Samsung TV/VCR Combo (model CXB1322) blows 3 amp F801 fuse when power on buttom pushed
Discussion in 'Electronic Repair' started by Joe R., Dec 13, 2003.
  1. Joe R.
    Joe R. Guest
    I have a Samsung TV/VCR Combo, model CXB1322 that will blow the F801
    fuse when the power button is pushed. It was making a high pitched
    noise when it was plugged in and VCR was not working. As suggested in
    a previous post, I replaced C810 (470 Mfd cap) which corrected the
    noise problem. I checked C09 on VCR power supply and it measured .18
    Mfd (should be 22 Mfd). I replaced it with a 22 Mfd cap (non-polar).
    and everything worked fine. I turned tv on and off several times and
    all was well. The next day, I plugged the TV in and went to power it
    on, and fuse F801 on main board blew. I then pulled the power supply
    out of vcr and removed the transsistors and some of the diodes to
    check. All checked (with multimeter) good. I re-assembled the power
    supply and plugged everthing in and all worked again. The next day, I
    plugged TV in and fuse blew again. Has anyone run into this type of
    problem that can point me in the right direction.
    Thanks!
    #1
    1. Advertisements
  2. Jerry G.
    Jerry G. Guest
    Check the horizontal output transistor, and the flyback assy.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    "Joe R." <> wrote in message
    news:...
    Thanks!
    Jerry G., Dec 14, 2003
    #2
    1. Advertisements
  3. Joe R.
    Joe R. Guest
    "Jerry G." <> wrote in message news:<brgfgd$kth$>...
    > Greetings,
    > news:...
    > Thanks!
    I already checked the HOT with a multimeter and the junctions were
    good - no shorts. Is there any way to check the flyback for shorts,
    either in circuit or out of the circuit? Could the flyback be
    intermittent?
    Joe R., Dec 14, 2003
    #3
    1. Advertisements
Similar Threads
  1. Joe R.
    4
    832
    Joe R.
    Dec 9, 2003
  2. Jason D.
    416
    Jason D.
    Feb 24, 2004
  3. burt squareman
    Toshiba hi-fi VCR blows fuse twice. w-604 (circa 1994)
    burt squareman, Nov 9, 2004, in forum: Electronic Repair
    4
    991
    JVC Dude
    Nov 12, 2004
  4. Roy Thomas
    switching power supply 24 v - blows fuse
    Roy Thomas, Nov 3, 2005, in forum: Electronic Repair
    6
    711
    Ross Herbert
    Nov 4, 2005
  5. Replies:
    5
    850
Loading...
