Rollins System 6 / System VI alarm -- need help Programming
Discussion in 'Security Alarms' started by V. Trace, May 3, 2004.
  1. V. Trace
    V. Trace Guest
    Hello all --
    We recently had a power outage and found that the backup battery in our
    Rollins System 6 was dead. All of the programming for the system has
    now been lost and all the sensors and smoke detector must be
    re-programmed back into the system. We would like to reprogram the
    system ourselves and are looking for a copy of the programming manual.
    The Rollins system 6 sensors are "Learn Mode" sensors and do =NOT= need
    to be ³burned² with a programming keypad or any special device. The
    Rollins System 6 is basically an ITI SV-5 using "Learn Mode" sensors
    that operate at the 317 mhz frequency. The ITI SV-5 systems normally
    use 319 mhz and this is why the Rollins System 6 sensors can not be
    used with the newer Concord system which operates at 319 hz.
    All of the sensors still have fresh batteries in them and the Alpha
    keypad and main keyed control unit are fine (we just installed a fresh
    backup battery in the control console). I am able to figure out how to
    get into ³programming mode² on the console because in the past I was
    able to remove certain sensors from the system, but other than that I
    am fuzzy on the programming. I'm not sure how to go about teaching the
    system how to recognize each sensor.
    Does anyone have the programming manual for a Rollins System 6? Or
    might anyone be able to tell me how to program this system? Any
    assistance is greatly appreciated.
    Thank you for your time.
    Email: victortrace @AT@ yahoo.com
    #1
    1. Advertisements
  2. V. Trace
    Frank Olson Guest
    "V. Trace" <> wrote in message
    news:030520041019292724%...
    > Hello all --
    Post this same inquiry to the uk.tech.electronic-security newsgroup...
    Frank Olson, May 4, 2004
    #2
    1. Advertisements
  3. V. Trace
    Guest
    > Hello all --
    > battery in our Rollins System 6 was dead. All of the
    > programming for the system has now been lost and all the
    > sensors and smoke detector must be re-programmed back into
    > the system. We would like to reprogram the system
    > manual.
    > do =NOT= need to be ³burned² with a programming
    keypad or
    > any special device. The Rollins System 6 is basically an
    > ITI SV-5 using "Learn Mode" sensors that operate at the
    > 317 mhz frequency. The ITI SV-5 systems normally use 319
    > be used with the newer Concord system which operates at
    > 319 hz.
    > the Alpha keypad and main keyed control unit are fine (we
    > just installed a fresh backup battery in the control
    > console). I am able to figure out how to get into
    I
    > was able to remove certain sensors from the system, but
    > other than that I am fuzzy on the programming. I'm not
    > sure how to go about teaching the system how to recognize
    > each sensor.
    > System 6? Or might anyone be able to tell me how to
    > program this system? Any assistance is greatly
    > appreciated.
    , Jun 7, 2004
    #3
  4. V. Trace
    Guest
    Re: Rollins System V / System V alarm -- need help Programming
    > Hello all --
    > manual.
    keypad or
    > 319 hz.
    I
    > each sensor.
    > appreciated.
    , Jun 7, 2004
    #4
    1. Advertisements
Similar Threads
  1. Klaus Kragelund
    Need a VI Curvetracer, simple and cheap
    Klaus Kragelund, Apr 27, 2007, in forum: Electronic Equipment
    3
    698
    Fred Bartoli
    Apr 29, 2007
  2. Samuel T. Daniels, Jr.
    Need programming manual for Rollins Series VI.
    Samuel T. Daniels, Jr., Sep 26, 2003, in forum: Security Alarms
    913
    Mark Leuck
    Sep 26, 2003
  3. MichelleinAtlanta
    Rollins Series VI-Need Part!!
    MichelleinAtlanta, Jan 7, 2004, in forum: Security Alarms
    816
    Aegis
    Jan 7, 2004
  4. Jim Fiedor
    Rollins model 60-324 System VI
    Jim Fiedor, Nov 23, 2004, in forum: Security Alarms
    1,257
    Jim Fiedor
    Nov 23, 2004
  5. Jim Rojas
    WTB: Rollins System V
    Jim Rojas, Jan 25, 2011, in forum: Security Alarms
    737
    Jim Rojas
    Jan 25, 2011
Loading...
