Sharp TV w/ No Sound
Discussion in 'Electronic Repair' started by Geoff Gessner, Jun 4, 2004.
  1. I have a 25" Sharp TV that got wet and now does not have any sound.
    The picture is still excellent and the speaker works fine.
    Model 25A-M120
    Any suggestions...
    The TV is 10 years old...
    Thanks!
    #1
    1. Advertisements
  2. Geoff Gessner
    Sofie Guest
    Geoff Gessner:
    Check the menu or look for a switch to verify that you do not have the sound
    mode in SAP.... also verify that mute is not on and if there is a speaker
    switch on the back of the set make certain that it is on.
    Other that all of this simple stuff, if you are looking for specific
    do-it-yourself repair suggestions you really need to FIRST do some initial
    technical troubleshooting with your DMM and perform a more thorough
    technical visual inspection. Be certain when you reply that you include as
    much technical detail, component test results, voltage readings, etc,
    etc.... as you can. You are our eyes and ears so you need to post all the
    pertinent information that you can.
    Best Regards,
    Daniel Sofie
    Electronics Supply & Repair
    "Geoff Gessner" <> wrote in message
    news:...
    > Model 25A-M120
    > Any suggestions...
    > Thanks!
    Sofie, Jun 4, 2004
    #2
    1. Advertisements
  3. If this set has electronic volume control (that is, you use the remote and
    can see graphics telling you the volume is going up), then crank it up as
    high as it will go and then lean in closely to listen to the speaker. If it
    is still dead-dog quiet, then the audio amplifier may be the problem. If
    you can hear at least a faint buzz, then the amp circuit is probably working
    but the audio source isn't.
    Matt J. McCullar, Jun 5, 2004
    #3
    1. Advertisements
Similar Threads
  1. John Bond
    746
    John Bond
    Mar 23, 2005
  2. Martijn
    1,059
    Gordon Gaskell
    Feb 9, 2004
  3. John Bond
    729
    John Bond
    Mar 23, 2005
  4. Replies:
    825
  5. CaptnCrunkRoman
    Philips tv w/ sound but NO Picture!
    CaptnCrunkRoman, May 18, 2007, in forum: Electronics Repair
    4,478
    CaptnCrunkRoman
    May 18, 2007
Loading...
