removing picture tube
Discussion in 'Electronic Components' started by nate88, Dec 18, 2004.
  1. nate88
    nate88 Guest
    I have a consol tv Iwould like to remove picture tube and other parts and
    reuse cabinet fof something else.can someone tell me how to ground out
    tube so I do not hurt myself .thanks
    #1
    1. Advertisements
  2. Get a screwdriver that will fit under the anode cap, but first ground the
    blade to the chassis with a piece of wire. If the set hasn't been on for
    months it probably won't have a charge and if it does it won't hurt you but
    if it had a charge and you were carrying the tube you might drop it and that
    could hurt.
    73
    Hank WD5JFR
    "nate88" <> wrote in message
    news:...
    Henry Kolesnik, Dec 18, 2004
    #2
    1. Advertisements
  3. nate88
    Tim Guest
    My favourite way is to use the slot screwdriver and strap it to a
    grounded source, eg an outlet etc., thru a 470 k resistor. No big snap
    and the tube will discharge nicely. Do not ground to the chassis unless
    you are sure it is grounded. It probably won't be unless the set in
    plugged into the wall, which you really don't want to have....
    - Tim -
    In article
    ..com>, says...
    Tim, Dec 19, 2004
    #3
  4. nate88
    Alan R. Betz Guest
    Tim <> wrote in
    news::
    > unless you are sure it is grounded. It probably won't be unless the
    > set in plugged into the wall, which you really don't want to have....
    > - Tim -
    Absurd. The capacitance storing the charge is formed by the aquadag
    coating on the outside of the picture tube glass and the internal
    coating connected to the metal HV connector. Since the outside
    coating is indeed connected to the chassis, you SHOULD discharge the
    button to the chassis. It doesn't matter whether or not the set is
    plugged in at the time.
    Alan.
    Alan R. Betz, Dec 20, 2004
    #4
    1. Advertisements
Similar Threads
  1. Br Dan Izzo
    5
    2,135
    Captain Blammo
    Sep 8, 2004
  2. Dan Winker
    5
    1,269
  3. Mark Pfeifer
    Mitsubishi Picture Tube Leak
    Mark Pfeifer, Oct 2, 2003, in forum: Electronic Repair
    24
    957
    Mark Pfeifer
    Oct 9, 2003
  4. Bobby Longsocks
    16
    1,563
    Bobby Longsocks
    Jun 24, 2004
  5. Simon Webberist
    CRT tube - Releasing vacuum for tube removal/disposal
    Simon Webberist, Aug 23, 2006, in forum: Electronic Repair
    23
    6,707
    Michael A. Terrell
    Dec 31, 2006
Loading...
