Repair Wharfedale speakers
Discussion in 'Electronics Repair' started by krneki10, Aug 4, 2012.
  1. krneki10
    krneki10
    Aug 4, 2012
    5
    I have an old pair of Wharfedale speakers which stopped playing any music whatsoever. One is still a bit beeping, while other one is completely quite. One was already repaired few years ago, only capacitors were replaced and that seemed to work. Here is an image of this repaired circuit:
    [​IMG]
    Where should I start? What do you recommend?
    #1
    1. Advertisements
  2. krneki10
    duke37 VIP Member
    Jan 9, 2011
    3,802
    365
    Derbyshire. UK
    I am not familiar with the various Wharfdale models.
    What is the model?
    How many drivers in each speaker?
    I would suggest that you take a photo of the connections, then disconnect one wire to each driver and measure the resistance of each driver. If you use a low resistance range on an analog meter, then you should get click on connection.
    I do not see the capacitors on your photo, you can check the inductors for continuity.
    duke37, Aug 4, 2012
    #2
    1. Advertisements
  3. krneki10
    krneki10
    Aug 4, 2012
    5
    Treble 2,1 ohm, midtones 8,1 ohm, bass 8,1 ohm. Nominal impendance 6 ohm. Measured with cheap multimeter.
    #3
  4. krneki10
    duke37 VIP Member
    Jan 9, 2011
    3,802
    365
    Derbyshire. UK
    Did they click when the meter was connected, if so, they look good.
    Have you checked the inductors for continuity?
    The most likely fault is the capacitors. these are unusual, they are non-polarised electrolytics. They should be replaced with the correct values.
    I have a pair of Wharfdale Unit 5s which contain the same bits as the Dovedale but in a home-built box. If necessary I could unearth these and take out the plethora of screws and look at the crossover network. This would take a few days.
    duke37, Aug 4, 2012
    #4
  5. krneki10
    krneki10
    Aug 4, 2012
    5
    Here is a picture of original cross-over filter. What capacitors and resistor should I get for replacement?
    [​IMG]
    krneki10, Aug 13, 2012
    #5
  6. krneki10
    CocaCola VIP Member
    Apr 7, 2012
    3,636
    Gurnee, Illinois - USA - North America - Planet Ea
    CocaCola, Aug 13, 2012
    #6
    1. Advertisements
Similar Threads
  1. ML
    Wharfedale TV - Blinking Picture
    ML, Mar 4, 2004, in forum: Electronic Repair
    458
  2. Ian French
    Wharfedale model 890 28 inch Widescreen TV
    Ian French, Jan 3, 2005, in forum: Electronic Repair
    4
    478
  3. Thaqalain
    3
    664
    Thaqalain
    Aug 16, 2005
  4. Lin
    11
    1,776
  5. laup
    Wharfedale monitor not working
    laup, Oct 19, 2013, in forum: Electronics Repair
    3
    581
Loading...
