Simulate LED in LTSpice
Discussion in 'Electronic Design' started by Dr Mitch, Aug 8, 2007.
  1. Dr Mitch
    Dr Mitch Guest
    How can I tell if an LED is on or off in Spice model? Currently, I'm
    looking at the current and voltage drop, (~20mA and ~1.7V
    respectively) but when I do this design with an actual circuit, I get
    bupkis.
    #1
    1. Advertisements
  2. "Dr Mitch" <> schrieb im Newsbeitrag
    news:...
    > bupkis.
    Hello,
    You don't tell SPICE when a diode is on or off, you only specify model
    parameters.
    Example.for a model specification of a LED with 20mA, 1.7V.
    ..model LED1 D(Is=1e-19 N=1.6 Rs=2.5 Eg=2.1)
    Replace the value D of your diode in the schematic with LED1 and
    place the model specifications on your schematic as a SPICE-directive.
    I recommend to read some text about the basics of SPICE.
    Best regards,
    Helmut
    Helmut Sennewald, Aug 8, 2007
    #2
    1. Advertisements
  3. Martin
    Martin Guest
    > bupkis.
    Most likely you have miswired your actual circuit (LED wrong way
    around perhaps)
    Also, LEDs are very long lasting when operated within their allowable
    parameters, but if you miswire and subject the LED to excessive
    current or reverse voltage, you can destroy it in much less than a
    second. If you did that previously, it will most likely look like an
    open (infintitely high resistance) to the rest of the circuit now.
    Martin, Aug 8, 2007
    #3
  4. "Helmut Sennewald" <> schrieb im Newsbeitrag
    news:f9cp1t$7c2$02$-online.com...
    > news:...
    >> bupkis.
    > Hello,
    > parameters.
    Hello again,
    Maybe I haven't correctly understood all questions when I answered first.
    Just probe the current flowing through the LED in LTspice to see
    whether it's "on" or "off". If a few milli-Amperes will be shown,
    the LED will light in a real circuit.
    Best regards,
    Helmut
    > Best regards,
    > Helmut
    #4
  5. D from BC
    D from BC Guest
    On Wed, 08 Aug 2007 07:01:27 -0700, Dr Mitch <>
    >bupkis.
    Nahhh..It can't be...I hope you don't expect to see the LED symbol to
    actually light up?
    D from BC
    D from BC, Aug 8, 2007
    #5
    1. Advertisements
Similar Threads
  1. sal
    951
  2. BrianW
    3
    1,933
    Helmut Sennewald
    Nov 16, 2003
  3. Talion
    516
    Mike Engelhardt
    Dec 23, 2004
  4. SaintOlas
    8
    896
    SaintOlas
    Feb 23, 2012
  5. Felipe Paulo
    error in simulate bug zapper on ltspice
    Felipe Paulo, Oct 30, 2013, in forum: Electronic Design
    32
    637
Loading...
Share This Page
