reversing electromagnet polarity
Discussion in 'Electronic Projects' started by comdoc, Oct 13, 2010.
  1. comdoc
    comdoc
    Oct 13, 2010
    3
    How to electronically switch polarity of a small stator electromagnet (0.5 ohms) as tube magnet rotor (magnetized across diameter) spins? Stators are opposed; stator #1 needs to attract S pole while opposite stator #3 attracts N pole; shaft rotates 90 degrees, power to 1+3 switched off, and power to 2+4 switched on...then stator #2 attracts S pole while stator #4 attracts N pole...etc. Plan to use 12V DC 2 amp power supply and Hall effect sensors. Motor has 4 circuits to solenoids spaced at 90 degrees around shaft; each circuit resistance about 4 ohms. What components are needed for timing?
    comdoc
    #1
    1. Advertisements
  2. comdoc
    20,363
    1,401
    As far as I can tell, you need nothing for timing, you simply place the hall effect switches in the appropriate place to detect when polarity should be reversed.
    Use an H Bridge to reverse the polarity.
    (*steve*), Oct 14, 2010
    #2
    1. Advertisements
  3. comdoc
    comdoc
    Oct 13, 2010
    3
    Thanks, Steve. But it's not when polarity is reversed--rather it's where. One coil is turned on and at the inner end is polarized (ie N) at the same time the opposite coil is turned on and polarized in opposite direction (ie S). These opposing coils are on the same circuit. Should I place Hall sensors at 90 degrees apart around the rotor magnet? Thanks, comdoc.
    comdoc, Oct 14, 2010
    #3
  4. comdoc
    20,363
    1,401
    You place the hall effect sensors such that they detect when the rotor is in the appropriate position to reverse polarity on the stator winding.
    That is what I meant by "when"
    You may have a third issue,
    1) Hall effect sensors to detect when to change polarity
    2) ???
    3) H Bridge to change polarity
    Obviously something needs to control the H Bridge. The hall sensors may only give a quick pulse to say that the polarity should be reversed.
    (2) Could be an SR flip-flop
    (*steve*), Oct 15, 2010
    #4
  5. comdoc
    comdoc
    Oct 13, 2010
    3
    Thanks for your help,
    comdoc
    comdoc, Oct 15, 2010
    #5
    1. Advertisements
Similar Threads
  1. smpaladin
    Reverese polarity of electromagnet
    smpaladin, Sep 12, 2004, in forum: Electronic Basics
    8
    725
    Peter Bennett
    Sep 14, 2004
  2. phaeton
    Determining Electromagnet Polarity
    phaeton, Jan 6, 2006, in forum: Electronic Basics
    13
    987
    Rich Grise
    Jan 11, 2006
  3. fernandomierhicks
    846
    (*steve*)
    Aug 21, 2012
  4. penumbra
    Reversing polarity (not for a motor)
    penumbra, Jun 14, 2013, in forum: Circuit Help
    288
    penumbra
    Jun 14, 2013
  5. flip84
    a reversing polarity?
    flip84, Mar 6, 2014, in forum: General Electronics Chat
    9
    452
    flip84
    Mar 8, 2014
Loading...
