    *Microsym* Computers Inc.
    Greg Neff, May 4, 2005
    #8
  9. John Popelish
    Robert Kent Guest
    On May 2, 11:14pm, John Popelish writes:
    Close. I expect it is a Skyworks AS169-73 SPDT switch, most likely used
    to select between antennas based on signal strength.
    Here's a schematic for a Prism2 WLAN card reference implementation
    which uses two of these chips, one for antenna discrimination and one
    for TX/RX switching:
    https://gullfoss2.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=134594&native_or_pdf=pdf
    Credit where credit is due, here's the page where I found the above
    link:
    http://www.lincomatic.com/wireless/usr2410.html
    Here is a datasheet for the part:
    http://www.alldatasheet.com/datasheet-pdf/view/ALPHA/AS169-73.html
    And what have we here, but a company offering samples and small sale
    quantities of Skyworks's current RF switch product line
    (disclaimer--never dealt with these guys):
    https://www.cdistore.com/skyworks/switch.aspx
    The AS169-73 is not listed but you might be able to substitute a part
    with similar specs, such as the AS193-73.
    Robert Kent
    hanuman at ccsi dot com
    Robert Kent, May 4, 2005
    #9
    I think you may be right, The layout is right and the component
    values I can read match this schematic.
    > link:
    Thank you very much. This is the info I was looking for.
    John Popelish, May 4, 2005
    #10
    1. Advertisements
Similar Threads
  1. William Miller
    9,253
    William Miller
    Oct 25, 2007
  2. William Miller
    Error codes? Fault Codes?
    William Miller, Oct 29, 2007, in forum: Electronic Repair
    1,850
    William Miller
    Nov 7, 2007
  3. N_Cook
    SMD top codes ?
    N_Cook, Apr 29, 2009, in forum: Electronic Repair
    1,123
    N_Cook
    Apr 29, 2009
  4. JW
    1,858
    Fester Bestertester
    Jun 27, 2010
  5. legg
    SMD fuse codes
    legg, Apr 12, 2013, in forum: Electronic Components
    11,803
Loading...
