Samsung txe2545
Discussion in 'Electronic Repair' started by SirOliver, Nov 25, 2003.
  1. SirOliver
    SirOliver Guest
    I got this set new, first I had half screen problem which I fixed and
    it was working for a wile but now,
    I get only high pitch click noise when I hit power button, no video no
    sound , keeps firing and makes noise every four sec but does not
    start. Noise is very short maybe quarter of second.
    When u try to shut it off does not respond to power switch at all.
    Need help!!! Switch maybe?
    #1
    1. Advertisements
  2. SirOliver
    David Guest
    Obviously the power button is working since the set tries to turn on after
    you push it.
    There is likely a failure somewhere in the power supply or deflection or
    high voltage flyback circuit. Only proper signal and voltage
    troubleshooting will direct the technician in the right direction.
    David
    SirOliver <> wrote in message
    news:...
    David, Nov 25, 2003
    #2
    1. Advertisements
Similar Threads
  1. leemax
    Monitor screen gives shock, SAMSUNG 753DFX
    leemax, Nov 20, 2003, in forum: General Electronics
    618
    Jerry Greenberg
    Nov 21, 2003
  2. Brad
    Samsung TV TXE2545 Bottom Half of Picture
    Brad, Apr 12, 2005, in forum: Electronic Repair
    7
    443
    Jason D.
    Apr 13, 2005
  3. Brad
    8
    684
    Leonard Caillouet
    Apr 20, 2005
  4. Ron Blancarte
    Samsung TXE2545
    Ron Blancarte, Jul 6, 2006, in forum: Electronic Repair
    540
  5. Replies:
    1,137
Loading...
