Schematic from PCB drawing
Discussion in 'General Electronics Chat' started by solo2racr, Oct 6, 2013.
  1. solo2racr
    solo2racr
    Aug 21, 2013
    141
    North Carolina U.S.
    I have never done this and was wondering if anyone had any tips to make this as easy and accurate as can be.
    #1
    1. Advertisements
  2. solo2racr
    19,930
    1,286
    It's non-trivial.
    Have a good clean image of the board and both (or all) layers. Then identify the componets and try to untangle the connections. It's often useful to identify the "main" part -- an op-amp, or a microcontroller, etc, then draw everything around it in a way that looks sensible.
    You need to be very careful that you haven't missed a connection. It may be useful to colour them in as you go.
    After you've drawn it once, see if you can untangle it and make it look nice.
    Then check for obvious errors and refer back to the PCB to see if you made a mistake.
    (*steve*), Oct 6, 2013
    #2
    1. Advertisements
  3. solo2racr
    solo2racr
    Aug 21, 2013
    141
    North Carolina U.S.
    So, work it out in segments as opposed to trying the sort it out in it's entirety. I was thinking to start, trace out the ground path. Then work from the +/- voltages from there.
    #3
  4. solo2racr
    19,930
    1,286
    I guess that you need to have some sort of system. I'd agree that tracing power and grounds is a good thing, but they're often easier than the signal path because you know that they are going everywhere (usually).
    (*steve*), Oct 7, 2013
    #4
  5. solo2racr
    Rleo6965 VIP Member
    Jan 22, 2012
    584
    9
    Quezon City, Philippines
    Before I use paper and pencil to draw the schematic diagram while tracing the pcb. Now , I use schematic drawing software . It's easier to draw lines , edit and drag components to its proper place for easier analysis. I use DesignSparkPCB5 software.
    You can use simpler schematic drawing software if you want.
    Rleo6965, Oct 7, 2013
    #5
  6. solo2racr
    KMoffett VIP Member
    Jan 21, 2009
    542
    47
    Minnesota USA
    As Steve said make good images of both sides. Highlight over each PCB trace on the paper image as you replicate it on the paper/CAD schematic. This makes sure that you don't leave connections out.
    Ken
    KMoffett, Oct 14, 2013
    #6
    1. Advertisements
Similar Threads
  1. Terry Vacha
    Schematic drawing program
    Terry Vacha, Feb 13, 2005, in forum: Electronic Basics
    5
    1,211
    Terry Vacha
    Feb 14, 2005
  2. jancarel jansenklomp
    schematic drawing and pcb lay-out program
    jancarel jansenklomp, Jun 22, 2005, in forum: Electronic Design
    567
    Jun 22, 2005
  3. BrunoG
    What schematic drawing tool do you use ?
    BrunoG, Dec 20, 2005, in forum: Electronic Design
    25
    711
    Joerg
    Dec 28, 2005
  4. Superman
    6
    715
  5. hiurl@163.com
    2,126
    tamil
    Feb 7, 2006
Loading...
