relay switching speed
Discussion in 'Electronic Basics' started by lerameur, Aug 22, 2008.
  1. lerameur
    lerameur Guest
    hello,
    I am trying to figure out is there is any rating on the maximum
    switching speed on mechanical relays such as the R3-24AC or 50-094-0
    (or just any mechanical relay) I want to use dc current on these and
    switch them possibly 1000Hertz or possibly 10,000Hertz. what is the
    maximum speed they can be continuously switch?
    thanks
    K
    #1
    1. Advertisements
  2. lerameur
    Sjouke Burry Guest
    lerameur wrote:
    > hello,
    > thanks
    > K
    The "on" switching time is depending on the speed with which
    you can push current into the relay coil, and would rather
    quickly get into the range to burn out the coil, if you want
    high switching speed.
    The "off" switching time however depends two things, first how
    fast you can kill the current in the relay(rather difficult),
    and secondly on a metal spring in the relay to pull the relay "open".
    The spring is what is limiting the ultimate speed.
    An ordinary relay will be ~50-200 hz, and very small relays, like a
    reed relay for example might be pushed a bit higher, like 200-400 hz
    A quick test would be to put the NO contact in series with the coil,
    and make it self-switching, acting like a buzzer.
    You can increase the supply voltage a bit, but you risk burnout of the
    coil.
    Also the contacts wont last long.
    1000Hz? unlikely.
    10000hz? wishful thinking.
    If you really want fast mechanical switching , use a rotary switch,
    driven by a motor.
    Using FET switches, you can get into the Megahz range.
    Sjouke Burry, Aug 22, 2008
    #2
    1. Advertisements
  3. lerameur
    lerameur Guest
    Re: relay switching speed
    On Aug 22, 2:14 pm, Sjouke Burry <>
    wrote:
    > lerameur wrote:
    > > hello,
    > > thanks
    > > K
    > coil.
    > 1000Hz? unlikely.
    > driven by a motor.
    Ok I found this part at Digikey.com
    CLA280-ND
    it is a static relay, that can handle the required switching but it
    is not a SPDT, and there are no SPDT in the 6 amps or higher
    regions.... are these high power relays done in static technology?
    K
    #3
  4. lerameur
    whit3rd Guest
    > switching speed on mechanical relays ...
    Firstly, if the coil current is modulated at 1000 Hz, this is NOT DC
    current
    we're talking about. On every cycle, you'll generate some core heat
    due to magnetization losses. This may be important. Smoke
    is possible. Do not expect that 'normal' operating voltages are
    sufficient, either
    Secondly, the 'ON' position of the relay is achieved by hitting a pair
    of parts together , and they either progress to hammer each other
    out of shape OR they engage in elastic deformation. That elasticity
    means there is bounce, and the 'ON' status is very much compromised
    until the bouncing stops. This is the one, the only, item that a
    relay
    manufacturer is likely to specify about the short-time character of
    the relay.
    And third, the 'OFF' position usually is a long way from the 'ON',
    so that sparks don't occur. If you expect 5 kV operation, or 50 mV
    operation, the suitable delay-to-OFF time will be quite different.
    Some small-signal (telephone) relays have impressive contact lifetime
    with circa 50V stress; lower voltages have dirt-related reliability
    issues, and higher voltages have wrath-of-Zeus related reliability
    issues.
    At 1 kHz your prospective device will hit millions of times per hour,
    and contact life will be a major issue. Practical vibrators (I seem
    to recall)
    worked at tens of Hz.
    The literature on this kind of application is heavily influenced by
    Motorola
    and relates to early car radios (which Motorola made); the oscillating
    'relay' was called a vibrator, and failed as frequently as any of the
    vacuum
    tubes.
    whit3rd, Aug 23, 2008
    #4
  5. lerameur
    Jamie Guest
    lerameur wrote:
    > hello,
    > thanks
    > K
    Most likely induction is to high in the coil for that kind of speed,
    you'll never get enough current to pull the contacts.
    Assuming this is a 24 Volt AC coil, it has been wound and designed
    to create enough current with in the cycle time of 50/60 hz..
    Ect...
    http://webpages.charter.net/jamie_5"
    Jamie, Aug 23, 2008
    #5
  6. lerameur
    Jasen Betts Guest
    On 2008-08-22, lerameur <> wrote:
    > hello,
    > thanks
    typical DC relays are good to something around 100Hz
    (AC relays have slower switching rates)
    you may be able to coax higher rates by closed loop control
    ISTR getting about 300Hz in this way once. (i wired the NC contats in
    series with the coil and adjusted the supply for the highest pitch)
    if you want to go higher you may need to consider piezo actuators
    instead of magnetic, or go solid-state instead.
    Bye.
    Jasen
    Jasen Betts, Aug 23, 2008
    #6
  7. lerameur
    kammenos
    Aug 18, 2008
    Absolutely imposible. Relays are not to work like this. They are to carry heavy loads. You should consider using some kind of transistor or anything else. What exactly are you trying to make?
    kammenos, Aug 23, 2008
    #7
  8. lerameur
    Bob Eld Guest
    "lerameur" <> wrote in message
    news:...
    > hello,
    > thanks
    > K
    Forget about it. As mentioned in all of the above posts, relays are far too
    slow for your application. AC relays are even slower because they have a
    copper "shade" on the pole piece to deliberately keep the field from
    collapsing fast. This keeps the relay from chattering on AC drive.
    Your application requires electronic switching for the speeds you mention.
    Transistors, FETs, SCRs, etc. should be considered depending on the exact
    requirements.
    Bob Eld, Aug 23, 2008
    #8
  9. lerameur
    Ross Herbert Guest
    On Fri, 22 Aug 2008 11:44:22 -0700 (PDT), lerameur <> wrote:
    :Ok I found this part at Digikey.com
    :CLA280-ND
    : it is a static relay, that can handle the required switching but it
    :is not a SPDT, and there are no SPDT in the 6 amps or higher
    :regions.... are these high power relays done in static technology?
    :K
    Did you look at the datasheet?
    http://clareweb2.clare.com/home/pdfs.nsf/0/614B59328CA886C28525726600495950/$file/CPC1709.pdf
    Max T-on is 20mS and max T-off is 5mS. This limits the maximum (reliable)
    operating speed to 40 operations per second but you would need some safety
    margin. Say around 37 ops per second guaranteed.
    A reed relay will typically have operate and release time of around 1mS but they
    can't handle the current you are talking about.
    Ross Herbert, Aug 24, 2008
    #9
  10. lerameur
    Ross Herbert Guest
    On Sun, 24 Aug 2008 07:56:02 GMT, Ross Herbert <> wrote:
    :Did you look at the datasheet?
    :http://clareweb2.clare.com/home/pdfs.nsf/0/614B59328CA886C28525726600495950/$file/CPC1709.pdf
    :Max T-on is 20mS and max T-off is 5mS. This limits the maximum (reliable)
    :eek:perating speed to 40 operations per second but you would need some safety
    :margin. Say around 37 ops per second guaranteed.
    And that is assuming that an on time of say 1 - 2mS is sufficient to perform the
    required function.
    #10
  11. lerameur
    neon VIP Member
    Oct 21, 2006
    1,324
    just forget relay for that speed theywere never meant to switch that fast. reeds might do it as mechanical switching but even them are not realibly at that speed . BOTTOM LINE FET or transistors.
    neon, Aug 24, 2008
    #11
    1. Advertisements
Similar Threads
  1. mike
    fan speed switching?
    mike, Jul 22, 2003, in forum: Electronic Basics
    3
    663
  2. Paul Burridge
    High speed switching transistors
    Paul Burridge, Jun 27, 2004, in forum: CAD
    462
    Robert
    Jun 28, 2004
  3. ectoplasm
    AC fan speed control by periodic on/off switching
    ectoplasm, May 3, 2007, in forum: Electronic Design
    41
    1,600
    ectoplasm
    May 19, 2007
  4. _
    Speed and cost of switching LCD segment
    _, Nov 1, 2009, in forum: Electronic Design
    3
    399
    oopere
    Nov 4, 2009
  5. Glock
    high speed solenoid switching
    Glock, Apr 25, 2011, in forum: Circuit Help
    4
    3,881
    Glock
    Apr 26, 2011
Loading...
