Slow, Automatic Light Dimmer
Discussion in 'Electronic Design' started by Aaron407, Jul 17, 2006.
  1. Aaron407
    Aaron407 Guest
    I'm hoping someone will have some insight into a simple design for a
    type of light dimmer. I'm looking to build a light dimmer that, after
    given power by an external timer, will slowly rise from a low dim on
    the ac light output (ie. low rms voltage level) to the full voltage
    over a course of about 15 minutes. I'm looking for 120Vac input, and
    hoping to not require a microcontroller to control anything (not too
    into programming). My biggest issue is how to control the voltage
    variation that slowly without a manual control or microcontroller.
    Overall, I'm just looking for a starting point to base my design on.
    I'm an electrical engineering graduate so I do have some background, so
    please throw some ideas at me, I'm all ears.
    -407
    #1
    1. Advertisements
  2. Aaron407
    PN2222A Guest
    "Aaron407" <> wrote in message
    news:...
    OK 407.
    So. D'yer know how a dimmer works? Go find that bit out.
    Then you'll discover you need a ramp on the control voltage what triggers
    the SCR (you _do_ know about the SCR?)
    That ramp is gonna be real, real ... slow.
    So you need to figure about high value resistors and low leakage capacitors.
    Am I going too fast?
    PN2222A
    fsubt 250MHz.
    PN2222A, Jul 17, 2006
    #2
    1. Advertisements
  3. Aaron407
    Aaron407 Guest
    Um, yeah, I do know about the conduction angle for firing an SCR to
    control the rms voltage you jackass, you don't have to patronize me.
    FYI, I focus on large power systems for my degree but I was hoping to
    start exploring electronics a little more, thanks for all the help.
    > news:...
    > OK 407.
    > PN2222A
    > fsubt 250MHz.
    #3
  4. On 16 Jul 2006 20:58:27 -0700, in sci.electronics.design "Aaron407"
    >-407
    How about a binary counter with a R2R network on the output, and use
    the FF state of the counter to inhibit the clock input.
    It will be better than a RC type time constant. The clock could be
    mains derived. One of the problems is that the normal incandescent
    lamp does not have a linear relatioship between volts applied and
    light output
    martin
    martin griffith, Jul 17, 2006
    #4
  5. Aaron407
    Aaron407 Guest
    Thanks Martin, I'll look into it. I really appreciate sincere help.
    > >-407
    > light output
    > martin
    #5
  6. Aaron407
    Fred Bloggs Guest
    It depends on what kind of effect you are trying to achieve, the timing
    is not so much an issue as setting the triggering angle. If you want the
    brightening ramp to be barely perceptible ("slowly") then there is
    something called the Weber-Fechner Law which relates actual light output
    intensity to changes to human perception. This roughly means that if the
    bulb drive is increased in discrete increments, then the increase
    between increments should be no more than 10% of the intensity
    corresponding to the preceding drive. Since the circuit most likely will
    use binary counters, this adds other constraints. If say you decide to
    use 64 drive levels, as derived from a simple resistor ladder off 6-bits
    of counter, and the increment is set to 8% , then this gives you
    (1.08)^64~ 120 to 150 range of intensity for the ramp. The 64 drive
    levels also implies 15 x 60 /64 = approximately 14 seconds of dwell at
    each level, and this is 15 x 60 x 60/64= 844 line cycles, the most
    readily available time base. So your basic circuit will be to initialize
    for an RMS output of Vmax/150, count cycles, increment the DAC counter,
    servo the bulb drive to Vmax/150*1.08, and so forth until the drive
    produces Vmax. I'll leave it to Jim Thompson to work out the best
    configuration of parts for you- he has plenty of time on his hands and
    claims to relish a challenge.
    Fred Bloggs, Jul 17, 2006
    #6
  7. On 17 Jul 2006 07:25:46 -0700, in sci.electronics.design "Aaron407"
    >> >-407
    >> light output
    >> martin
    WRT Fred's good info, you could use a photocell to monitor the light
    output, and effectively put lamp in a feedback loop, this might give
    you a linear response, or it might just be a bit OTT for a simple
    device
    martin
    #7
  8. "Fred Bloggs" <> wrote in message
    news:...
    > bulb drive is increased in discrete increments, then the increase between
    > increments should be no more than 10% of the intensity corresponding to
    > the preceding drive. Since the circuit most likely will use binary
    > counters, this adds other constraints. If say you decide to use 64 drive
    > levels, as derived from a simple resistor ladder off 6-bits of counter,
    > and the increment is set to 8% , then this gives you (1.08)^64~ 120 to
    > 150 range of intensity for the ramp. The 64 drive levels also implies 15
    > x 60 /64 = approximately 14 seconds of dwell at each level, and this is
    > 15 x 60 x 60/64= 844 line cycles, the most readily available time base.
    > So your basic circuit will be to initialize for an RMS output of
    > Vmax/150, count cycles, increment the DAC counter, servo the bulb drive
    > to Vmax/150*1.08, and so forth until the drive produces Vmax. I'll leave
    > it to Jim Thompson to work out the best configuration of parts for you-
    > he has plenty of time on his hands and claims to relish a challenge.
    This really is a perfect application for a small PIC or other
    microcontroller. It would be difficult to make an analog ramp for phase
    angle to produce a visually linear change in intensity over a long period.
    A PIC could use a lookup table that could be adjusted for the desired
    effect. This would compensate for the problem that voltage is not linearly
    related to phase angle, and also lamp brightness is not linear with
    voltage.
    Since so many things are now being done with PICs, it is important to have
    a good working knowledge of their capabilities. They are also often much
    cheaper and smaller than the equivalent set of conventional logic ICs or
    linear components, and have the advantage of simple reprogramming to make
    changes, rather than twiddling pots or changing components.
    I have the phase modulation PIC code already working for my SCR board, and
    it could be readily adapted to this project. I'm willing to email the code
    and help with some of the specific programming and circuitry. You can get a
    complete development kit (PicKit I) for about $30 from www.microchip.com.
    Good luck.
    Paul
    Paul E. Schoen, Jul 17, 2006
    #8
  9. Aaron407
    PN2222A Guest
    407, man, you cut me to the quick! J***A***? This is usenet,dude. We do
    have our standards.
    What I'd be looking to do for this problem is this:
    Zero-crossing circuit starts a timer when the line voltage is zero.
    Prolly the timer's a 555 or so. At the beginning of time (your 15-minute
    interval)
    the timer waits 8.32msec and sends out a quick pulse.
    That pulse fires the triac, turning the lamp on for a bit, until the next
    zero-crossing.
    As the time runs out of the hourglass, the delay drops from 8.32msec to
    zero, or nearly so.
    So I want a circuit that drops the trigger voltage steadily (more or less)
    from some initial voltage down to zero. Typically an R-C network. Maybe
    with a current source to make the ramp linear, and some low-input current
    buffers.
    Depends on how accurate, and how complex.
    At this point, somebody will insist that it's easier to do with a PIC.
    They'll be right.
    PN2222A
    pinout ebc, looking at the package.
    #9
  10. Aaron407
    Aaron407 Guest
    Ok, I realize I may have been a little harsh, but when a person is
    patronized without a request for any clarification, I believe that this
    is lowering oneself to a sub-par professional standard and comes off as
    mere ignorance to me.
    Anyway, as for your solution, that was actually the direction I was
    originally headed in to begin with as I have some experience with 555
    timers and RC circuits. I just stated the problem broadly as to not
    limit myself to any particular foundation for design. However, as you
    stated, there will likely be many people that will claim that a PIC
    solution is much simpler, and I will probably succomb to the peer
    pressure and follow suit, but I'd like to keep my options open at this
    point.
    407
    > have our standards.
    > interval)
    > zero-crossing.
    > zero, or nearly so.
    > buffers.
    > They'll be right.
    > PN2222A
    #10
  11. Aaron407
    Dennis Guest
    > They'll be right.
    > PN2222A
    Something like ww1.microchip.com/downloads/en/AppNotes/40171a.pdf
    Dennis, Jul 18, 2006
    #11
    > -407
    Use a PIC or a BASIC STAMP of course.
    Not using a microcontroller for this ap is fundamentally insane.
    Many thanks,
    Don Lancaster voice phone: (928)428-4073
    Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
    rss: http://www.tinaja.com/whtnu.xml email:
    Please visit my GURU's LAIR web site at http://www.tinaja.com
    Don Lancaster, Jul 18, 2006
    #12
  13. Aaron407
    -berlin.de Guest
    martin griffith <> wrote in sci.electronics.design:
    > >> mains derived.
    15 min at 60 Hz gives a count of 54000. A 16 bit counter would fit
    nicely.
    Anno
    -berlin.de, Jul 20, 2006
    #13
    1. Advertisements
Similar Threads
  1. Automatic dimmer circuit
    , Oct 15, 2006, in forum: Electronic Basics
    1,853
    Bill Bowden
    Oct 16, 2006
  2. stairforce
    Slow-on Slow-off filament lamp control circuit
    stairforce, Oct 16, 2006, in forum: Electronic Design
    5
    1,670
  3. Jeff Jonas
    slow motion light bulb abuse!
    Jeff Jonas, Jul 19, 2007, in forum: Lighting
    378
    Jeff Jonas
    Jul 19, 2007
  4. ScienceBorn
    Automatic light?
    ScienceBorn, Nov 15, 2013, in forum: Electronic Projects
    7
    439
    Jibby
    Nov 28, 2013
  5. AdamMortlock
    Help with light-sensing automatic LED bicycle headlight
    AdamMortlock, Nov 21, 2013, in forum: Electronic Projects
    6
    762
    AdamMortlock
    Dec 3, 2013
Loading...
