RS-232 control of several relays
Discussion in 'Electronic Design' started by Steven Endres, Jul 3, 2007.
  1. I want to use an RS-232 port to control several (at least 8, but preferably
    16) relays individually. The load on the relays is low voltage/low current.
    Basically, I want to use RS-232 to close the relay to replace a PC power
    switch, so I can boot a machine on demand from another.
    This is a school project, so I'm looking for a low-cost solution. I'd prefer
    a trip to Radio Shack instead of a commercial solution. I did find this
    component, which looks suitable: http://www.elabinc.com/ede300.htm
    Any suggestions? Am I on the right track?
    Thanks for the help!
    Steven
    #1
    1. Advertisements
  2. Steven Endres
    MooseFET Guest
    On Jul 2, 4:30 pm, "Steven Endres"
    > component, which looks suitable:http://www.elabinc.com/ede300.htm
    Are you intending to build something?
    Why not use the parallel port?
    Do the relays take turns or can they be on in any combination?
    Are you able to write software?
    Can you program a PAL (22V10) or a PIC?
    The RS232 has a couple of handshake lines and the RS-232 line. There
    are several things you can do to make the hardware simple at the cost
    of making the software more complex.
    If you think of the lines as just signals you can make go high and low
    and pulse and not as RS-232 data, I think you'll see some of the ideas
    right away.
    8 relays won't be very cheap BTW.
    MooseFET, Jul 3, 2007
    #2
    1. Advertisements
  3. Steven Endres
    Donald Guest
    > Steven
    Yes, you are on the right track, however becareful of the head-on train.
    You have not mentioned weather you are able to code and program your own
    chips. Like the one from elabinc.com.
    So, I would guess that you are _not_ able to code and program your own
    chip, if you did, you would be done by now.
    So, please help us help you.
    1) Do you know how to program ?
    a) in assembly code
    b) in "C"
    c) in Basic
    2) Do you know how to solder ?
    a) two wires together
    b) parts on to a PCB
    c) you can only burn yourself.
    3) Do you understand that RS-232 is a voltage level standard and serial
    ports use those voltage levels for Asynchronous Serial Communications ?
    There are many other question that can be asked, but, now its your turn.
    donald
    PS: If the questions above are beyond you, just buy the chips from
    labinc.com. You will get something done quicker and you will feel like
    you have accomplished something. After the first one, you then can move
    on to your own design, coding, burning, frying parts, makeing lots of
    smoke, debugging code, finding bad parts from the vendor, learning about
    how currents will flow into the path of least resistance, etc, etc, etc.
    Good Luck
    Donald, Jul 3, 2007
    #3
  4. "MooseFET" <> wrote in message
    news:...
    preferably
    current.
    prefer
    > right away.
    "Donald" <> wrote in message
    news:...
    preferably
    current.
    prefer
    > > Steven
    > a) in assembly code
    > b) in "C"
    > c) in Basic
    > donald
    > Good Luck
    Both of you asked for some clarification as to the nature of the project and
    my skill set, so I'll answer you both together.
    > a) two wires together b) parts on to a PC c) you can only burn yourself.
    I can assemble a professional project from a schematic. I can layout and
    etch a PCB and solder components etc. But I have no experience in designing
    the circuit itself.
    No particular reason. The controlling system is a Sun server which has two
    serial ports and one parallel port, so either option is fine.
    My goal is to boot a number of Sun servers on command from a master Sun
    server. Sun systems can accept a power-on signal through their keyboard
    connector, since their keyboards include a power button. Basically, shorting
    POWER_ON (pin 7) to GND (pin 1) on this connector will boot the system.
    Here's a pinout:
    http://www.hardwarebook.info/SUN_Keyboard/Mouse (bottom figure)
    These pins only need to close for a moment (~1 sec) and can then switch back
    off. And note that we're switching a low-voltage, low-current circuit, so I
    don't necessarily need a relay if some other cheaper/simpler device will
    accomplish the trick.
    As each server has a significant current draw (~7 amps peak) I would like to
    stagger the timing such that I don't get a big spike by booting all systems
    simultaneously. As soon as I can borrow one, I plan to put an ammeter on a
    system to determine when peak demand is reached after boot, so I can set a
    delay between each boot appropriately. I'm guessing this will fall in the
    10-20 second range. Ideally each relay would be individually addressable,and
    the delay would be adjustable in software, but in a pinch I can settle for a
    circuit that has a fixed sequence and timing between "turn-ons".
    > Do you know how to program a) in assembly code b) in "C" c) in Basic
    Yes, I can write in C, C++, Basic, Java, and several scripting languages
    without trouble. I'd use C given the choice. I can do assembler as well, but
    it's been years and I'm rusty. And I haven't had a need to program serial or
    parallel ports before, so I'd need to look that up.
    Yes, I would prefer a solution with more simple hardware and more complex
    software if given the choice, as that would likely cost less.
    I have not sone so, but I'm sure I could learn.
    I hope this answers your preliminary questions, and I thank you again for
    the help.
    Steven
    #4
  5. Steven Endres
    budgie Guest
    On Mon, 2 Jul 2007 18:30:15 -0500, "Steven Endres"
    Don't know about your part of the planet, but here in Australia there are kits
    which offer that sort of functionality for both serial and parallel ports.
    If they are still in operation (their head honcho died a couple of years back,
    and I haven't looked in there since) Kits'r'Us in HongKong did this type of kit
    also, and they are a mail order specialist.
    Personally I favour the parallel port for this type of control.
    budgie, Jul 3, 2007
    #5
  6. Steven Endres
    Donald Guest
    8<snip
    8<snip
    > the help.
    > Steven
    Yes, you are now ready.
    The first question is a religious one.
    What chip to use ?
    There are many chips to chose from, PICs, AVRs, MSP430s, 8051s, and the
    ARM world extends this list further.
    The list is long and each has its own set of challenges and features.
    So, do you have a preference ??
    This project sounds like a one off, maybe two for backup.
    Since you have a real project in mind, how fast do you need it ?
    Getting a proto-board and soldering down a chip can be daunting to a
    beginner. But I bet you can handle that.
    Getting a prebuilt proto-board with a chip on it would get you up and
    running quickly and many demo boards comes with assemblers or compilers.
    For a quick one off project like this, I get boards from Sparkfun.com.
    I have compilers for most of the small 8/16 bit chips on the market.
    So I tend to use AVRs or MSP430s.
    As far as compiler/assemblers are concerned, do you want to use a
    development environment on said SUN systems ??
    Are you unaffected by using WinXP based tools ?
    OK, go to this link
    :http://www.sparkfun.com/commerce/product_info.php?products_id=30
    download the schematics and docs.
    This will give you a good idea on how to build your own version.
    Good Luck
    donald
    PS: send pics :)
    Donald, Jul 3, 2007
    #6
  7. Steven Endres
    MooseFET Guest
    On Jul 2, 9:34 pm, "Steven Endres"
    > the circuit itself.
    Ok.
    This is good. Interfacing to the parallel port will be easier than
    doing the RS232 version.
    Beware that on some PCs, the printer port shuts down if it not used.
    This is most common on laptops. I'm going to suggest that the design
    latch the information for other reasons anyway but this is just
    another reason.
    The parallel port has 8 data lines. You want more than 8 relays
    controlled so the simple design where each pin is used to control one
    relay. We will need to decode the output to select which latch gets
    the data.
    Decoding and latching can all be done in one chip.
    http://www.fairchildsemi.com/pf/MM/MM74HC259.html
    I'll start by explaining 8 bits worth but leaving a consideration or
    two out and then expand from there:
    Hardware:
    Port Chip
    GND ------------------------ GND
    D0 ------------------------- Data In
    D1 ------------------------- A \
    D2 ------------------------- B ) Address pins
    D3 ------------------------- C /
    D4 ------------------------- Enable/ (Active low)
    Software to set one bit:
    Temp = BitValue + (BitNumber SHL 1) + 10H
    ParaPort = Temp
    ParaPort = Temp AND 0FH
    ParaPort = Temp
    This works but it has four problems. (1) It only does 8 bits (2) When
    the Enable is moved, there may be glitches on the other lines. (3) It
    may do something when the port is shut down (if it is). (4) It is not
    protected against static.
    Solving (1):
    On the second chip use the D5 instead of the D4 as the enable. The
    third chip used D6 if you need one and so on. This means that the
    software will have to change just a bit to run it.
    UpperMask = 10H SHL (BitNumber SHR 3)
    Temp = BitValue + ((BitNumber AND 07H) SHL 1) + 0F0H
    ParaPort = Temp
    ParaPort = Temp AND NOT UpperMask
    ParaPort = Temp
    Solving (4):
    Right near the chip put a 10K resistor in each line and a 0.01uF to
    ground. This will slow down and spread out any ESD spikes.
    Unfortunately, you have to change the software a bit to work with
    this. 10K and 0.01uF cause all the signals to move more slowly.
    After each write to the ParaPort, we need to add a delay of at least
    1/2 a millisecond.
    10K
    --- 0.01
    GND
    Solving (3):
    Add this line:
    ParaPort = 0F0H
    at the end of the code and don't use the "0" output of any of the
    chips to do anything.
    Solving (2):
    Our ESD protector, filters out any glitches so this isn't a problem.
    You now have more logic lines than you need to control the relays.
    > Here's a pinout:http://www.hardwarebook.info/SUN_Keyboard/Mouse(bottom figure)
    We need to know how much current is really needed for this. If it is
    really tiny, the IC can drive it. I expect that you will need more
    than that so I suggest each have a transistor on it. The 2N2222 can
    likely do the job.
    ------- server
    1K !/c
    Q---/\/\----! 2N2222
    !\e
    -------GND
    When Q goes high, (5V - 0.7V)/1K = 4.3mA flows into the base. The
    2N2222 can be easily trusted to switch up to 25 times its base current
    so this will be good up to about 100mA.
    The above circuit is very general purpose. It is slight overkill
    because it can assert any combination of pins.
    One thing to worry about is differences in ground voltages. I suggest
    that you run a big fat wire between all the chassis to ensure that
    they are all at the same voltage. I have seen wall outlet grounds up
    to 3VAC different. Only trust a wire you can see for this. Wall
    outlet grounds may only connect together at the far end of the
    building.
    I think I've done that.
    I think I've removed the need for anything special in programming.
    > the help.
    > Steven
    #7
  8. "MooseFET" <> wrote in message
    news:...
    > <--SNIP-->
    > Hardware:
    > Port Chip
    > ParaPort = Temp
    > ParaPort = Temp
    > Solving (1):
    > ParaPort = Temp
    > ParaPort = Temp
    > Solving (4):
    > 1/2 a millisecond.
    > 10K
    > --- 0.01
    > GND
    > Solving (3):
    > Add this line:
    > ParaPort = 0F0H
    > Solving (2):
    shorting
    figure)
    back
    so I
    > likely do the job.
    > ------- server
    > 1K !/c
    > !\e
    > -------GND
    like to
    systems
    a
    a
    the
    addressable,and
    for a
    > building.
    > <--SNIP-->
    Okay, so far I like this option, as it seems the most striaghtforward to me
    (both to build and to program), and it looks like it can be built at the
    lowest component cost.
    I share your concern about ground voltages. Perhaps to be on the safe side
    we should modify the output circuit to use an optocoupler to isolate the
    circuit being switched? I see that the Sparkfun AVR uses 4N37 optocouplers
    on its inputs. I presume this technique could be adapted for the outputs?
    The 4N37 is a single-channel optocoupler; perhaps there's a 4-channel or
    8-channel equivalent?
    Thanks again to MooseFET, Donald, and budgie for taking the time to help.
    Steven
    #8
  9. Steven Endres
    whit3rd Guest
    > 16) relays individually. ... so I can boot a machine on demand from another.
    So many folk say you should make a computer to handle the task...
    they're all thinking inside their box.
    Instead, consider the humble LM567 tone decoder, that responds with
    a logic output whenever it hears its programmed frequency.
    You can queue up a kilobyte of zeros and ones for the serial port,
    with any pattern that you need to generate the frequency of interest.
    Just program a bunch of decoders, for 200 Hz, 240 Hz, 270 Hz,
    300 Hz, 330 Hz...
    Condition the EIA-232 with some limit diodes and a crude filter.
    Isolate the target computer's reset pin with an optoisolator. You're
    done except for connecting the wires.
    It might pay to use a small capture bandwidth and 'learn' each center
    frequency.
    whit3rd, Jul 3, 2007
    #9
  10. Steven Endres
    MooseFET Guest
    On Jul 3, 1:16 pm, "Steven Endres"
    > news:...
    > > <--SNIP-->
    > > Hardware:
    > > Port Chip
    > > ParaPort = Temp
    > > ParaPort = Temp
    > > Solving (1):
    > > ParaPort = Temp
    > > ParaPort = Temp
    > > Solving (4):
    > > 1/2 a millisecond.
    > > 10K
    > > --- 0.01
    > > GND
    > > Solving (3):
    > > Add this line:
    > > ParaPort = 0F0H
    > > Solving (2):
    > shorting
    > figure)
    > back
    > so I
    > > likely do the job.
    > > ------- server
    > > 1K !/c
    > > !\e
    > > -------GND
    > like to
    > systems
    > a
    > a
    > the
    > addressable,and
    > for a
    > > building.
    > > <--SNIP-->
    I suggest that you consider running the logic on its own power supply
    and not using the +5V on the printer port connection. If you use the
    printer port connection's power, you have to worry about what happens
    if the plug is plugged or unplugged with the power on.
    Non Darlington
    http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=490349&Row=192078&Site=US
    Darlington
    http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=488533&Row=193515&Site=US
    330
    +5V --/\/\-----
    ! ------Input of PC
    V -> !/c
    ! !\e
    From logic -------- -----GND of PC
    The HCTxxx chips pull down better than up. The LED current is about
    I = (5V - 1.6V) / 330 = 10.3mA
    I think that is enough if the load is small.
    The non-Darlington is better if the signal is really logic. It will
    pull about 10mA down to a legal logic low. It is also nice that the
    two LEDs prevent you from getting it hooked up backwards.
    The Darlington will pull down a lot more current but not to a legal
    logic low.
    I suggest you use sockets and use the Darlington's pinout. This way
    you can change your mind if you want to use it for other purposes.
    > Steven
    MooseFET, Jul 4, 2007
    #10
  11. Steven Endres
    oopere Guest
    > Steven
    Do you _have_ to use RS232? If you just want to boot other PCs you may
    wake them up using your LAN. Google for "wakeonlan".
    Pere
    oopere, Jul 4, 2007
    #11
  12. Steven Endres
    Fred Bloggs Guest
    > Steven
    About the only suitable product available from Radio Shack is the
    Parallax Basic Stamp kit, and this costs about $75. That has everything
    you need to get the project up and running very quickly though. Basic
    communications is all through the serial port and the project board has
    ample room to insert relay drivers. By the time you nickel and dime with
    piece parts, this may ultimately be the cheapest way too, not too much
    you will end up with a lot better product.
    Fred Bloggs, Jul 4, 2007
    #12
  13. Steven Endres
    Si Ballenger Guest
    >Steven
    There are a number of places robotic types of places that sell
    serial to parallel chips and boards starting at ~$10 for the
    chips and ~$40 for the boards. The cheapest chip is probably the
    SN74LV8153 TI chip.TI will send you samples of the chips for
    free, or you can get them from Digikey for $1.38. I'd connect
    this chip to the 74hct259 latching chips ($.50 or less) to be
    able to do a lot of descrete on/off operations. As for relays,
    the below parallel port relay board is inexpensive and can be
    connected to the output of the 74hct259 chips in stead of the
    parallel port. Some have said to use the parallel port, but a
    number of its pins go hi/lo during a computer boot, and could
    cause some unintended situations. You could get around this by
    using it to operate the 74hct259 chips. Programming wise, you can
    actually use simple batch files to send the desired bytes to the
    chips via the serial port. Below are some links that might be of
    interest.
    http://focus.ti.com/docs/prod/folders/print/sn74lv8153.html
    http://focus.ti.com/lit/ds/symlink/sn74lv8153.pdf
    http://www.elecdesign.com/Articles/ArticleID/10524/10524.html
    http://tinyurl.com/32kx7a
    http://www.electronickits.com/kit/complete/elec/ck1601.htm
    http://store.qkits.com/moreinfo.cfm/QK74
    Si Ballenger, Jul 4, 2007
    #13
  14. Steven Endres
    Rich Grise Guest
    > another reason.
    > the data.
    I don't see what an HC259 will buy you. I'd use (up to) 3 of the control
    lines (if I needed 8 x 8 bits out) for address, the fourth one for strobe,
    and just use a 74HC138 or something for a decoder, and how ever many
    latches you need.
    http://www.doc.ic.ac.uk/~ih/doc/par/
    Pseudocode:
    write 0nnnb to control port, where nnn is port address
    write data to data port
    write 1nnnb to control port - this should latch the appropriate latch.
    write 0nnnb to control port - this ends the write strobe.
    And if you want, there are 5 input lines where you can read status or
    whatever you want. (they used to simulate a bidirectional port by
    nybble-banging - they'd send a byte 4 bits at a time to the status
    inputs.)
    Cheers!
    Rich
    Rich Grise, Jul 4, 2007
    #14
  15. On a sunny day (Wed, 04 Jul 2007 18:38:26 GMT) it happened Rich Grise
    <> wrote in <>:
    OK ENOUGH OF THIS IF YOU DO NOT WANT PIC:
    I USE A PCF8474 IO EXPANDER ON THE PARPORT VIA I2C PROTOCOL,
    3 PINS: CLOCK, DATA, AND DATA PULL DOWN VIA A DIODE.
    IT WILL HOLD DATA WHEN THE PC IS OFF.
    IT WILL NOT GET CONFUSED BY INTERRUPTS IN CLOCK IN A MULTITASK OS.
    IT ONLY USES MICROWATTS.
    IT CAN USE 5V FROM THE PAR PORT FOR SUPPLY.
    IT CAN ALSO READ FROM THE PINS.
    IT HAS 8 IO PINS AND AN INTERRUPT.
    IT CAN DRIVE LEDS DIRECTLY.
    I HAVE PCF8591 ADC/DA ON IT TOO.
    YOU CAN HAVE MORE THEN ONE ONE THE SAME I2C BUS.
    I HAVE C COURCE CODE FOR THIS FOR THOSE WHO WANT IT UNDER GPL LICENSE.
    THANK YOU FOR YOUR ATTENTION.
    Jan Panteltje, Jul 4, 2007
    #15
  16. On Mon, 2 Jul 2007 18:30:15 -0500, "Steven Endres"
    - Can be done in a simple microcontroller with UART and enough IOs to
    control the relays. PIC, SILABS, ATMEL, and much more...
    - Can be done with a simple FPGA and some VHDL programming.
    - Can be done with two 8bit shift registers and some glue logic
    around.
    Heinz
    Heinz Liebhart, Jul 6, 2007
    #16
  17. "MooseFET" <> wrote in message
    news:...
    > > news:...
    > > > <--SNIP-->
    > > > Hardware:
    > > > Port Chip
    > > > ParaPort = Temp
    > > > ParaPort = Temp
    > > > Solving (1):
    > > > ParaPort = Temp
    > > > ParaPort = Temp
    > > > Solving (4):
    > > > 1/2 a millisecond.
    > > > 10K
    > > > --- 0.01
    > > > GND
    > > > Solving (3):
    > > > Add this line:
    > > > ParaPort = 0F0H
    > > > Solving (2):
    Sun
    keyboard
    > > shorting
    system.
    > > > > Here's a
    > > figure)
    switch
    > > back
    circuit,
    > > so I
    will
    > > > likely do the job.
    > > > ------- server
    > > > 1K !/c
    > > > !\e
    > > > -------GND
    > > like to
    > > systems
    ammeter on
    > > a
    set
    > > a
    in
    > > the
    > > addressable,and
    settle
    > > for a
    > > > building.
    > > > <--SNIP-->
    me
    side
    optocouplers
    outputs?
    > Non Darlington
    > Darlington
    > 330
    > +5V --/\/\-----
    > ! ------Input of PC
    > V -> !/c
    > ! !\e
    > logic low.
    help.
    > > Steven
    Okay, thanks for this info. I have found some additional information on this
    topic by including /parallel port/ AND /robotics/ in my searches. I'm going
    to try during the upcoming days to compile the best features of a few
    approaches into a schematic.
    BTW, where does an IEEE 1284 parallel port provide +5V? All the pinouts I've
    come across do not list this as a feature.
    If I have any further questions, I'll probably request a "schematic review"
    under a new thread.
    Thanks agin, everyone, for your suggestions.
    Steven
    Steven Endres, Jul 9, 2007
    #17
  18. Steven Endres
    Si Ballenger Guest
    On Mon, 9 Jul 2007 14:26:18 -0500, "Steven Endres"
    If you are looking at a specific PC, you probably need to check
    the voltage with a multimeter. Come current parallel ports may
    only output ~3.5v.
    Si Ballenger, Jul 14, 2007
    #18
    1. Advertisements
Similar Threads
  1. Ralph Seguin
    Newbie: A/D -> RS-232 -> Computer -> RS-232 -> D/A
    Ralph Seguin, Jan 14, 2004, in forum: General Electronics
    5
    670
    the Wiz
    Jan 15, 2004
  2. What does "232" in RS-232 stands for?
    , Jun 16, 2006, in forum: Electronic Basics
    3
    2,564
  3. What does "232" in RS-232 stands for?
    673
  4. Ralph Seguin
    Ralph Seguin, Jan 14, 2004, in forum: Electronic Design
    6
    552
    the Wiz
    Jan 15, 2004
  5. Ralph Seguin
    Ralph Seguin, Jan 14, 2004, in forum: Misc Electronics
    4
    451
Loading...
